    4. Gelöst:Installation vmware / Ubuntu Server 19
    SOLVED Gelöst:Installation vmware / Ubuntu Server 19
    • MarkusDe
      MarkusDe last edited by MarkusDe
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Hp DL360G8.
      Arbeitsspeicher: 96GB
      Festplattenart: SSD&HDD RAID
      Betriebssystem: Ubuntu 19 Server auf vmware
      Node-Version: 10.16.3
      Nodejs-Version: 10.16.3
      NPM-Version: 6.11.3
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: http://releases.ubuntu.com/19.04/ubuntu-19.04-live-server-amd64.iso
      Hallo Miteinander,
      hab bei der Installation unter Ubuntu 19 Server auf vmware meine Sorgen.
      Im Teil 3 der Installation von ioBroker kommt diese Fehlermeldung:
      In file included from ../src/main.cpp:3:
      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_                            work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      In file included from ../../nan/nan.h:54,
      ../src/main.cpp: At global scope:
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::O                            bject>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(diskusage, Init)
      In file included from /home/dadmin/.cache/node-gyp/10.16.3/include/node/node.h:63,
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInf                            o<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8:                            :WeakCallbackInfo<node::ObjectWrap>&)]’:
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node                            ::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<                            void>&)’} [-Wcast-function-type]
                      reinterpret_cast<Callback>(callback), type);
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInf                            o<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::                            WeakCallbackInfo<Nan::ObjectWrap>&)]’:
      ../../nan/nan_object_wrap.h:65:61:   required from here
      /home/dadmin/.cache/node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan:                            :ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<vo                            id>&)’} [-Wcast-function-type]
      darauf quittierte dann das Ubuntu mit folgender Aussage von vmware den Dienst:
      The CPU has been disabled by the guest operating system. Power off or reset the virtual machine.
      vorher hatte ich das Ganze unter debian 10 probiert..... da kam der Aufhänger mit gleicher Meldung erst beim Konfigurieren des ioBroker.
      Auf beiden Systemen :
      dadmin@iobroker:~$ nodejs -v
      v10.16.3
      dadmin@iobroker:~$ node -v
      v10.16.3
      dadmin@iobroker:~$ npm -v
      6.11.3
      Irgendeine Idee , was hier schief ist ? bin ich zu aktuell mit den Versionen ? 😉
      • MarkusDe
        Lösung gefunden:
        Punkt 1:
        Nodejs neuere Version mit originaler Installationsanleitung für Ubuntu installiert.
        # Using Ubuntu
        curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
        sudo apt-get install -y nodejs
        Punkt 2:
        Neuste Installation direkt von GitHub genommen:
        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/master/installer.sh | bash -
        so läuft es ohne Probleme mit dem aktuellen 19er Server Release von Ubuntu.
        • MarkusDe
          Lösung gefunden:
          Punkt 1:
          # Using Ubuntu
          Punkt 2:
          installationsfehler vmware
