    4. Yahka Fehlermeldung
    UNSOLVED Yahka Fehlermeldung
    • Kusselin
      Kusselin last edited by Kusselin
      Hallo, ich habe auf einmal keien Verbindung mehr...kommt diese meldung...könnt ihr mir sagen was da los ist?
      Danke und Gruss
      yahka.0	2019-09-09 21:15:27.676	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      yahka.0	2019-09-09 21:15:27.676	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      yahka.0	2019-09-09 21:15:27.676	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      yahka.0	2019-09-09 21:15:27.676	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      yahka.0	2019-09-09 21:15:27.676	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      yahka.0	2019-09-09 21:15:27.676	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      yahka.0	2019-09-09 21:15:27.676	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      yahka.0	2019-09-09 21:15:27.676	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      yahka.0	2019-09-09 21:15:27.676	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
      yahka.0	2019-09-09 21:15:27.676	error	at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
      yahka.0	2019-09-09 21:15:27.676	error	TypeError: Cannot read property 'val' of null
      yahka.0	2019-09-09 21:15:27.674	error	uncaught exception: Cannot read property 'val' of null
      host.raspberrypi	2019-09-09 22:17:08.004	info	Restart adapter system.adapter.yahka.0 because enabled
      host.raspberrypi	2019-09-09 22:17:08.004	error	instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
      host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      host.raspberrypi	2019-09-09 22:17:08.003	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
      host.raspberrypi	2019-09-09 22:17:08.002	error	Caught by controller[0]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
      host.raspberrypi	2019-09-09 22:17:08.001	error	Caught by controller[0]: TypeError: Cannot read property 'val' of null
      host.raspberrypi	2019-09-09 22:17:08.000	error	Caught by controller[0]: Mon, 09 Sep 2019 20:17:06 GMT EventedHTTPServer Server listening on port 38545
      EDIT: mit Aktualisireung von npm läufts wieder!!!
      error im log
