    4. [erledigt] Adapter startet obwohl deaktiviert (adapter.weatherunderground.0)
    • derAuge
      derAuge last edited by
      Habe adapter.weatherunderground.0 installiert
      Nach der Installation ist er sofort aktiv. (ist das so gewollt?)
      Habe den Adapter dann deaktiviert. Trotzdem wird versucht ihn zu starten
      2016-05-03 15:00:00.703  - info: host.RPi3-1 instance system.adapter.weatherunderground.0 started with pid 26288
      2016-05-03 15:00:04.299  - error: adapter disabled
      2016-05-03 15:00:05.364  - error: host.RPi3-1 instance system.adapter.weatherunderground.0 terminated with code 3 (Adapter disabled or invalid config)
      2016-05-03 15:45:00.699  - info: host.RPi3-1 instance system.adapter.weatherunderground.0 started with pid 28472
      2016-05-03 15:45:04.636  - error: adapter disabled
      2016-05-03 15:45:05.719  - error: host.RPi3-1 instance system.adapter.weatherunderground.0 terminated with code 3 (Adapter disabled or invalid config)
      Jürgen
      • derAuge
        heute wollte ich das Update auf 0.0.5 durchführen
        Adapter war nicht aktiv
        im LOG kam Fehlermeldung.
        iobroker	2016-05-04 08:10:48	info	npm ERR! syscall rename
        iobroker	2016-05-04 08:10:48	info	code ENOENTnpm ERR! errno -2
        iobroker	2016-05-04 08:10:49	info	exit 25
        iobroker	2016-05-04 08:10:49	info	Cannot install iobroker.weatherunderground: 254
        iobroker	2016-05-04 08:10:49	info	npm ERR! /npm-debug.log
        iobroker	2016-05-04 08:10:49	info	npm ERR! Please include the following file with any support request:
        iobroker	2016-05-04 08:10:48	info	npm ERR! enoent
        iobroker	2016-05-04 08:10:48	info	ERR! enoent This is most likely not a problem with npm itselfnpm ERR! enoent and is related to npm not being able to find a file.
        iobroker	2016-05-04 08:10:48	info	ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.staging/iobroker.weatherunderground-99ce02da' -> '/opt/iobroker/node_modul
        iobroker	2016-05-04 08:10:48	info	npm ERR! path /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.staging/iobroker.weatherunderground-99ce02da
        iobroker	2016-05-04 08:10:48	info	npm ERR! node v4.4.3npm ERR! npm v3.8.8
        iobroker	2016-05-04 08:10:48	info	"/usr/bin/nodejs" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.weatherunderground"
        iobroker	2016-05-04 08:10:48	info	npm ERR! argv
        iobroker	2016-05-04 08:10:48	info	npm ERR! Linux 4.1.19-v7+
        iobroker	2016-05-04 08:09:48	info	npm WARN iobroker No README datanpm WARN iobroker No license field.
        iobroker	2016-05-04 08:09:49	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.weatherunderground" (System call)
        iobroker	2016-05-04 08:09:48	info	npm WARN iobroker No repository field.
        iobroker	2016-05-04 08:09:48	info	WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'npm WARN iobroker No description
        iobroker	2016-05-04 08:06:56	info	npm install iobroker.weatherunderground --production --prefix "/opt/iobroker" (System call)
        iobroker	2016-05-04 08:06:53	info	upgrade weatherunderground
        Beim zweiten versuch ist der Adapter gelöscht
        iobroker	2016-05-04 09:47:58	info	exit 0
        iobroker	2016-05-04 09:47:58	info	Adapter "weatherunderground" is not installed.
        iobroker	2016-05-04 09:47:55	info	upgrade weatherunderground
        Jürgen
          @derAuge:
          Jürgen `
          Danke fürs Fehlermeldung. Problem gefunden.
          Mit dem Update kann ich nicht reproduzieren.
