    2. English
    3. ioBroker general
    4. Z-Wave does not work after reboot
      ap2017 last edited by Negalein
      I had fully working Z-Wave adapter on X64 Intel Platform with 12 nodes. After reboot, z-wave adapter is no longer working, continuously trying to start, but having the following ,messages:
      host.ap-OptiPlex-390	2019-07-27 21:10:47.661	error	instance system.adapter.zwave.0 terminated with code null ()
      host.ap-OptiPlex-390	2019-07-27 21:10:47.661	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
      zwave.0	2019-07-27 21:10:22.134	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
      host.ap-OptiPlex-390	2019-07-27 21:10:21.849	info	instance system.adapter.zwave.0 started with pid 8008
      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	info	Restart adapter system.adapter.zwave.0 because enabled
      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	error	instance system.adapter.zwave.0 terminated with code null ()
      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
      zwave.0	2019-07-27 21:09:26.319	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
      host.ap-OptiPlex-390	2019-07-27 21:09:26.029	info	instance system.adapter.zwave.0 started with pid 6542
      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	info	Restart adapter system.adapter.zwave.0 because enabled
      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	error	instance system.adapter.zwave.0 terminated with code null ()
      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
      zwave.0	2019-07-27 21:08:30.506	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
      host.ap-OptiPlex-390	2019-07-27 21:08:30.218	info	instance system.adapter.zwave.0 started with pid 5091
      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	info	Restart adapter system.adapter.zwave.0 because enabled
      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	error	instance system.adapter.zwave.0 terminated with code null ()
      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
      I also noticed that it does not show COM port that I previously used. After some struggle I was able to save COM configuration /dev/ttyACM0 but adapter still does not work
      I found this discussion, but don't see there a clean solution.
      https://github.com/ioBroker/ioBroker.zwave/issues/43
      bergjet created this issue in ioBroker/ioBroker.zwave
      closed Install Problem #43
        which system .. windows or linux ??
        AlCalzone A 2 Replies Last reply Reply Quote 0
        • AlCalzone
          AlCalzone Developer @arteck last edited by
          @arteck Pretty sure /opt/iobroker and /dev/ttyACM0 means Linux 😉
            arteck Developer Most Active @AlCalzone last edited by arteck
            @AlCalzone i know but look
            "I also noticed that it does not show COM port that I previously used"
            COM = windows
            the combobox has USB Device Name as title
            but you're right /opt/iobroker/ is for linux
              ap2017 @arteck last edited by
              @arteck Linux
                more infos plz
                adapter -> debug option -> log ??
                  Connecting Z-Wave USB stick to a different USB port solved the problem. System accepted port as /dev/ttyACM0 and I am able to see all my Z-Wave devices. I am afraid to reboot, but eventually will have to do it to troubleshoot another ongoing trouble with ASTRO Blockly function.
                    Continue to struggle with same issue - after reboot Z-Wave does not work, see log. I am running 64bit Intel platform with all latest modules (ioBroker, Node, ZWave adapter. Please help
                    ZWave 8-17-19.txt
                    • AlCalzone
                      AlCalzone Developer @ap2017 last edited by
                      @ap2017 sagte in Z-Wave does not work after reboot:
                      libopenzwave.so.1.6: cannot open shared object file: No such file or directory
                      Did you follow the instructions under known issues?
                        ap2017 @AlCalzone last edited by
                        @AlCalzone Sorry, forgot about this fix, I though that in new version of Z-Wave adapter 1.5.1 this issue is fixed, but I guess this is not an adapter issue.
                        The "sudo ldconfig /usr/local/lib64" worked and fixed the issue. Thank you!
                          Anthon1y @ap2017 last edited by Anthon1y
                          I'm also having the same problem as the others!
                            Homoran Global Moderator Administrators @Anthon1y last edited by
                            @Anthon1y sagte in Z-Wave does not work after reboot:
                            please specify!
                            1.0k
                            z wave z-wave
                            989
