    4. Javascript-Adapter formatDate() erzeugt Fehler
    SOLVED Javascript-Adapter formatDate() erzeugt Fehler
    • ruhr70
      ruhr70 last edited by Jey Cee
      TypeError:	06 07:46:36.849	error	at Adapter.formatDate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1661:28)
      TypeError:	06 07:46:36.849	error	isDuration.toLowerCase is not a function
      uncaught	06 07:46:36.846	error	exception: isDuration.toLowerCase is not a function
      Fehlermeldung komplett:
      host-ubuntu-1604-dev	06 07:46:36.865	error	instance system.adapter.javascript.1 terminated with code 0 (OK)
      TypeError:	06 07:46:36.849	error	at process._tickCallback (node.js:356:17)
      TypeError:	06 07:46:36.849	error	at nextTickCallbackWith2Args (node.js:442:9)
      TypeError:	06 07:46:36.849	error	at endReadableNT (_stream_readable.js:913:12)
      TypeError:	06 07:46:36.849	error	at IncomingMessage.emit (events.js:166:7)
      TypeError:	06 07:46:36.849	error	at emitNone (events.js:72:20)
      TypeError:	06 07:46:36.849	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:988:12)
      TypeError:	06 07:46:36.849	error	at Request.emit (events.js:169:7)
      TypeError:	06 07:46:36.849	error	at emitOne (events.js:82:20)
      TypeError:	06 07:46:36.849	error	at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1067:10)
      TypeError:	06 07:46:36.849	error	at Request.emit (events.js:172:7)
      TypeError:	06 07:46:36.849	error	at emitTwo (events.js:87:13)
      TypeError:	06 07:46:36.849	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:200:22)
      TypeError:	06 07:46:36.849	error	at Request._callback (script.js.common.WIFFI:31:13)
      TypeError:	06 07:46:36.849	error	at script.js.common.WIFFI:122:13
      TypeError:	06 07:46:36.849	error	at createDpFromJson (script.js.common.WIFFI:110:42)
      TypeError:	06 07:46:36.849	error	at timeLastData (script.js.common.WIFFI:13:12)
      TypeError:	06 07:46:36.849	error	at sandbox.formatDate (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1759:32)
      Skript:
      var request = require("request");
      var pfad    = "WIFFI" + ".Arbeitszimmer.";
      var url     = 'http://172.16.130.195/?json:';
      // TODO:
       function timeLastData() {
          return formatDate(new Date(), "DD.MM, hh:mm:ss");
       function parseJson(text) {
          if (text === "") return {};
          try {
              json = JSON.parse(text);
          } catch (ex) {
              json = {};
          if(!json) json = {};
          return json;
       function readJson(url, callback) {
          request(url, function (err, state, body){
              if (body) {
                  var json = parseJson(body);
                  callback(null, json);
              } else {
                  var error = "(" + err + ") ERROR bei Abfrage von: " + url;
                  log(error, "warn");
                  callback(error, null);
       function readVars() {
          readJson(url, function(err,json) {
              if(!err) {
                  var myJson = json;
                  var dPname, init;
                  var anzahlVars = myJson.vars.length;
                  for (var i = 1; i < anzahlVars; i++) {
                      dPname = pfad + myJson.vars[i].homematic_name;
                      init = myJson.vars[i].value;
                      setState(dPname, init);
                  for (var systeminfo in myJson.Systeminfo) {
                      dPname = pfad + "Systeminfo." + systeminfo;
                      init = myJson.Systeminfo[systeminfo];
                  setState(pfad + "LetzteAbfrage",timeLastData());
                  var statusNe = getState(pfad + "Last_State_Count").val;
                  if (statusNe < 0) {
                      setState(pfad + "Last_State_Count",0);
                  } else {
                      setState(pfad + "Last_State_Count",statusNe + 1);
                  log("WIFFI Daten aktualisiert: " + url,"debug");
              } else {
                  log("Fehler beim Auslesen des JSON. Keine Daten erhalten.","warn");
                  if (statusNe > 0) {
                  } else {
                      setState(pfad + "Last_State_Count",statusNe - 1);
       function createDpFromJson(myJson) {
          var dpname = "";
          var name = "";
          var forceCreation = true;
          var common;
          var init;
          var type, desc, unit;
              type = myJson.vars[i].type;
              desc = myJson.vars[i].desc;
              name = desc;
              unit = myJson.vars[i].unit.replace('grad','°');
              common = '{"desc":"' + desc + '","type":"' + type + '","unit":"' + unit + '","role":"value"' +',"name":"' + name + '"}';
              common = JSON.parse(common);
              createState(dPname, init , forceCreation, common);
              //createState(dPname, init);
              log("neuer Datenpunkt: " + dPname + ": " + init +", common: " + common,"debug");
              common = '{"name":"'+systeminfo+'","desc":"'+systeminfo+'","role":"value"}';
              log("neuer Datenpunkt: " + dPname + ": " + init +", common: " + common,"info");
          createState(pfad + "System.Modultyp",myJson.modultyp);
          createState(pfad + "System.url",url.replace("json:","xpert:0:"));
          createState(pfad + "Last_State_Count",0,true);
          createState(pfad + "LetzteAbfrage"  ,timeLastData());
          createState(pfad + "Skriptstart"    ,timeLastData()),true;
          createState(pfad + "Control_GetData",false,true,        {"name":"Daten mit true manuell abrufen","type":"boolean","role":"value"});
          log("Datenpunkte für WIFI in "+ pfad +" angelegt.");
       function createDp() {
          readJson(url, function (err,json) {
              if(!err) {
                  var myJson = json;
                  createDpFromJson(myJson);
                  log("WIFFI Datenpunkte angelegt/aktualisiert");
              } else {
                  log("Fehler beim Auslesen des JSON. Keine Daten erhalten.","error");
                  log("Keine Datenpunkte angelegt. Skript beendet","error");
                  return;
       function createOn() {
          var dpId = "javascript." + instance + "." + pfad + "Control_GetData";
          on({id: dpId ,change:'any'}, function (obj) {
              log(obj.state.val,"warn");
              if(obj.state.val) {
                  readVars();
           schedule("*/1 * * * *", function () { // jede Minute die Werte abfragen
              readVars();
       function main() {
          readVars();
       // Skriptstart
       createDp();
      setTimeout(createOn,    3000);
      setTimeout(main,        3000);
        Ist das das Gleiche, nach dem ich http://forum.iobroker.net/viewtopic.php?f=36&t=2789#p25195 schon gefragt habe??
        Dann liegt es diesmal ausnahmsweise nicht an meinem Unwissen?
        • ruhr70
          ja. sieht nach dem gleichen Thema aus.
            pix last edited by
            habe das auch schon festgestellt und deshalb in einige meiner Skripte workarounds eingebaut.
            Pix
              @ruhr70:
              Skript:
              `var request = require("request");
              >! var pfad    = "WIFFI" + ".Arbeitszimmer.";
              >! // TODO:
              >! function timeLastData() {
              >! function parseJson(text) {
                  try {
                  } catch (ex) {
                      json = {};
                  return json;
              >! function readJson(url, callback) {
                      if (body) {
                      } else {
                          log(error, "warn");
              >! function readVars() {
                      if(!err) {
                          var myJson = json;
                          var dPname, init;
                          if (statusNe < 0) {
                          } else {
                      } else {
                          if (statusNe > 0) {
                          } else {
              >! function createDpFromJson(myJson) {
                  var dpname = "";
                  var name = "";
                  var common;
                  var init;
                      name = desc;
              >! function createDp() {
                      if(!err) {
                          var myJson = json;
                      } else {
                          return;
              >! function createOn() {
                      if(obj.state.val) {
                          readVars();
              >!     schedule("*/1 * * * *", function () { // jede Minute die Werte abfragen
                      readVars();
              >! function main() {
                  readVars();
              >! // Skriptstart
              >! createDp();
              setTimeout(main,        3000);`
              Sollte am Git gefixt sein. Danke fürs Melden.[/i][/i][/i][/i][/i][/i][/i]
              • ruhr70
                @Bluefox:
                Sollte am Git gefixt sein. Danke fürs Melden. `
                Jetzt muss ich wieder blöd nachfragen… :oops:
                Der Javascript Adapter ist auf Git immer noch der 2.0.6.
                Was muss ich denn aktualisieren?
                  paul53 last edited by
                  @ruhr70:
                  Was muss ich denn aktualisieren? `
                    und anschließend
                    sudo chmod 777 * -R
                    nicht vergessen, sonst hagelt es Schimpfe!
                    EDIT: Seltsam, ./iobroker restart startet iobroker - dann Error2 cannot start, aber ioBroker läuft?
                    • ruhr70
                      @ruhr70:
                      • im Admin/Adapter werden nur die installierten Adapter angezeigt (ggf. wg. meiner Vorgehensweise oben) `
                      Sind wieder von alleine da.
                      • ruhr70
                        @Homoran:
                        und anschließend
                        sudo chmod 777 * -R
                        Rainer `
                        zu spät gesehen.
                        Hab Schimpfe verdient.
                        Lief auch ohne :oops:
                        habe ich nachträglich ausgeführt
                        javascript
                        1899
