    4. Extrem viele Fehlermeldungen (logFile >16 MB)
      tgirard last edited by
      Guten Abend
      vielleicht kann mir jemand von Euch helfen? Ich habe eine Installation mit einem Raspi2 und einem BananaPi. Auf dem Banana laufen
      Harmony
      history
      socketio
      sql
      vis
      flot
      Mein Logfile ist extrem gross, zum Teil täglich über 16 MB. Die häufigste Fehlermeldung ist:
      bananapi 2016-04-18 19:53:49 info host.bananapi Restart adapter system.adapter.sql.0 because enabled
      bananapi 2016-04-18 19:53:49 error host.bananapi instance system.adapter.sql.0 terminated with code 7 (Adapter already running)
      bananapi 2016-04-18 19:53:49 info host.bananapi Restart adapter system.adapter.harmony.0 because enabled
      bananapi 2016-04-18 19:53:49 error host.bananapi instance system.adapter.harmony.0 terminated with code 6 (uncaught exception)
      bananapi 2016-04-18 19:53:48 info host.bananapi Restart adapter system.adapter.socketio.0 because enabled
      bananapi 2016-04-18 19:53:48 error host.bananapi instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
      bananapi 2016-04-18 19:53:38 info host.bananapi instance system.adapter.socketio.0 started with pid 26367
      bananapi 2016-04-18 19:53:37 info host.bananapi instance system.adapter.sql.0 started with pid 26364
      bananapi 2016-04-18 19:53:37 info host.bananapi Restart adapter system.adapter.history.0 because enabled
      bananapi 2016-04-18 19:53:37 error host.bananapi instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      bananapi 2016-04-18 19:53:36 info host.bananapi instance system.adapter.harmony.0 started with pid 26357
      bananapi 2016-04-18 19:53:33 info host.bananapi instance system.adapter.history.0 started with pid 26354
      host-bananapi 2016-04-18 19:53:08 info Restart adapter system.adapter.socketio.0 because enabled
      host-bananapi 2016-04-18 19:53:08 error instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
      kann mir da evtl. jemand helfen ?
      vielen Dank!
      Thierry
        Hast du auf dem Bananapi mal ein iobroker restart gemacht?
        Wenn das nicht hilft einen reboot?
          Danke für die schnelle Antwort. Ja, habe ich beides schon gemacht. Macht keinen Unterschied.
          ioBroker startet jeden Morgen um 04:00 neu (inkl. backup). Den BananaPi habe ich schon mehrfach neu gestartet.
          Auch schon beide ausgeschaltet, dann zuerst Raspberry gestartet, dann BananaPi. Aber es sieht immer ungefähr gleich aus. Auf dem Raspberry sind die logfiles ca. 300kB gross, auf dem BananaPi zwischen 2 und 16 MB.
            @tgirard:
            Auch schon beide ausgeschaltet, dann zuerst Raspberry gestartet, dann BananaPi. Aber es sieht immer ungefähr gleich aus. Auf dem Raspberry sind die logfiles ca. 300kB gross, auf dem BananaPi zwischen 2 und 16 MB. `
            Ich nehme an, du hast multihost installation. Das ist bekannter Bug, dass wenn HauptHost(Raspi) neu gestartet wird, wird er versuchen auf SlaveHost(BananaPi) schon laufende Adapter neu zu starten… Ich dachte, dass nach dem als HauptHost neu gestartet wird, reicht es SlaveHost auch neu zu starten. Ist das nicht so?
              ja genau, läuft unter multihost. Nein bisher scheint es nicht so zu sein:
              • Master neu starten, dann Slave neu starten => Fehlermeldungen betreffend versuch laufenden Adapter zu starten
              • Nur Slave neu starten => gleicher Fehler
              • Nur Master nur starten => gleicher Fehler
              Was ich noch nicht versucht habe ist zuerst beide runterfahren, dann Slave neu starten und dann Master. Soll ich das versuchen?
              81.0k
