    5. [Gelöst] Javascript Adapter Update Fehler
    • Bluelinux
      Bluelinux last edited by Bluelinux
      Halli Hallo... Kann mir jemand sagen wieso ich den Javascript Adapter Updaten kann?? Aktuelle Version die ich auf meinem Debian System ist 4.1.13 und bekomme ihn nicht auf 4.1.14... Anbei die Meldung..
      Danke für eure Hilfe
      npm
      ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      npm ERR! code EACCESnpm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
      npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path:
      npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     /home/iobroker/.npm/_logs/2019-08-03T13_48_05_940Z-debug.log
      ERROR: host.ioBroker-Debian Cannot install iobroker.javascript@4.1.14: 243
      ERROR: process exited with code 25
      crunchip Issi 2 Replies Last reply Reply Quote 0
      • crunchip
        crunchip Forum Testing Most Active @Bluelinux last edited by
        @Bluelinux Benutzer keine Berechtigung
        • Issi
          Issi Developer @Bluelinux last edited by
          @Bluelinux einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash - dann sollte es wieder gehen
          Bluelinux 1 Reply Last reply Reply Quote 0
          • Bluelinux
            Bluelinux @Issi last edited by
            @Issi dankeschön jetzt funktioniert wieder alles... tip top...
