    4. Gelöst: [Tester] kein Aufruf von http://RPi2-1:8081/#javascript möglich
    • derAuge
      derAuge last edited by
      2016-05-07 13:37:10.287  - info: host.RPi2-1 object change system.adapter.javascript.0
      2016-05-07 13:37:10.289  - info: host.RPi2-1 stopInstance system.adapter.javascript.0
      2016-05-07 13:37:10.290  - info: host.RPi2-1 stopInstance system.adapter.javascript.0 killing pid 775
      2016-05-07 13:37:10.351  - info: host.RPi2-1 instance system.adapter.javascript.0 terminated with code 0 (OK)
      2016-05-07 13:37:12.829  - info: host.RPi2-1 instance system.adapter.javascript.0 started with pid 1040
      2016-05-07 13:37:18.313  - info: javascript.0 starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.javascript
      2016-05-07 13:37:18.366  - info: javascript.0 requesting all states
      2016-05-07 13:37:18.375  - info: javascript.0 requesting all objects
      2016-05-07 13:37:18.848  - info: javascript.0 received all states
      2016-05-07 13:37:19.010  - info: javascript.0 received all objects
        @derAuge:
        Wenn du jetzt so was aufrufst:
        cd /opt/iobroker
        iobroker stop javascript
        node node_modules/iobroker.javascript/javascript.js --force --logs
        Da sollte es mehr Fehlermeldungen sein.
        • derAuge
          @Bluefox:
          Code: Alles auswählen
          cd /opt/iobroker
          node node_modules/iobroker.javascript/javascript.js –force --logs
          Da sollte es mehr Fehlermeldungen sein. `
          da startet leider garnichts.
          System neu gestartet
          ` > root@RPi2-1:/opt/iobroker# uname -a && node -v && nodejs -v && npm -v
          Linux RPi2-1 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
          v4.4.3
          v0.10.29
          2.15.1 `
          pi@RPi2-1:~ $ su
          Passwort:
          root@RPi2-1:/home/pi# cd /opt/iobroker/
          root@RPi2-1:/opt/iobroker# ps -A | grep " io.*"
          root@RPi2-1:/opt/iobroker# ./start.sh
          Starting iobroker controller daemon...
          iobroker controller daemon started. PID: 713
            713 ?        00:00:11 iobroker.js-con
            722 ?        00:00:11 io.admin.0
            727 ?        00:00:08 io.sql.0
            732 ?        00:00:07 io.web.0
            743 ?        00:00:05 io.history.0
          root@RPi2-1:/opt/iobroker# node node_modules/iobroker.javascript/javascript.js --force --logs
          • derAuge
            Lösung:
            über den Schalter Admin muss die Anzeige von "Skript" aktiviert werden. Danach geht es
            Jürgen
