    4. Iobroker startet nicht mehr
    • sissiwup
      sissiwup last edited by
      Starting iobroker controller daemon...
      /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
      Error: Error: Invalid syslog protocol: UDP
          at new exports.Syslog (/opt/iobroker/node_modules/winston-syslog/lib/winston-syslog.js:70:11)
          at logger (/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:99:45)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:67:51)
          at Module._compile (module.js:409:26)
          at Object.Module._extensions..js (module.js:416:10)
          at Module.load (module.js:343:32)
          at Function.Module._load (module.js:300:12)
          at Module.require (module.js:353:17)
          at require (internal/module.js:12:17)
          at init (/opt/iobroker/node_modules/daemonize2/lib/wrapper.js:105:17)
          at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
          at emitTwo (events.js:87:13)
          at ChildProcess.emit (events.js:172:7)
          at handleMessage (internal/child_process.js:695:10)
          at Pipe.channel.onread (internal/child_process.js:440:11)</anonymous></anonymous>
        @sissiwup:
        Wie sieht dein /opt/iobroker/iobroker-data/iobroker.json aus?
        • sissiwup
            "network": {
              "IPv4": true,
              "IPv6": true,
              "bindAddress": null,
              "useSystemNpm": true
            "objects": {
              "type": "file",
              "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
              "host": "127.0.0.1",
              "port": 9001,
              "user": "",
              "pass": "",
              "noFileCache": false
            "states": {
              "type": "file",
              "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
              "port": 9000,
              "options": {
                "auth_pass": null,
                "retry_max_delay": 15000
            "log": {
              "level": "info",
              "maxDays": 30,
              "transport": {
                "file1": {
                  "type": "file",
                  "enabled": true,
                  "filename": "log/iobroker",
                  "fileext": ".log",
                  "maxsize": null,
                  "maxFiles": null
                "syslog": {
                         "type": "syslog",
                         "enabled": true,
                         "host": "192.168.1.14",
                         "port": "514",
                         "protocol":  "UDP",
                         "path": ""
            "dataDirComment": "Always relative to iobroker.js-controller/",
            "dataDir": "../../iobroker-data/"
          • sissiwup
            soll das heissen, dass der Logger jetzt tut?
            Ich habe das loglevel bei yr.0 von info auf debug geändert. Danach ging nix mehr.
            Neustart iobroker. Fehler.
              @sissiwup:
              Neustart iobroker. Fehler. `
              Mach mal:
              "syslog": {
              "type": "syslog",
              "enabled": false,
              "port": "514",
              "protocol": "UDP",
              "path": ""
              • sissiwup
                lag wohl an den Versuchen den Logger zum laufen zu bekommen. Jetzt scheint er schon mehr zu tun.
                Hatte ja Zeile 10 auskommentiert und den winston Logger nachinstalliert.
                Habe die Module alle weggeworfen, danach ging es wieder.
                Danke.
                  @sissiwup:
                  Danke. `
                  Schade… Ich dachte syslog geht schon. Dann muss man mehr untersuchen :?
