    4. Kann VIS Adapter nicht installieren
    SOLVED Kann VIS Adapter nicht installieren
      PeterImNetz last edited by Negalein
      Ich hatte meinen VIS Adapter gelöscht und wollte den jetzt neu installieren.
      Nun kommt leider der Fehler "Done with error: host.raspberrypi Cannot install vis".
      Im ioBroker Log steht:
      iobroker	2019-08-29 18:14:10.631	error	host.raspberrypi Cannot install vis
      iobroker	2019-08-29 18:14:10.628	info	host.raspberrypi install adapter vis
      iobroker	2019-08-29 18:14:10.564	info	npm ERR! /home/iobroker/.npm/_logs/2019-08-29T16_14_09_731Z-debug.log
      iobroker	2019-08-29 18:14:10.564	info	npm ERR! A complete log of this run can be found in:
      iobroker	2019-08-29 18:14:09.730	info	npm ERR! File size (4398046515200) is greater than possible Buffer: 1073741823 bytes
      iobroker	2019-08-29 18:14:09.717	info	ERR! code ERR_FS_FILE_TOO_LARGE
      iobroker	2019-08-29 18:14:09.714	info	npm
      iobroker	2019-08-29 18:13:53.039	info	npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2019-08-29 18:13:53.037	info	NPM version: 6.10.2
      iobroker	2019-08-29 18:13:47.528	info	host.raspberrypi install adapter vis
      iobroker	2019-08-29 18:13:47.469	info	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-08-29T16_13_47_039Z-debug.log
      iobroker	2019-08-29 18:13:47.467	info
      **iobroker	2019-08-29 18:13:47.032	info	File size (4398046515200) is greater than possible Buffer: 1073741823 bytes**
      iobroker	2019-08-29 18:13:47.030	info	ERR!
      iobroker	2019-08-29 18:13:47.028	info	npm
      iobroker	2019-08-29 18:13:47.020	info	ERR_FS_FILE_TOO_LARGE
      iobroker	2019-08-29 18:13:47.018	info	ERR! code
      iobroker	2019-08-29 18:13:47.017	info
      iobroker	2019-08-29 18:13:47.012	info	npm
      iobroker	2019-08-29 18:13:30.327	info	npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2019-08-29 18:13:30.325	info	NPM version: 6.10.2
      iobroker	2019-08-29 18:13:25.011	info	host.raspberrypi install adapter vis
      iobroker	2019-08-29 18:13:24.912	info	npm ERR! /home/iobroker/.npm/_logs/2019-08-29T16_13_24_880Z-debug.log
      iobroker	2019-08-29 18:13:24.912	info	npm ERR! A complete log of this run can be found in:
      iobroker	2019-08-29 18:13:24.874	info	npm ERR! File size (4398046515200) is greater than possible Buffer: 1073741823 bytes
      iobroker	2019-08-29 18:13:24.868	info	npm ERR! code ERR_FS_FILE_TOO_LARGE
      iobroker	2019-08-29 18:12:58.101	info	npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2019-08-29 18:12:53.634	info	NPM version: 6.10.2
      iobroker	2019-08-29 18:12:43.271	info	add vis --host raspberrypi
      Das Logfile 2019-08-29T16_13_24_880Z-debug.log füge ich anbei.
      Platz habe ich auf der SDKarte noch reichlich:
      pi@raspberrypi:~ $ df
      Filesystem                        1K-blocks      Used Available Use% Mounted on
      /dev/root                          29934552   7506168  21133420  27% /
      devtmpfs                             469544         0    469544   0% /dev
      tmpfs                                474152         0    474152   0% /dev/shm
      tmpfs                                474152     12352    461800   3% /run
      tmpfs                                  5120         4      5116   1% /run/lock
      tmpfs                                474152         0    474152   0% /sys/fs/cgroup
      /dev/mmcblk0p1                       258096     39975    218121  16% /boot
      tmpfs                                 94828         0     94828   0% /run/user/1000
      //192.168.178.20/backups_iobroker 961618816 660366328 301252488  69% /opt/iobroker/backups
      Ich meine die Zeile "info npm ERR! File size (4398046515200) is greater than possible Buffer: 1073741823 bytes"
      ist relativ klar, nur wieso ist das File so riesig?
      Hat jemand einen Tipp für mich??
      MOD-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      • Negalein
        This post is deleted!
          PeterImNetz @PeterImNetz last edited by
          Ich habe jetzt das ganze Verzeichnis /opt/iobroker aus einem Backup wiederhergestellt es läuft wieder.
          iobroker.vis
