    4. GELÖST: Kein HTTPS nach Wiederherstellung
    SOLVED GELÖST: Kein HTTPS nach Wiederherstellung
    • Mauflo
      Mauflo last edited by Mauflo
      Ich bin ein bisserl am Verzweifeln: Ich hab einen neues sauberes IoBroker Image installiert, danach meine Wiederherstellung mit BackItUp installiert. hat soweit alles geklappt. Nur meine SSL Instanz will nicht mehr starten. Ich bekomme folgende Fehlermeldung im LOG:
      host.ioBroker	2019-08-03 00:20:39.089	error	instance system.adapter.web.0 terminated with code 0 (OK)
      Caught	2019-08-03 00:20:39.089	error	by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2019-08-03 00:20:39.089	error	by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-08-03 00:20:39.089	error	by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2019-08-03 00:20:39.088	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:725:21)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at adapter.getCertificates (/opt/iobroker/node_modules/iobroker.web/main.js:239:29)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:847:28)
      Caught	2019-08-03 00:20:39.087	error	by controller[0]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:81:34)
      Caught	2019-08-03 00:20:39.086	error	by controller[0]: at Object.createSecureContext (_tls_common.js:104:17)
      Caught	2019-08-03 00:20:39.086	error	by controller[0]: Error: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
      Kann mir da jemand weiterhelfen?
      Danke!
      Hat sich mittlerweile erledigt. Eine saubere Wiederherstellung geht nur mit Minimal Backups, da dann die Adapter neu installiert werden und daher mit dem neuen System kompatibel sind. Wenn man eine "total"-Wiederherstellungsdatei verwendet, werden offenbar nur die Ordner kopiert. Damit werden aber notwendige Änderungen in den configs offenbar ignoriert. Dann kommt es bei verschiedenen Adaptern zu seltsamen Störungen. Meine Empfehlung daher immer mit einer minimal-Wiederherstellungsdatei arbeiten. Dauert zwar länger - aber spart im Endeffekt Zeit! 😉
      https lets encrypt
