    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер KODI
    Драйвер KODI
    • I
      instalator last edited by
      Начал писать https://github.com/instalator/iobroker.kodi.
      Принимаются пожелания. Кто, что и как хочет видеть в работе драйвера.
      • V
        vtec last edited by
        Если я не ошибаюсь, kodi может работать на ws. Тогда для начала сделать пульт управления через ws .
        А как максимум так: https://github.com/Jalle19/xbmc-video-server 🙂
        • aurodionov
          aurodionov last edited by
          ставится с варнингами и ошибками
          ! iobroker 2016-04-24 11:02:56 info exit 0
          ! iobroker 2016-04-24 11:02:56 info upload [0] kodi /opt/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown
          ! iobroker 2016-04-24 11:02:56 info upload [1] kodi /opt/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html
          ! iobroker 2016-04-24 11:02:56 info upload [2] kodi /opt/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png
          ! iobroker 2016-04-24 11:02:56 info Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.kodi/www
          ! host-SmartHome 2016-04-24 11:02:56 info "system.adapter.vis.0" enabled
          ! host-SmartHome 2016-04-24 11:02:56 info object change system.adapter.vis.0
          ! host-SmartHome 2016-04-24 11:02:56 info "system.adapter.vis.0" disabled
          ! iobroker 2016-04-24 11:02:56 info upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html
          ! Cannot 2016-04-24 11:02:56 error write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/: EISDIR: illegal operation on a directory, open '/opt/iobroker/node_modules/iobr
          ! iobroker 2016-04-24 11:02:56 info upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/iobroker.kodi.png image/png
          ! iobroker 2016-04-24 11:02:55 info upload [2] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png
          ! iobroker 2016-04-24 11:02:55 info got /opt/iobroker/node_modules/iobroker.kodi/admin
          ! iobroker 2016-04-24 11:02:55 info iobroker.kodi@0.0.2 ../opt/iobroker/node_modules/iobroker.kodi└── kodi-ws@2.4.0 (has-value@0.2.1, set-value@0.2.0, jrpc-schema@2.0.0, ws@0.7.2, eslint@2.2.0, babel-eslint@5.0.4)
          ! iobroker 2016-04-24 11:02:02 info npm WARN optional dep failed, continuing bufferutil@1.1.0
          ! iobroker 2016-04-24 11:02:02 info npm WARN optional dep failed, continuing utf-8-validate@1.1.0
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! not ok
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/w
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! System Linux 3.16.0-4-686-pae
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at ChildProcess.emit (events.js:172:7)
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at emitTwo (events.js:87:13)
          ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          ! iobroker 2016-04-24 11:02:02 info ERR! build error
          ! iobroker 2016-04-24 11:02:02 info make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Ошибка 1
          ! iobroker 2016-04-24 11:02:02 info bufferutil.target.mk:90: ошибка выполнения рецепта для цели «Release/obj.target/bufferutil/src/bufferutil.o»make: выход из каталога «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node
          ! iobroker 2016-04-24 11:02:01 info ^
          ! iobroker 2016-04-24 11:02:01 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
          ! iobroker 2016-04-24 11:02:01 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal’ to ‘v8::Local’
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
          ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:16:0:
          ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
          ! iobroker 2016-04-24 11:02:01 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
          ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
          ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
          ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
          ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:10:0:
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:672:67: note: candidates are:
          ! iobroker 2016-04-24 11:02:01 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:
          ! iobroker 2016-04-24 11:02:01 info v8::Isolate::GetCurrent(), data, length, callback, hint);
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’ , node::smalloc::FreeCallback callback
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
          ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:256:25: note: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
          ! iobroker 2016-04-24 11:02:01 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
          ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
          ! iobroker 2016-04-24 11:01:59 info CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
          ! iobroker 2016-04-24 11:01:59 info make: вход в каталог «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil/build»
          ! iobroker 2016-04-24 11:01:55 info > node-gyp rebuild
          ! iobroker 2016-04-24 11:01:55 info > bufferutil@1.1.0 install /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! not ok
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! node-gyp -v v3.3.1
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! node -v v4.4.3
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! System Linux 3.16.0-4-686-pae
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          ! iobroker 2016-04-24 11:01:55 info gyp ERR! build error
          ! iobroker 2016-04-24 11:01:55 info make: *** [Release/obj.target/validation/src/validation.o] Ошибка 1
          ! iobroker 2016-04-24 11:01:55 info validation.target.mk:90: ошибка выполнения рецепта для цели «Release/obj.target/validation/src/validation.o»make: выход из каталога «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node
          ! iobroker 2016-04-24 11:01:55 info ^
          ! iobroker 2016-04-24 11:01:55 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
          ! iobroker 2016-04-24 11:01:55 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal’ to ‘v8::Local’
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
          ! iobroker 2016-04-24 11:01:55 info In file included from ../src/validation.cc:15:0:
          ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
          ! iobroker 2016-04-24 11:01:55 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
          ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
          ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
          ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
          ! iobroker 2016-04-24 11:01:55 info In file included from ../src/validation.cc:10:0:
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:672:67: note: candidates are:
          ! iobroker 2016-04-24 11:01:55 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:
          ! iobroker 2016-04-24 11:01:55 info v8::Isolate::GetCurrent(), data, length, callback, hint);
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’ , node::smalloc::FreeCallback callback
          ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
          ! iobroker 2016-04-24 11:01:54 info ^
          ! iobroker 2016-04-24 11:01:54 info ../node_modules/nan/nan.h:256:25: note: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
          ! iobroker 2016-04-24 11:01:54 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
          ! iobroker 2016-04-24 11:01:54 info In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
          ! iobroker 2016-04-24 11:01:52 info CXX(target) Release/obj.target/validation/src/validation.o
          ! iobroker 2016-04-24 11:01:52 info make: вход в каталог «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate/build»
          ! iobroker 2016-04-24 11:01:37 info > node-gyp rebuild
          ! iobroker 2016-04-24 11:01:37 info > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate
          ! iobroker 2016-04-24 11:01:31 info npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
          ! iobroker 2016-04-24 11:01:31 info WARN peerDependencies The peer dependency eslint@<2.3.0 included from babel-eslint will no
          ! iobroker 2016-04-24 11:01:06 info npm install https://github.com/instalator/iobroker. ... all/master --production --prefix "/opt/iobroker" (System call)
          ! iobroker 2016-04-24 11:01:06 info install https://github.com/instalator/iobroker. ... all/master
          ! iobroker 2016-04-24 11:01:05 info url "https://github.com/instalator/iobroker.kodi" --debug
          • aurodionov
            добавить в уведомления - адрес иконки для отображения в уведомлении,
            например http://server.lan/%D0%BA%D0%B0%D1%80%D1%82%D0%B8%D0%BD%D0%BA%D0%B0.jpg или vis/путь.картинка.jpg
            • I
              @aurodionov:
              например http://server.lan/%D0%BA%D0%B0%D1%80%D1%82%D0%B8%D0%BD%D0%BA%D0%B0.jpg или vis/путь.картинка.jpg `
              А пример можно как там можно отобразить картинку?
              • aurodionov
                На смежном сайте тоже пилят драйвер
                http://majordomo.smartliving.ru/forum/v … f=5&t=2893
                возможно у них подсмотреть
                • I
                  @aurodionov:
                  возможно у них подсмотреть `
                  Вспомнил что я делал так, хотел жипег с камеры отображать, но картинка уменьшается до размера иконки. т.е. там можно задать свою иконку просто.
                  • aurodionov
                    ясно , иконка уже не плохо
                    можно от разных девайсов месоги быстро различать визуально а не только аларм,инфо
                    хотя для камеры снапшот это было бы круто, вопрос с размером
                    • I
                      Если закрыть Коди, то драйвер падает с непонятной ошибкой
                      Server-PC 2016-04-27 21:39:57 info host.Server-PC instance system.adapter.kodi.0 started with pid 2692
                      Server-PC 2016-04-27 21:39:27 info host.Server-PC Restart adapter system.adapter.kodi.0 because enabled
                      Server-PC 2016-04-27 21:39:27 error host.Server-PC instance system.adapter.kodi.0 terminated with code 0 (OK)
                      kodi.0 2016-04-27 21:39:26 debug kodi.0 Response GetPlayerId [[],{"muted":false,"volume":100}]
                      Из-за чего происходит ошибка непонятно, как можно выловить эти ошибки и отработать? Может возможно подписаться на 'error' модуля kodi-ws?
                      у него есть self.emit но я так понимаю чтобы подписаться на них в самом драйвере нужно как то их сделать видимыми в самом драйвере.
                      • I
                        Виджеты для КОДИ:
                        [{"tpl":"tplkodiProgressBar","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid":"kodi.0.playing_time","oid_curtime":"kodi.0.playing_time","oid_curtimetotal":"kodi.0.playing_time_total","oid_seek":"kodi.0.seek"},"style":{"left":"93px","top":"436px","width":"514px","height":"12px","color":"","background-color":"#a50d0d"},"widgetSet":"kodi"},{"tpl":"tplkodiPlaylist","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_playlist":"kodi.0.playlist","oid_goto":"kodi.0.GoTo","oid_position":"kodi.0.position"},"style":{"left":"91px","top":"186px","width":"511px","height":"241px","color":"#2d8f39","background-color":"#0f0505","border-radius":"5px","border-style":"groove","border-color":"#0a8aeb","padding-left":"","box-shadow":"","font-size":"x-small"},"widgetSet":"kodi"},{"tpl":"tplkodiButton","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_play":"kodi.0.play","oid_speed":"kodi.0.speed","oid_prev":"kodi.0.previous","oid_next":"kodi.0.next","oid_stop":"kodi.0.stop","oid_mute":"kodi.0.mute","oid_rpt":"kodi.0.repeat","oid_shf":"kodi.0.shuffle","oid_seek":"kodi.0.seek"},"style":{"left":"88px","top":"458px","width":"400px","height":"50px"},"widgetSet":"kodi"},{"tpl":"tplJquiSlider","data":{"oid":"kodi.0.volume","visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"min":"0","max":"100","step":"1"},"style":{"left":"490px","top":"469px","width":"102px","height":"23px"},"widgetSet":"jqui"},{"tpl":"tplkodiCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_codec":"kodi.0.codec"},"style":{"left":"96px","top":"520px","width":"50px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiAspect","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_aspect":"kodi.0.info.video_aspect"},"style":{"left":"272px","top":"520px","width":"36px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiResolut","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_resolut":"kodi.0.info.video_height"},"style":{"left":"232px","top":"520px","width":"35px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiChannel","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_channel":"kodi.0.channels"},"style":{"left":"150px","top":"520px","width":"28px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiVideoCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_videocodec":"kodi.0.info.video_codec"},"style":{"left":"183px","top":"520px","width":"46px","height":"25px"},"widgetSet":"kodi"}]
                          Запости скрины для затравки 😉
                          • I
                            @Bluefox:
                            Запости скрины для затравки 😉 `
                            • I
                              @Bluefox:
                              Немогу победить почему драйвер падает при закрытии КОДИ, причем он падает даже если вызов всех функции в main закоментить кроме getConnection.
                              Получается какой то встроенный модуль дает исключение. Может посмотреть?
                                BTW: https://github.com/ioBroker/ioBroker/wi … connection
                                Проблема с падением ещё есть?
                                • I
                                  @Bluefox:
                                  Проблема с падением ещё есть? `
                                  Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                                    @instalator:
                                    @Bluefox:
                                    Проблема с падением ещё есть? Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                                    У меня нет KODI. С какой ошибкой сваливается и где?
                                    Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin.
                                      Ты не можешь создать все переменные, как info.connection в io-package.json?
                                      А то при установке значения ты всегда создаёшь (или перезаписываешь) объект.
                                      function setObject(name, val, type){
                                      if (type){
                                      name = type +'.'+ name;
                                      object = {
                                      type: 'state',
                                      common: {
                                      role: 'media',
                                      type: typeof val
                                      native: {}
                                      adapter.setObject(name, object, function (err, obj) {
                                      adapter.setState(name, {val: val, ack: true});
                                      Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта.
                                      Вот этого я тоже не пойму..
                                      [https://github.com/instalator/iobroker. … di.js#L255](https://github.com/instalator/iobroker.kodi/blob/master/kodi.js#L255)
                                      • I
                                        @Bluefox:
                                        Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта. `
                                        Это переделаю.
                                        @Bluefox:
                                        https://github.com/instalator/iobroker. … di.js#L255 `
                                        Если этой строки не добавить, то драйвер не реагирует на message. И только после того как из самого драйвера отправишь сообщение то начинает работать и из драйвера JS. Поэтому сделал пока так и хотел тебя спросить по этому вопросу.
                                        • I
                                          @Bluefox:
                                          @instalator:
                                          @Bluefox:
                                          Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin. `
                                          info.connection добавил, интересная штука, только сейчас увидел ее в работе)
                                          А вот по падению не понятно.
                                          Если в драйвере оставляю в main только этот код:
                                          getConnection(function (err, _connection) {
                                          if (_connection){
                                          стартануть драйвер, а потом закрыть программу КОДИ, то драйвер просто падает.
                                          Из лога ошибка не ясна.
                                          host-Server-PC	2016-05-04 19:39:14	info	Restart adapter system.adapter.kodi.0 because enabled
                                          host-Server-PC	2016-05-04 19:39:14	error	instance system.adapter.kodi.0 terminated with code 0 (OK)
                                          kodi-0	2016-05-04 19:39:12	debug	Response GetPlayerId [[],{"muted":false,"volume":100}]
                                          • I
                                            Вот просто свалился и все, сам не перезапускается.
                                            8868
