    4. [gelöst] HomeMatic ReGaHSS Update von ver. 0.3.7 auf 1.1.0 funktioniert nicht
      Schnutexxl last edited by
      Hallo Zusammen,
      wollte heute Morgen ein Update des HM ReGaHSS Adaper von er. 0.3.7 auf 1.1.0 durchführen, leider ohne Erfolg. Bei folgender Meldung bleibt das Update stehen:
      ` > http 200 https://registry.npmjs.org/hoek
      npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm http GET https://registry.npmjs.org/is-property
      npm http 304 https://registry.npmjs.org/is-property `
      Und folgende LOG Errors erscheinen:
      ` > iobroker 2016-05-14 05:57:56 info exit 25
      iobroker 2016-05-14 05:57:56 error host.ioBroker Cannot install iobroker.hm-rega: 137
      iobroker 2016-05-14 05:57:56 info Killed
      Error: 2016-05-14 05:57:56 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      Error: 2016-05-14 05:57:56 error at [object Object]._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:243:18)
      Error: 2016-05-14 05:57:56 error at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:296:8)
      Error: 2016-05-14 05:57:56 error at Request.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
      Error: 2016-05-14 05:57:56 error at Request. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:108:10)
      Error: 2016-05-14 05:57:56 error at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:62:13)
      Error: 2016-05-14 05:57:56 error xhr post error
      xhr 2016-05-14 05:57:56 error post error
      Error: 2016-05-14 05:57:56 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:243:18)
      xhr 2016-05-14 05:57:56 error post error `
      Wo liegt hier das Problem? Ist der nodejs auf der falschen Version, wenn ja wie update ich den, oder liegt es an was anderem?
      Danke schonmal.
      • Jey Cee
        Ja es liegt an deiner nodejs version. Du solltest auf 4.x.x updaten.
        Update: Alte nodejs version deinstallieren und dann die neue Version installieren.
        Einzelne schritte kann ich dir keine nennen, da es davon abhängt worauf ioBroker bei dir läuft.
        Ein Blick in die Installationsanleitung von iobroker auf der iobroker.de hilft sicher da ist die Installation für verschiedene Systeme beschrieben.
          looxer01 last edited by
          ich habe auch noch 0.10.22, weil es einfach stabil läuft.
          Die Warnungen konnten bisher ignoriert werden. Es gab nie Probleme.
          Kann jemand bestätigen, dass ab jetzt Node 0.10.22 nicht mehr läuft ?
          vG Looxer
            paul53 last edited by
            @looxer01:
            Kann jemand bestätigen, dass ab jetzt Node 0.10.22 nicht mehr läuft ? `
            Auf https://docs.npmjs.com/getting-started/installing-node wird Version > 0.10.32 gefordert.
              @looxer01:
              vG Looxer `
              Nein. 0.10.22 sollte gehen.
              Da war ein temporären Fehler. Man sollte mit
              cd /opt/iobroker
              npm install iobroker.hm-rega
              probieren.
                Trotz der Fehlermeldungen wird mir nun der Adapter mit der Version 1.1.0 in iobroker angezeigt. Scheint zu funktionieren. Habe aber keinen neuen Installationsversuch gemacht.
