    4. require("request") ergibt EHOSTUNREACH
    • etv
      etv last edited by
      Liebe Leute,
      mir ist heute im Log aufgefallen, dass dieser Fehler den Restart des Adapters auslöst...
      2019-09-17 12:26:15.764 - error: Caught by controller[0]: { Error: connect EHOSTUNREACH 192.168.68.220:50000
      2019-09-17 12:26:15.774 - error: Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
      2019-09-17 12:26:15.775 - error: Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
      2019-09-17 12:26:15.775 - error: Caught by controller[0]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1090:14)
      2019-09-17 12:26:15.775 - error: Caught by controller[0]: code: 'EHOSTUNREACH',
      2019-09-17 12:26:15.776 - error: Caught by controller[0]: errno: 'EHOSTUNREACH',
      2019-09-17 12:26:15.776 - error: Caught by controller[0]: syscall: 'connect',
      2019-09-17 12:26:15.776 - error: Caught by controller[0]: address: '192.168.68.220',
      2019-09-17 12:26:15.776 - error: Caught by controller[0]: port: 50000 }
      2019-09-17 12:26:15.776 - error: Caught by controller[1]: { Error: connect EHOSTUNREACH 192.168.68.220:50000
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: at Object.exports._errnoException (util.js:1020:11)
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1043:20)
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1090:14)
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: code: 'EHOSTUNREACH',
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: errno: 'EHOSTUNREACH',
      2019-09-17 12:26:15.777 - error: Caught by controller[1]: syscall: 'connect',
      2019-09-17 12:26:15.778 - error: Caught by controller[1]: address: '192.168.68.220',
      2019-09-17 12:26:15.778 - error: Caught by controller[1]: port: 50000 }
      2019-09-17 12:26:15.778 - error: Caught by controller[2]: { Error: socket hang up
      2019-09-17 12:26:15.778 - error: Caught by controller[2]: at createHangUpError (_http_client.js:254:15)
      2019-09-17 12:26:15.778 - error: Caught by controller[2]: at Socket.socketCloseListener (_http_client.js:286:23)
      2019-09-17 12:26:15.778 - error: Caught by controller[2]: at emitOne (events.js:101:20)
      2019-09-17 12:26:15.779 - error: Caught by controller[2]: at Socket.emit (events.js:188:7)
      2019-09-17 12:26:15.779 - error: Caught by controller[2]: at TCP._handle.close [as _onclose] (net.js:497:12)
      2019-09-17 12:26:15.779 - error: Caught by controller[2]: code: 'ECONNRESET' }
      2019-09-17 12:26:15.779 - error: Caught by controller[3]: { Error: socket hang up
      2019-09-17 12:26:15.779 - error: Caught by controller[3]: at createHangUpError (_http_client.js:254:15)
      2019-09-17 12:26:15.780 - error: Caught by controller[3]: at Socket.socketCloseListener (_http_client.js:286:23)
      2019-09-17 12:26:15.780 - error: Caught by controller[3]: at emitOne (events.js:101:20)
      2019-09-17 12:26:15.780 - error: Caught by controller[3]: at Socket.emit (events.js:188:7)
      2019-09-17 12:26:15.780 - error: Caught by controller[3]: at TCP._handle.close [as _onclose] (net.js:497:12)
      2019-09-17 12:26:15.780 - error: Caught by controller[3]: code: 'ECONNRESET' }
      2019-09-17 12:26:15.780 - error: host.etv-nas-1 instance system.adapter.javascript.0 terminated with code 0 (OK)
      2019-09-17 12:26:15.781 - info: host.etv-nas-1 Restart adapter system.adapter.javascript.0 because enabled
      Wie kann man das verhindern?
      Liebe Grüße
      Tom
      • U
        uschi08 @etv last edited by
        @etv
        Hi.
        hattest du es noch rausbekommen? Hat das was mit dem Netzwerk zuntun?
        Habe nämlich das gleiche Phänomen und glaube auch das nicht mehr alles sauer übertragen wird.
        Ole
        etv 1 Reply Last reply Reply Quote 0
        • etv
          etv @uschi08 last edited by
          Servus @uschi08 ,
          leider bis jetzt noch nicht! Ich hab nun mal genauer geschaut und eine Adresse ausgemacht, die eigentlich immer da zu sein scheint - ist aber nix bei uns im Haus und soll angeblich ein Samsung Gerät sein.
          Das hab ich als zu überwachendes Gerät angelegt und lasse mitloggen, ob es irgendwann auch weg ist.....
          Sonst hab ich nun auch den restart des Adapters um 0:05 Uhr eingestellt, damit es wenigstens nicht eine endlose Loste wird, sondern jeden Tag auf's Neue erstellt wird....ist aber leider rein kosmetisch.
          Das Spannende ist, dass diese Einträge eigentlich alle nur eine MAC Adresse haben, aber keinen Bluetooth Namen oder Vendor eingetragen haben....
          Liebe Grüße
          Tom
          communication javascript
