    4. JS-Controller Update IOBroker läuft nicht mehr
      Againstyou last edited by Againstyou
      nachdem ich keine Adapter mehr updaten konnte, habe ich ein Update auf JS-Controller 1.5.14 gemacht. Seit dem läuft IOBroker nicht mehr sauber. Das Verzeichnis
       "/opt/iobroker/node_modules/iobroker.js-controller"
      fehlt komplett. Auch nachinstallieren funktioniert nicht.
      "sudo npm install iobroker.js-controller --production"
      gibt mir:
      > iobroker.js-controller@1.5.14 preinstall /home/pi/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.4.1
      npm version >= 5: disabling package-lock
      > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      fs.js:646
       return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES: permission denied, open './stdout.log'
         at Object.fs.openSync (fs.js:646:18)
         at Object.fs.writeFileSync (fs.js:1299:33)
         at Object.<anonymous> (/home/pi/node_modules/ursa-optional/rebuild.js:13:10)
         at Module._compile (module.js:653:30)
         at Object.Module._extensions..js (module.js:664:10)
         at Module.load (module.js:566:32)
         at tryModuleLoad (module.js:506:12)
         at Function.Module._load (module.js:498:3)
         at Function.Module.runMain (module.js:694:10)
         at startup (bootstrap_node.js:204:16)
      > diskusage@1.1.3 install /home/pi/node_modules/diskusage
      > node-gyp rebuild
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.16.0"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/pi/node_modules/diskusage/.node-gyp"
      gyp WARN install got an error, rolling back install
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/home/pi/node_modules/diskusage/.node-gyp'
      gyp ERR! System Linux 4.19.57-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /home/pi/node_modules/diskusage
      gyp ERR! node -v v8.16.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > iobroker.js-controller@1.5.14 install /home/pi/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
      fs.js:885
       return binding.mkdir(pathModule._makeLong(path),
      Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../tmp'
         at Object.fs.mkdirSync (fs.js:885:18)
         at Setup.setup (/home/pi/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:189:58)
         at /home/pi/node_modules/iobroker.js-controller/lib/setup.js:653:27
         at processCommand (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:691:15)
         at Object.module.exports.execute (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:3193:5)
         at Object.<anonymous> (/home/pi/node_modules/iobroker.js-controller/iobroker.js:1:100)
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules/diskusage):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.5.14 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.5.14 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-07-30T08_18_16_443Z-debug.log
      Hab schon im Forum gelesen, aber bisher hat nichts geholfen. 😞 Hat jemand ne Idee?
      Vielen Dank schonmal!
      • Stabilostick
        Stabilostick last edited by
        [Stabilostick, 30.07.2019, Thema ist kein Problem mit Scripting. Deshalb verschoben nach Error/Bug.]
        • sigi234
          https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
          • AlCalzone
            AlCalzone Developer @Againstyou last edited by
            @Againstyou sagte in JS-Controller Update IOBroker läuft nicht mehr:
            sudo npm install
            Und bevor du das nochmal machst, lese bitte
            https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
            javascript
