    4. Fehler Tuya Update 3.0.0
    UNSOLVED Fehler Tuya Update 3.0.0
      akurria last edited by
      Bekomme leider das Update des Tuya Updates nicht hin. Vielleicht kann mir jemand ja helfen?
      > node-bluetooth@1.2.6 install /opt/iobroker/node_modules/node-bluetooth
      > node-gyp configure build
      make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird betrete        n
        CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPo        rt.o
        CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o
      ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden
           #include <bluetooth/bluetooth.h>
      compilation terminated.
      BluetoothSerialPort.target.mk:105: die Regel für Ziel „Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o“ scheiterte
      make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.14.98-v7+
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
      gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      In file included from ../node_modules/nan/nan.h:190:0,
                       from ../src/unix_dgram.cc:5:
      ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
      ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
         return obj->ForceSet(GetCurrentContext(), key, value, attribs);
      In file included from ../src/unix_dgram.cc:5:0:
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from ../node_modules/nan/nan.h:47:0,
      /root/.node-gyp/10.16.3/include/node/node.h:177:50: note: declared here
                       NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /root/.node-gyp/10.16.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
           __attribute__((deprecated(message))) declarator
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /root/.node-gyp/10.16.3/include/node/node.h:170:50: note: declared here
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, method, argc, argv);
      /root/.node-gyp/10.16.3/include/node/node.h:163:50: note: declared here
      ../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
      In file included from /root/.node-gyp/10.16.3/include/node/v8.h:26:0,
                       from /root/.node-gyp/10.16.3/include/node/node.h:63,
                       from ../node_modules/nan/nan.h:47,
      /root/.node-gyp/10.16.3/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /root/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[1]);
      /root/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /root/.node-gyp/10.16.3/include/node/node.h:63:0,
      /root/.node-gyp/10.16.3/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         offset = info[2]->Uint32Value();
      /root/.node-gyp/10.16.3/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      unix_dgram.target.mk:99: die Regel für Ziel „Release/obj.target/unix_dgram/src/unix_dgram.o“ scheiterte
      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! not ok
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@serialport/bindings/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/abbrev/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/needle/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/package.json'
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: `node-gyp configure build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      + iobroker.tuya@3.0.0
      added 10 packages from 13 contributors, removed 108 packages, updated 6 packages, moved 1 package and audited 4458 packages in 69.558s
      found 41 vulnerabilities (30 low, 11 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      root@raspberrypi:/opt/iobroker# npm audit
      npm ERR! code EAUDITNOLOCK
      npm ERR! audit Neither npm-shrinkwrap.json nor package-lock.json found: Cannot audit a project without a lockfile
      npm ERR! audit Try creating one first with: npm i --package-lock-only
      npm ERR!     /root/.npm/_logs/2019-09-09T20_49_38_766Z-debug.log
      • Glasfaser
        Glasfaser @akurria last edited by
        @akurria
        Lösung hier : Link Text
        errorproblem tuya adapter update error
