    4. [Fehlermeldung] npm install iobroker.js-controller –production --prefix "/opt/iobroker" (System call)
    • derAuge
      derAuge last edited by
      beim aktualisieren des controlers über das WebInterface kommt folgende Fehlermaldung:
      iobroker	2016-04-24 18:34:15	info	exit 1
      iobroker	2016-04-24 18:34:15	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      iobroker	2016-04-24 18:34:15	error	at ChildProcess.emit (events.js:172:7)
      iobroker	2016-04-24 18:34:15	error	at emitTwo (events.js:87:13)
      iobroker	2016-04-24 18:34:15	error	at ChildProcess. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:263:31)
      iobroker	2016-04-24 18:34:15	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:212:29
      iobroker	2016-04-24 18:34:15	error	at restartController (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2091:18)
      iobroker	2016-04-24 18:34:15	error	at Object.fs.openSync (fs.js:549:18)
      iobroker	2016-04-24 18:34:15	error	at Error (native)
      iobroker	2016-04-24 18:34:15	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/../log/restart.log'
      iobroker	2016-04-24 18:34:15	error	^
      iobroker	2016-04-24 18:34:15	error	fs.js:549 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      iobroker	2016-04-24 18:34:15	info	Chmod finished. Restart controller
      node-red-0	2016-04-24 18:34:11	info	Save /opt/iobroker/iobroker-data/node-red/flows.json
      iobroker	2016-04-24 18:34:11	info	Execute: chmod 777 -R /opt/iobroker
      iobroker	2016-04-24 18:34:11	info	Host "RPi2-2" (linux) updated
      javascript-0	2016-04-24 18:34:09	info	script.js.DS18B20_Werte_abfragen: Sensoren wurden ausgelesen
      iobroker	2016-04-24 18:33:35	info	WARN deprecated graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
      iobroker	2016-04-24 18:33:35	info	npm
      iobroker	2016-04-24 18:33:32	info	WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
      iobroker	2016-04-24 18:33:32	info	npm
      javascript-0	2016-04-24 18:33:09	info	script.js.DS18B20_Werte_abfragen: Sensoren wurden ausgelesen
      iobroker	2016-04-24 18:33:06	info	npm install iobroker.js-controller --production --prefix "/opt/iobroker" (System call)
      iobroker	2016-04-24 18:33:04	info	upgrade self
      Nach reboot ist die neue Version aktiv
      Jürgen
        ist es das hier?:
        http://forum.iobroker.net/viewtopic.php … 725#p24361
        Bluefox weiß darüber bescheid
        81.0k
