    4. Was tut sich denn da?
      Ich habe durch Zufall als ich nach ruhr70s repo in Github suchte das folgende gefunden:
      https://github.com/foxthefox?tab=repositories
      Gibt es dazu schon irgendwelche infos?
      • eric2905
        eric2905 last edited by
        Sieht ja spannend aus 😄
        Gruß,
        Eric
        • derAuge
          derAuge last edited by
          JAu
          Jeelink
          da habe ich einen Clon und wollte schon fragen wie ich den in ioBroher abfragen kann
          • derAuge
            Habe mir den Adapter installiert
            https://github.com/foxthefox/ioBroker.j … /README.md
            Und , siehe da...
            es kommen Daten
            2016-05-09 08:51:57.411  - info: host.RPi3-1 object change system.adapter.jeelink.0
            2016-05-09 08:51:57.483  - info: host.RPi3-1 instance system.adapter.jeelink.0 started with pid 26969
            2016-05-09 08:52:00.213  - debug: jeelink.0 objectDB connected
            2016-05-09 08:52:00.257  - debug: jeelink.0 statesDB connected
            2016-05-09 08:52:00.429  - info: jeelink.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.jeelink
            2016-05-09 08:52:00.441  - info: jeelink.0 entered ready
            2016-05-09 08:52:00.457  - info: jeelink.0 RFM12B setting up object 19
            2016-05-09 08:52:00.461  - info: jeelink.0 RFM12B setting up object 21
            2016-05-09 08:52:00.465  - info: jeelink.0 RFM12B setting up object 22
            2016-05-09 08:52:00.506  - info: jeelink.0 open
            2016-05-09 08:52:00.539  - debug: inMem message  jeelink.0.* jeelink.0.testVariable val=true, ack=false, ts=1462776721, q=0, from=system.adapter.jeelink.0, lc=1462776721
            2016-05-09 08:52:00.550  - info: jeelink.0 stateChange jeelink.0.testVariable {"val":true,"ack":false,"ts":1462776721,"q":0,"from":"system.adapter.jeelink.0","lc":1462776721}
            2016-05-09 08:52:00.551  - info: jeelink.0 ack is not set!
            2016-05-09 08:52:00.594  - debug: inMem message  jeelink.0.* jeelink.0.testVariable val=true, ack=true, ts=1462776721, q=0, from=system.adapter.jeelink.0, lc=1462776721
            2016-05-09 08:52:00.597  - info: jeelink.0 stateChange jeelink.0.testVariable {"val":true,"ack":true,"ts":1462776721,"q":0,"from":"system.adapter.jeelink.0","lc":1462776721}
            2016-05-09 08:52:00.599  - debug: inMem message  jeelink.0.* jeelink.0.testVariable val=true, ack=true, ts=1462776721, q=0, from=system.adapter.jeelink.0, lc=1462776721
            2016-05-09 08:52:00.602  - info: jeelink.0 stateChange jeelink.0.testVariable {"val":true,"ack":true,"ts":1462776721,"q":0,"from":"system.adapter.jeelink.0","lc":1462776721}
            2016-05-09 08:52:02.529  - info: jeelink.0 data received:
            [LaCrosseITPlusReader.10.1q (RFM69 f:868300 r:17241)]
            2016-05-09 08:52:03.887  - info: jeelink.0 data received: OK 9 27 1 4 143 59
            2016-05-09 08:52:05.258  - info: jeelink.0 data received: OK 9 30 1 4 173 52
            2016-05-09 08:52:12.309  - info: jeelink.0 data received: OK 9 27 1 4 143 59
            2016-05-09 08:52:13.726  - info: jeelink.0 data received: OK 9 30 1 4 173 52
            2016-05-09 08:52:17.959  - info: jeelink.0 data received: OK 9 30 1 4 172 52
            2016-05-09 08:52:20.728  - info: jeelink.0 data received: OK 9 27 1 4 143 59
            2016-05-09 08:52:22.195  - info: jeelink.0 data received: OK 9 30 1 4 173 52
            2016-05-09 08:52:26.428  - info: jeelink.0 data received: OK 9 30 1 4 173 52
            2016-05-09 08:52:26.589  - debug: inMem message  jeelink.0.* jeelink.0.testVariable val=null, ack=true, ts=1462776747, q=0, from=system.adapter.jeelink.0, lc=1462776747
            2016-05-09 08:52:26.591  - info: jeelink.0 stateChange jeelink.0.testVariable {"val":null,"ack":true,"ts":1462776747,"q":0,"from":"system.adapter.jeelink.0","lc":1462776747}
            2016-05-09 08:52:26.618  - info: jeelink.0 cleaned everything up...
            2016-05-09 08:52:26.605  - info: host.RPi3-1 object change system.adapter.jeelink.0
            2016-05-09 08:52:26.611  - info: host.RPi3-1 stopInstance system.adapter.jeelink.0
            2016-05-09 08:52:26.612  - info: host.RPi3-1 stopInstance system.adapter.jeelink.0 killing pid 26969
            2016-05-09 08:52:26.635  - info: jeelink.0 terminating
            2016-05-09 08:52:26.681  - info: host.RPi3-1 instance system.adapter.jeelink.0 terminated with code 0 (OK)
            Habe mal einträge in
            nano node_modules/iobroker.jeelink/io-package.json
            gemacht.
            Bekomme aber noch nicht wirklich werte angezeigt / ausgelesen
            gibt es da auch noch unterschiede
            Mein JeeLink = [LaCrosseITPlusReader.10.1q (RFM69 f:868300 r:17241)]
            der Adapter versucht : jeelink.0 RFM12B setting up object 19
            RFM69 / RFM12B = das ist wohl der Unterschied
            siehe http://www.mikrocontroller.net/articles/RFM69
            Jürgen
