    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Iobroker js-controller - ошибки
      Lstt last edited by
      Шеф, всё пропало..)
      Всё как у немцев - http://forum.iobroker.com/viewtopic.php … bc9c49faf7 .
      Удалил папки, переустановил заново:
      npm install iobroker.js-controller
      npm install iobroker.admin
      В серверах написано:
      ! js-controller ioBroker.js-controller win32 доступен 0.8.7 установлен 0.8.9
      После небольшого времени сыпятся ошибки:
      ! iobroker 2016-04-23 21:21:31 info exit 1 iobroker 2016-04-23 21:21:30 error iobroker 2016-04-23 21:21:30 error at require (module.js:384:17) iobroker 2016-04-23 21:21:30 error at Module.require (module.js:365:17) iobroker 2016-04-23 21:21:30 error at Function.Module._load (module.js:310:12) iobroker 2016-04-23 21:21:30 error at Module.load (module.js:355:32) iobroker 2016-04-23 21:21:30 error at Object.Module._extensions..js (module.js:478:10) iobroker 2016-04-23 21:21:30 error at Module._compile (module.js:460:26) iobroker 2016-04-23 21:21:30 error at Object. (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:310:9) iobroker 2016-04-23 21:21:30 error at restartController (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:2113:18) iobroker 2016-04-23 21:21:30 error at Object.fs.openSync (fs.js:500:18) iobroker 2016-04-23 21:21:30 error at Error (native) iobroker 2016-04-23 21:21:30 error Error: ENOENT, no such file or directory 'C:\iobroker\node_modules\iobroker.js-controller\log\restart.log' iobroker 2016-04-23 21:21:30 error ^ iobroker 2016-04-23 21:21:30 error fs.js:500 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); host-OPENSERVER 2016-04-23 21:21:29 info instance system.adapter.javascript.0 terminated with code 0 (OK) iobroker 2016-04-23 21:21:29 info _restart TypeError: 2016-04-23 21:21:29 error at TCP.onread (net.js:540:20) TypeError: 2016-04-23 21:21:29 error at Socket.Readable.push (_stream_readable.js:126:10) TypeError: 2016-04-23 21:21:29 error at readableAddChunk (_stream_readable.js:163:16) TypeError: 2016-04-23 21:21:29 error at Socket.emit (events.js:107:17) TypeError: 2016-04-23 21:21:29 error at Socket.realHandler (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\WebSocket.js:800:20) TypeError: 2016-04-23 21:21:29 error at Receiver.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:95:24) TypeError: 2016-04-23 21:21:29 error at Receiver. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:451:33) TypeError: 2016-04-23 21:21:29 error at Receiver.opcodes.1.finish (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:483:12) TypeError: 2016-04-23 21:21:29 error at Receiver.endPacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:247:18) TypeError: 2016-04-23 21:21:29 error Cannot read property 'fragmentedOperation' of null uncaught 2016-04-23 21:21:29 error exception: Cannot read property 'fragmentedOperation' of null !
        @Lstt:
        Шеф, всё пропало..)
        ! iobroker 2016-04-23 21:21:31 info exit 1 iobroker 2016-04-23 21:21:30 error iobroker 2016-04-23 21:21:30 error at require (module.js:384:17) iobroker 2016-04-23 21:21:30 error at Module.require (module.js:365:17) iobroker 2016-04-23 21:21:30 error at Function.Module._load (module.js:310:12) iobroker 2016-04-23 21:21:30 error at Module.load (module.js:355:32) iobroker 2016-04-23 21:21:30 error at Object.Module._extensions..js (module.js:478:10) iobroker 2016-04-23 21:21:30 error at Module._compile (module.js:460:26) iobroker 2016-04-23 21:21:30 error at Object. (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:310:9) iobroker 2016-04-23 21:21:30 error at restartController (C:\iobroker\node_modules\iobroker.js-controller\lib\setup.js:2113:18) iobroker 2016-04-23 21:21:30 error at Object.fs.openSync (fs.js:500:18) iobroker 2016-04-23 21:21:30 error at Error (native) iobroker 2016-04-23 21:21:30 error Error: ENOENT, no such file or directory 'C:\iobroker\node_modules\iobroker.js-controller\log\restart.log' iobroker 2016-04-23 21:21:30 error ^ iobroker 2016-04-23 21:21:30 error fs.js:500 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); host-OPENSERVER 2016-04-23 21:21:29 info instance system.adapter.javascript.0 terminated with code 0 (OK) iobroker 2016-04-23 21:21:29 info _restart TypeError: 2016-04-23 21:21:29 error at TCP.onread (net.js:540:20) TypeError: 2016-04-23 21:21:29 error at Socket.Readable.push (_stream_readable.js:126:10) TypeError: 2016-04-23 21:21:29 error at readableAddChunk (_stream_readable.js:163:16) TypeError: 2016-04-23 21:21:29 error at Socket.emit (events.js:107:17) TypeError: 2016-04-23 21:21:29 error at Socket.realHandler (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\WebSocket.js:800:20) TypeError: 2016-04-23 21:21:29 error at Receiver.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:95:24) TypeError: 2016-04-23 21:21:29 error at Receiver. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:451:33) TypeError: 2016-04-23 21:21:29 error at Receiver.opcodes.1.finish (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:483:12) TypeError: 2016-04-23 21:21:29 error at Receiver.endPacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Receiver.js:247:18) TypeError: 2016-04-23 21:21:29 error Cannot read property 'fragmentedOperation' of null uncaught 2016-04-23 21:21:29 error exception: Cannot read property 'fragmentedOperation' of null ! `
        А комп перестартовывал?
        К меня подозрения, что ты не остановил контролер перед обновлением. Или он не до конца остановился.
        • I
          instalator last edited by
          Стоит обновляться нет? работает? попробовал через админку выдал ошибку.
          ! $ ./iobroker upgrade self
          ! npm install iobroker.js-controller –production --prefix "C:/ioBroker" (System call)
          ! npm
          ! ERR!
          ! Windows_NT 6.1.7601
          ! npm
          ! ERR!
          ! argv
          ! "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.js-controller" "--production" "--prefix" "C:/ioBroker"
          ! npm
          ! ERR!
          ! node
          ! v0.12.2
          ! npm
          ! ERR!
          ! npm
          ! v2.7.4
          ! npm
          ! ERR!
          ! Cannot read property 'trim' of undefined
          ! npm
          ! ERR!
          ! npm
          ! ERR!
          ! If you need help, you may report this error at:
          ! npm
          ! ERR!
          ! <https://github.com/npm/npm/issues>
          ! npm
          ! WARN
          ! deprecated
          ! jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
          ! npm
          ! WARN
          ! deprecated
          ! graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
          ! npm
          ! ERR!
          ! Please include the following file with any support request:
          ! npm
          ! ERR!
          ! C:\ioBroker\node_modules\iobroker\npm-debug.log
          ! ERROR: host.Server-PC Cannot install iobroker.js-controller: 1
          ! ERROR: process exited with code 25
          • I
            Обновился:
            чяднт?
              DAndre last edited by
              Тоже самое как у instalator Ж((
              • I
                В логе выдает:
                Server-PC	2016-04-24 18:23:08	warn	host.Server-PC warning: Timeout by read all package.json (79) seconds
                Похоже рубится по таймауту?
                  @instalator:
                  В логе выдает:
                  Похоже рубится по таймауту? `
                  Переставь репозиторий на fast-online
                  • I
                    @Bluefox:
                    @instalator:
                    В логе выдает:
                    Похоже рубится по таймауту? Переставь репозиторий на fast-online
                    ) Спасибо помогло
                      Кто подскажет адрес этого faааааааst-online 😢
                      • I
                        @DAndre:
                        Кто подскажет адрес этого faааааааst-online 😢 `
                        http://download.iobroker.net/sources-dist.json
                          spectrekr last edited by
                          Не знаю, тут не тут, опишу тут.
                          После обновления до версии 0.8.10 посыпались ошибки от rpi драйвера
                          ! rpi-0 2016-04-26 15:04:49 error No Value found for cpu_frequency
                          Хотя, на версии 0.8.9 работало все отлично.
                            @spectrekr:
                            Хотя, на версии 0.8.9 работало все отлично. `
                            Надо сказать, что обновление 0.8.10 ничего с rpi не делало.
                            rpi читает данные из файлов:
                            > cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
                              Ну только что проверил, файл на месте и с него читаются данные. Странно то что после обновления появилась данная проблема. Попробую переустановить драйвер. Обновление nodejs до 4 версии ошибку тоже не исправило.
                              Отправлено с моего C6603 через Tapatalk
                                @spectrekr:
                                Отправлено с моего C6603 через Tapatalk `
                                Здесь можно увидеть, как происходит добыча информации:
                                https://github.com/husky-koglhof/iobrok … e.json#L40
                                  Странно как до этого работало, сейчас проверил по всем процессорам cpuinfo_cur_frequently доступ на чтение только root, остальным вообще все запрещено. Но есть scaling_cur_frequently с теме же показателями, может стоит с него читать? Он по крайней мере всем доступен
                                    kID last edited by
                                    Обновился до версии 0.11.1 после чего перестали обновляться драйвера.
                                    Не получается ни через админку, ни через командную строку. брокер через секунду рапортует о том, что драйвер обновлен, при этом все остается как прежде.
                                    Если драйвер снести, то новая установка проходит без проблем.
                                      Haus last edited by
                                      @kID:
                                      Если драйвер снести, то новая установка проходит без проблем. `
                                      Потверждаю,
                                      Я тут megaESP драйвер делаю :roll: , псле неправильных конфигураций 😢 иногда слетала в eror думал сломал чего 🙂
                                      • Z
                                        znammut last edited by
                                        Здравствуйте, обновил контроллеры до версии 1.1.3 - отвалились ноды. Что делать непонятно, конфигурацию не менял… Может, что изменилось?
                                        Логи нод:
                                        2017-08-23 10:08:05.593 - .[32minfo.[39m: host.orangepipc-2 iobroker.js-controller version 1.1.3 js-controller starting 2017-08-23 10:08:05.613 - .[32minfo.[39m: host.orangepipc-2 Copyright (c) 2014-2017 bluefox, hobbyquaker 2017-08-23 10:08:05.615 - .[32minfo.[39m: host.orangepipc-2 hostname: orangepipc-2, node: v4.8.4 2017-08-23 10:08:05.618 - .[32minfo.[39m: host.orangepipc-2 ip addresses: 192.168.17.67 fe80::81:d4ff:fe54:4964[/code]
                                        ! и все
                                        • Z
                                          похоже что контроллер поднимается на 127.0.0.1:
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      31156/iobroker.js-c
                                          Что надо поправить?
                                          С уважением
                                            @znammut:
                                            Что надо поправить?
                                            С уважением `
                                            На мастере открываешь /opt/iobroker/iobroker-data/iobroker.json и правишь 127.0.0.1 на 0.0.0.0, сохраняешь и перезапускаешь, должны подключится остальные хосты.
                                            Второй вариант
                                            iobroker stop
                                            iobroker setup custom
                                            Type of objects DB [file, couch, redis], default [file]: нажать enter
                                            Host of objects DB(file), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                            Port of objects DB(file), default[9001]: нажать enter
                                            Type of states DB [file, redis], default [file]: redis нажать enter
                                            Host of states DB (redis), default[127.0.0.1]: ввести 0.0.0.0 и нажать enter
                                            Port of states DB (redis), default[6379]: нажать enter
                                            Data directory (file), default[../../../iobroker-data/]: нажать enter
                                            Host name of this machine [FastPC]: нажать enter
                                            creating conf/iobroker.json
                                            27
                                            9267
