    4. Error: Maximum call stack size exceeded
    SOLVED Error: Maximum call stack size exceeded
      simpixo last edited by simpixo
      Seit neuestem erhalte ich eine Menge an Fehlern, kann mir jemand sagen woran das liegen könnte?
      2019-08-04 23:06:02.283 - error: Caught by controller[0]: RangeError: Maximum call stack size exceeded
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      2019-08-04 23:06:02.284 - error: Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
      Kompletter Auszug...
      error.txt
      Davor habe ich nur das OS upgedated, dabei wurde Node.js von v10.16.0 auf v10.16.1 upgedated.
      Über jegliche Hilfe würde ich mich freuen, danke!
      Hier ein paar Infos zu meinem System
      Architektur: x64
      CPUs: 4
      Geschwindigkeit; 2400 MHz
      Modell: Intel(R) Atom(TM) CPU C2758 @ 2.40GHz
      RAM: 31.39 GB
      System Betriebszeit: 28 T. 12:27:17
      Node.js: v10.16.1
      NPM: 6.9.0
      Festplatte Größe: 14.7 GB
      Festplatte frei: 8.98 GB
      Anzahl der Adapter: 284
      Betriebszeit: 00:28:12
      Aktive Instanzen: 33
        der socketio ist es..
        @simpixo installiere mal die neue version vom GIT von dem socket.io Adapter
        • Jey Cee
          Jey Cee Developer @simpixo last edited by
          @simpixo hast du das log gefiltert? Ich hab jetzt beim überfliegen nur die controller Meldung gesehen, daraus geht nicht hervor welcher Adapter das Auslöst.
              Hab jetzt den Socket.io aus dem GIT upgedated, ioBroker rebootet, jetzt kommt der Fehler nicht mehr.
              Was mich verwundert ist das meine installierte Version genau die gleiche war die ich aus dem GIT installiert habe.
              Vielen dank für die schnelle Hilfe
              error
