    4. [Backitup] Fehler beim starten der Instanz
    UNSOLVED [Backitup] Fehler beim starten der Instanz
    • Lenny.CB
      Lenny.CB Most Active last edited by Lenny.CB
      kann mir das mal jemand "übersetzen"?
      Hintergrund: Instanz lässt sich nicht starten. Wollte dann "drüber installieren", bekomme dann diesen Fehler:
      root@rockpro64:/opt/iobroker# npm install iobroker.backitup -production
      > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      Traceback (most recent call last):
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
          import gyp
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in <module>
          import gyp.input
        File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
          from compiler.ast import Const
      ImportError: No module named compiler.ast
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.4.184-rockchip64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      prebuild-install WARN install No prebuilt binaries found (target=10.16.3 runtime=node arch=arm64 libc= platform=linux)
          import gyp
          import gyp.input
      gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
      gyp ERR! not ok
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/asn1/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/ecc-jsbn/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/safer-buffer/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/stack-trace/package.json'
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules/diskusage):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 (node_modules/@serialport/bindings):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
      + iobroker.backitup@1.2.0
      added 2 packages from 3 contributors, updated 1 package and audited 9735 packages in 51.449s
      found 189 vulnerabilities (81 low, 43 moderate, 65 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      backitup fehler
