    5. [gelöst]js-typeof-befehl - was ist falsch daran?
    • liv-in-sky
      liv-in-sky last edited by liv-in-sky
      hätte frage zm typeof befehl
      warum wird dieser datenpunkt nicht als type string erkannt?
      if(typeof val1 === "string" && !val1.includes('span') && !val1.includes('class')) ...
      wenn ich den inhalt in z.b aaa ändere funktioniert es!?
      mein datenpunkt:
      der inhalt (html-code):
      <table><tr><td  class="getprocessswap1" >9192kB&emsp;&emsp;</td><td>/usr/bin/node</td></tr><tr><td  class="getprocessswap1" >5088kB&emsp;&emsp;</td><td>/usr/bin/node</td></tr><tr><td  class="getprocessswap1" >2912kB&emsp;&emsp;</td><td>/usr/sbin/nmbd</td></tr><tr><td  class="getprocessswap1" >2061kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1863kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1829kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1805kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1688kB&emsp;&emsp;</td><td>/sbin/dhclient</td></tr><tr><td  class="getprocessswap1" >1304kB&emsp;&emsp;</td><td>/usr/sbin/sshd</td></tr><tr><td  class="getprocessswap1" >1285kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1267kB&emsp;&emsp;</td><td>/usr/sbin/smbd</td></tr><tr><td  class="getprocessswap1" >1216kB&emsp;&emsp;</td><td>/lib/systemd/systemd</td></tr><tr><td  class="getprocessswap1" >1120kB&emsp;&emsp;</td><td>/usr/bin/redis-server</td></tr><tr><td  class="getprocessswap1" >724kB&emsp;&emsp;</td><td>/lib/systemd/systemd-journald</td></tr><tr><td  class="getprocessswap1" >712kB&emsp;&emsp;</td><td>/lib/systemd/systemd-logind</td></tr><tr><td  class="getprocessswap1" >616kB&emsp;&emsp;</td><td>/usr/sbin/rsyslogd</td></tr><tr><td  class="getprocessswap1" >552kB&emsp;&emsp;</td><td>/usr/bin/dbus-daemon</td></tr><tr><td  class="getprocessswap1" >504kB&emsp;&emsp;</td><td>/usr/bin/node</td></tr><tr><td  class="getprocessswap1" >368kB&emsp;&emsp;</td><td>/usr/sbin/cron</td></tr><tr><td  class="getprocessswap1" >280kB&emsp;&emsp;</td><td>/sbin/agetty</td></tr><tr><td  class="getprocessswap1" >280kB&emsp;&emsp;</td><td>/sbin/agetty</td></tr><tr><td  class="getprocessswap1" >72kB&emsp;&emsp;</td><td>/usr/sbin/cron</td></tr><t/able>
      • AlCalzone
        AlCalzone Developer @liv-in-sky last edited by
        @liv-in-sky sagte in js-typeof-befehl - was ist falsch daran?:
        Wo ist val1 definiert? Woran machst du fest, dass der Datenpunkt kein String ist?
        • liv-in-sky
          liv-in-sky @AlCalzone last edited by liv-in-sky
          @AlCalzone weil ich es logge aber zum besseren verständnis der ganze teil (es handelt sich um ein geändertes script zu auslesen der redis states)
          var cacheSelectorState = $('state[state.id=javascript.0.*]');
          cacheSelectorState.each(function (id, i) {
              if (!id.includes('scriptEnabled') && !id.includes('scriptProblem') && !id.includes('Log-Script')  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS') ){
              var val1 = getState(id).val;
                 if (val1 == null )
                    {log(id + " hat keinen state");}
               else {var zk = "setState('"+id+"', "+val1 +");\n";
                     if(typeof val1 === "string" && !val1.includes('span') && !val1.includes('class')) {
                         zk = "setState('"+id+"', '"+val1+"');\n";
                         log(id + " -- " + val1 + " ----------- " + val1.includes('span'));
                         fs.appendFileSync(datei + logdate + "-"+ logtime + ".txt", zk);}
                     else {
                      log("KEIN STRING " +id + " -- " + val1);
          wie erwähnt - steht nur ein kleiner text drin wird es als string erkannt
          ich wollte gerne die html einträge nicht im ergebnis haben, deashalb versuche ich span und class zu finden und nicht zu schreiben
          • AlCalzone
            Das müsste eigentlich genau so funktionieren. Gebe doch mal für den State bei dem der Fehler (?) auftritt den Typ im Log aus:
            if (id === "dein-problematischer-state") {
                log(typeof val1);
            • liv-in-sky
              @AlCalzone habe es mal so versucht - jetzt scheint es zu gehen - habe abfragen getrennt
                  var cacheSelectorState = $('state[state.id=controll-own.0.*]');
                     if (val1 == null )
                        /* if(typeof val1 === "string" ) {*/
                             /*if( val1.indexOf('bespiel') == -1 && val1.indexOf('class') == -1) {                  && ! val1.includes('beispiel') && ! val1.includes('class') */
                             if( typeof val1 === "string") {
                             if (val1.includes('span') || val1.includes('class')) {log("------------------------------------------------------------- span oder classn enthalten "+ id);} else {
                             fs.appendFileSync(datei + "-controll-own0-" + logdate + "-"+ logtime + ".txt", zk);}}
                         else {
              irgendwie habe ich da was falsches gemacht?
              javascript
