    4. Error bei History mit InfluxDB
      Nachdem mir gestern ein netter Mensch geholfen hat die InfluxDB zu installieren, habe ich heute einige Datenpunkte begonnen in ioBroker mit der influxDB zu loggen.
      Jetzt bekomme ich folgende Fehlermeldungen:
      influxdb-0	2016-04-24 11:24:00	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:23:00	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:21:59	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:20:59	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:19:58	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:18:57	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:17:57	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:16:56	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:15:56	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:14:55	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:14:55	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.cpu.load5\" is type string, already exists as type float"}
      influxdb-0	2016-04-24 11:13:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:12:57	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
      influxdb-0	2016-04-24 11:12:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.temperature.soc_temp\" is type string, already exists as type float"}
      influxdb-0	2016-04-24 11:12:54	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:12:43	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
      influxdb-0	2016-04-24 11:12:12	error	Error: unsupported max iterator type: *influxql.stringInterruptIterator
      influxdb-0	2016-04-24 11:12:00	error	Error: unsupported mean iterator type: *influxql.stringInterruptIterator
      influxdb-0	2016-04-24 11:11:53	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      influxdb-0	2016-04-24 11:10:53	warn	Error: {"error":"field type conflict: input field \"value\" on measurement \"rpi.0.memory.memory_available\" is type float64, already exists as type string"}
      PS mir ist aufgefallen, dass Flot mehrere X-Achsen anlegt, kann man das synchronisieren?
