    5. Waschmaschine/Trockner Script
      freaktech last edited by
      hi
      ich hab hier noch das Problem, dass wenn der Trockner fertig ist die Nachricht ca alle 5-10 Minuten kommt.
      Wie könnte man ändern dass es nur einmalig kommt?
        <variables>
          <variable type="" id="?3%%L.;KPa-d6Zkoj*6T">AUS Zaehler</variable>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="create" id="!tN4!:gtM^}ek;|m=nHo" x="32" y="55">
          <field name="NAME">Vis.Trockner.Aktiv</field>
            <block type="comment" id="hB%p_so=4`EGzX;10:wr">
              <field name="COMMENT">Trockner_Script</field>
                <block type="control" id="Kb.uPdr~gS|=7Ng+:H?a">
                  <field name="OID">javascript.0.Vis.Trockner.Aktiv</field>
                    <block type="logic_boolean" id="vqBy?8.1fiDNDoLrT;G~">
                    <block type="on_ext" id="+A7wlutQO8gBfqosc.y3">
                      <value name="OID0">
                        <shadow type="field_oid" id="L[i=p{|ii-ai*/YAZ@8s">
                          <field name="oid">shelly.0.SHSW-PM#00C9A5#1.Relay0.Power</field>
                        <block type="controls_if" id="bP`*)0;M+g9O:g?]Pd*f">
                          <mutation elseif="2"></mutation>
                            <block type="logic_operation" id="F:)qYHsI}dugF;;Tjm,A" inline="false">
                              <field name="OP">AND</field>
                                <block type="logic_compare" id="H5%_/a!o;(cd2f~t!+^Q">
                                  <field name="OP">GT</field>
                                    <block type="get_value" id="a:y916W!S%H|pb5qQl:J">
                                      <field name="OID">shelly.0.SHSW-PM#00C9A5#1.Relay0.Power</field>
                                    <block type="math_number" id="qFPWw{;UZY{D^a6HN4F4">
                                      <field name="NUM">10</field>
                                <block type="logic_compare" id="+]^D[{zcOd~)d%8C%:S9">
                                  <field name="OP">EQ</field>
                                    <block type="get_value" id="E4;q.WI):RF8,)P;4GaM">
                                    <block type="logic_boolean" id="BlP[`XK*dfV6{q],uSuN">
                            <block type="control" id="XxjRG-wx{Gis|P}j%wi{">
                                <block type="logic_boolean" id="8]j]NPy0pzg_@fy7#pu9">
                          <value name="IF1">
                            <block type="logic_operation" id="xQ~Axjp^x}xIc}?,~bd3" inline="false">
                                <block type="logic_compare" id="m:F[A,C]23{tVG.[9ogx">
                                    <block type="get_value" id="~9hm.bn7JuR`9T^57r|!">
                                    <block type="math_number" id="KK#)EKMNqV.YXg?PWltR">
                                <block type="logic_operation" id="WZqeqrqbx=zB-@D)~l_!" inline="false">
                                    <block type="logic_compare" id="2#,2{UzKUXKc-b;aXI]d">
                                        <block type="get_value" id="X|7IEq+#eQ6U]K@QZDL_">
                                        <block type="logic_boolean" id="88[x9TQtT`hkagX?ux;6">
                                    <block type="logic_compare" id=";5T2wjhgRkI4a=fP=txA">
                                        <block type="variables_get" id="X|5;WK_6+b*X7dWThdYF">
                                          <field name="VAR" id="?3%%L.;KPa-d6Zkoj*6T" variabletype="">AUS Zaehler</field>
                                        <block type="math_number" id="JhvY#m2e){iZg*}U)U7=">
                                          <field name="NUM">0</field>
                          <statement name="DO1">
                            <block type="variables_set" id="qd2jcZSX.j`maks-0XGG">
                                <block type="math_arithmetic" id="-Y}Zmf^#hm,WyL6)Kcd-">
                                    <shadow type="math_number" id="^~p~#U!R+eaJjaW~6U)d">
                                      <field name="NUM">1</field>
                                    <block type="variables_get" id="c/b;teh7B.tfavW#3Kx2">
                                    <shadow type="math_number" id="/@dSwZ{HpbKk6y3_q?jz">
                          <value name="IF2">
                            <block type="logic_operation" id="iHpE~=uUiC0HYZE0ixfv" inline="false">
                                <block type="logic_compare" id="~=`AKkV)p.LRK|-)ym#0">
                                  <field name="OP">LT</field>
                                    <block type="get_value" id="{bMP3Rct]s~^OxB^KYJB">
                                    <block type="math_number" id="}n$r~.-0H0;Y`%V?r;zH">
                                      <field name="NUM">4</field>
                                <block type="logic_compare" id="!cAR@kagkdn/du!lg5?r">
                                    <block type="get_value" id="9TggDfqlTj?4OO=@`~eO">
                                    <block type="logic_boolean" id="S1R!kS9-?kQk+KS_5Qs#">
                          <statement name="DO2">
                            <block type="math_change" id="T.un5=.rdLl@woGn*4oJ">
                              <value name="DELTA">
                                <shadow type="math_number" id="?c=pXLOc61v3AJP.(d:k">
                            <block type="controls_if" id="J!0cvTG#hm+.vpOmP+Dh">
                                <block type="logic_compare" id="%AbMO?J2D[f-rCEWyq=O">
                                    <block type="variables_get" id="u5FZNsypgs:pPUYsV1=g">
                                    <block type="math_number" id="uaHP[P3wt-!h@M!UE]eX">
                                      <field name="NUM">45</field>
                                <block type="timeouts_settimeout" id=";RetM]1NMnq(gM2?*6vO">
                                  <field name="DELAY">1500</field>
                                  <field name="UNIT">ms</field>
                                    <block type="pushover" id="O;i_Of;3W;~`ut*XLErs">
                                      <field name="INSTANCE">.0</field>
                                      <field name="SOUND"></field>
                                      <field name="PRIORITY">0</field>
                                      <field name="LOG"></field>
                                      <value name="MESSAGE">
                                        <shadow type="text" id="bb?GK(0u[jN(qPPjnox1">
                                          <field name="TEXT">Der Trockner ist fertig</field>
                                        <block type="controls_if" id="{YgN%Y7A7_EEDWVfrH-~">
                                            <block type="time_compare_ex" id=";Z9|mLh|XOy}l6q!/|)H">
                                              <mutation end_time="true" actual_time="true"></mutation>
                                              <value name="START_TIME">
                                                <shadow type="text" id="1Mb7k9=om19kl(|^ls{B">
                                                  <field name="TEXT">07:00</field>
                                              <value name="END_TIME">
                                                <shadow type="text" id="u|0,W8,^1sLZcDkByT9E">
                                                  <field name="TEXT">22:00</field>
                                            <block type="control" id="Q#Co*Fw?F|S1$qjg#/Pr">
                                              <mutation delay_input="true"></mutation>
                                              <field name="OID">alexa2.1.Echo-Devices.G000WV0484541A9F.Commands.speak</field>
                                              <field name="DELAY_MS">500</field>
                                                <block type="text" id="%o[+[,2P)W1gpBy8pY,H">
                                                  <field name="TEXT">Der Trockner ist fertig!</field>
                                                <block type="control" id="dEf[f=1wnG@+}UB=)iZ0">
                                                  <field name="OID">alexa2.1.Echo-Devices.G070RR0975070D18.Commands.speak</field>
                                                    <block type="text" id="-lTxI!_9p]4YRp8o1qG/">
                                            <block type="variables_set" id="Hvd2vL)ptc4/sfjoP3Kx">
                                                <block type="math_number" id="Yz`)rz,.esx8@lC+dmm^">
                                                <block type="control" id="sj0ZAG=ELQ-|XeWmtEg3">
                                                    <block type="logic_boolean" id="eX|Bf{oW+%BAW.Y:)kbK">
        <block type="comment" id="k_2r^B84`,O0y4.u,WwG" x="338" y="613">
          <field name="COMMENT">Zähler definiert Leerlaufzeit bis fertig gemeldet wird 15 ist ca. 90 sec bei shelly</field>
      dann wär es perfekt für uns.
      danke
      tom
      • Glasfaser
        Glasfaser @freaktech last edited by
        @freaktech
        Hallo lieber IoBroker User ,wie auch ich einer bin !
        Ich verstehen nicht warum Du immer wieder neue Threads für Dich eröffnest …. !?
        Du hast doch schon hier den Anfang gemacht wo andere User dir helfen ….
        Link Text
        ( Sorry , musste ich mal loswerden )
          sorry
          du hast natürlich recht ich schreibe in dne alten rein
