    2. Русский
    3. ioBroker
    4. ioBroker установка и конфигурация
    5. FreeBSD
    FreeBSD
      boba last edited by
      ставлю по инструкции отсюда http://forum.iobroker.net/viewtopic.php … sd.#p22467
      (там неточность небольшая "sudo chmod 777 /opt/iobroker/. -R" ключ после команды должен быть)
      все встает без ошибок и запускается.
      а дальше:
      root /opt/iobroker # iobroker add vis        11:23
      npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      host.home.su install adapter vis
      npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
      npm ERR! FreeBSD 10.2-RELEASE
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
      npm ERR! node v6.1.0
      npm ERR! npm  v3.8.8
      npm ERR! path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall rename
      npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
      Cannot install iobroker.vis: 254
      root /opt/iobroker # uname -a
      FreeBSD home.su 10.2-RELEASE FreeBSD 10.2-RELEASE #0 r286835: Mon Aug 17 10:34:15 YEKT 2015     root@home.su:/usr/obj/usr/src/sys/MYKERNEL9  amd64
      root /opt/iobroker # node -v
      v6.1.0
      root /opt/iobroker # npm -v
      3.8.8
      ! root /opt/iobroker # cat /opt/iobroker/npm-debug.log 11:40
      ! 0 info it worked if it ends with ok
      ! 1 verbose cli [ '/usr/local/bin/node',
      ! 1 verbose cli '/usr/local/bin/npm',
      ! 1 verbose cli 'install',
      ! 1 verbose cli '–production',
      ! 1 verbose cli '--prefix',
      ! 1 verbose cli '/opt/iobroker/node_modules/iobroker.vis' ]
      ! 2 info using npm@3.8.8
      ! 3 info using node@v6.1.0
      ! 4 silly loadCurrentTree Starting
      ! 5 silly install loadCurrentTree
      ! 6 silly install readLocalPackageData
      ! 7 silly install normalizeTree
      ! 8 silly loadCurrentTree Finishing
      ! 9 silly loadIdealTree Starting
      ! 10 silly install loadIdealTree
      ! 11 silly cloneCurrentTree Starting
      ! 12 silly install cloneCurrentTreeToIdealTree
      ! 13 silly cloneCurrentTree Finishing
      ! 14 silly loadShrinkwrap Starting
      ! 15 silly install loadShrinkwrap
      ! 16 silly loadShrinkwrap Finishing
      ! 17 silly loadAllDepsIntoIdealTree Starting
      ! 18 silly install loadAllDepsIntoIdealTree
      ! 19 silly loadAllDepsIntoIdealTree Finishing
      ! 20 silly idealTree:prePrune iobroker.vis@0.9.4
      ! 21 silly loadIdealTree Finishing
      ! 22 silly currentTree iobroker.vis@0.9.4
      ! 23 silly idealTree iobroker.vis@0.9.4
      ! 24 silly generateActionsToTake Starting
      ! 25 silly install generateActionsToTake
      ! 26 silly generateActionsToTake Finishing
      ! 27 silly diffTrees action count 1
      ! 28 silly diffTrees update iobroker.vis@0.9.4
      ! 29 silly decomposeActions action count 8
      ! 30 silly decomposeActions fetch iobroker.vis@0.9.4
      ! 31 silly decomposeActions extract iobroker.vis@0.9.4
      ! 32 silly decomposeActions test iobroker.vis@0.9.4
      ! 33 silly decomposeActions preinstall iobroker.vis@0.9.4
      ! 34 silly decomposeActions build iobroker.vis@0.9.4
      ! 35 silly decomposeActions install iobroker.vis@0.9.4
      ! 36 silly decomposeActions postinstall iobroker.vis@0.9.4
      ! 37 silly decomposeActions finalize iobroker.vis@0.9.4
      ! 38 silly executeActions Starting
      ! 39 silly install executeActions
      ! 40 silly doSerial global-install 0
      ! 41 silly doParallel fetch 1
      ! 42 verbose correctMkdir /root/.npm/_locks correctMkdir not in flight; initializing
      ! 43 verbose lock using /root/.npm/_locks/staging-40fe0fc83e86560c.lock for /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging
      ! 44 silly doParallel extract 1
      ! 45 silly extract iobroker.vis@0.9.4
      ! 46 verbose unbuild node_modules/.staging/iobroker.vis-c6a771c0
      ! 47 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0 is being purged from base /opt/iobroker/node_modules/iobroker.vis
      ! 48 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      ! 49 verbose tar unpack /root/.npm/iobroker.vis/0.9.4/package.tgz
      ! 50 verbose tar unpacking to /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      ! 51 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0 is being purged
      ! 52 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      ! 53 silly gunzTarPerm modes [ '755', '644' ]
      ! 54 silly gunzTarPerm extractEntry package.json
      ! 55 silly gunzTarPerm modified mode [ 'package.json', 438, 420 ]
      ! 56 silly gunzTarPerm extractEntry .npmignore
      ! 57 silly gunzTarPerm modified mode [ '.npmignore', 438, 420 ]
      ! 58 silly gunzTarPerm extractEntry README.md
      ! 59 silly gunzTarPerm modified mode [ 'README.md', 438, 420 ]
      ! 60 silly gunzTarPerm extractEntry LICENSE
      ! 61 silly gunzTarPerm modified mode [ 'LICENSE', 438, 420 ]
      ! 62 silly gunzTarPerm extractEntry main.js
      ! 63 silly gunzTarPerm modified mode [ 'main.js', 438, 420 ]
      ! 64 silly gunzTarPerm extractEntry ROADMAP.md
      ! 65 silly gunzTarPerm modified mode [ 'ROADMAP.md', 438, 420 ]
      ! 66 silly gunzTarPerm extractEntry admin/index.html
      ! 67 silly gunzTarPerm modified mode [ 'admin/index.html', 438, 420 ]
      ! 68 silly gunzTarPerm extractEntry admin/vis.png
      ! 69 silly gunzTarPerm modified mode [ 'admin/vis.png', 438, 420 ]
      ! 70 silly gunzTarPerm extractEntry io-package.json
      ! 71 silly gunzTarPerm modified mode [ 'io-package.json', 438, 420 ]
      ! 72 silly gunzTarPerm extractEntry lib/install.js
      ! 73 silly gunzTarPerm modified mode [ 'lib/install.js', 438, 420 ]
      ! 74 silly gunzTarPerm extractEntry lib/utils.js
      ! 75 silly gunzTarPerm modified mode [ 'lib/utils.js', 438, 420 ]
      ! 76 silly gunzTarPerm extractEntry www/cordova.js
      ! 77 silly gunzTarPerm modified mode [ 'www/cordova.js', 438, 420 ]
      ! 78 silly gunzTarPerm extractEntry www/img/editmode-pattern.png
      ! 79 silly gunzTarPerm modified mode [ 'www/img/editmode-pattern.png', 438, 420 ]
      ! 80 silly gunzTarPerm extractEntry www/img/Heating.png
      ! 81 silly gunzTarPerm modified mode [ 'www/img/Heating.png', 438, 420 ]
      ! 82 silly gunzTarPerm extractEntry www/img/OutsideTemp.png
      ! 83 silly gunzTarPerm modified mode [ 'www/img/OutsideTemp.png', 438, 420 ]
      ! 84 silly gunzTarPerm extractEntry www/img/Window.png
      ! 85 silly gunzTarPerm modified mode [ 'www/img/Window.png', 438, 420 ]
      ! 86 silly gunzTarPerm extractEntry www/img/back/box-radial.png
      ! 87 silly gunzTarPerm modified mode [ 'www/img/back/box-radial.png', 438, 420 ]
      ! 88 silly gunzTarPerm extractEntry www/img/back/flowers.jpg
      ! 89 silly gunzTarPerm modified mode [ 'www/img/back/flowers.jpg', 438, 420 ]
      ! 90 silly gunzTarPerm extractEntry www/img/back/oblique-line-bk.png
      ! 91 silly gunzTarPerm modified mode [ 'www/img/back/oblique-line-bk.png', 438, 420 ]
      ! 92 silly gunzTarPerm extractEntry www/img/bulb_off.png
      ! 93 silly gunzTarPerm modified mode [ 'www/img/bulb_off.png', 438, 420 ]
      ! 94 silly gunzTarPerm extractEntry www/img/bulb_on.png
      ! 95 silly gunzTarPerm modified mode [ 'www/img/bulb_on.png', 438, 420 ]
      ! 96 silly gunzTarPerm extractEntry www/img/camera.png
      ! 97 silly gunzTarPerm modified mode [ 'www/img/camera.png', 438, 420 ]
      ! 98 silly gunzTarPerm extractEntry www/img/cc-nc-by.png
      ! 99 silly gunzTarPerm modified mode [ 'www/img/cc-nc-by.png', 438, 420 ]
      ! 100 silly gunzTarPerm extractEntry www/img/disconnect.png
      ! 101 silly gunzTarPerm modified mode [ 'www/img/disconnect.png', 438, 420 ]
      ! 102 silly gunzTarPerm extractEntry www/img/door-bell.mp3
      ! 103 silly gunzTarPerm modified mode [ 'www/img/door-bell.mp3', 438, 420 ]
      ! 104 silly gunzTarPerm extractEntry www/img/Lamp.png
      ! 105 silly gunzTarPerm modified mode [ 'www/img/Lamp.png', 438, 420 ]
      ! 106 silly gunzTarPerm extractEntry www/img/eg_trans.png
      ! 107 silly gunzTarPerm modified mode [ 'www/img/eg_trans.png', 438, 420 ]
      ! 108 silly gunzTarPerm extractEntry www/img/favicon.png
      ! 109 silly gunzTarPerm modified mode [ 'www/img/favicon.png', 438, 420 ]
      ! 110 silly gunzTarPerm extractEntry www/img/faviconEdit.png
      ! 111 silly gunzTarPerm modified mode [ 'www/img/faviconEdit.png', 438, 420 ]
      ! 112 silly gunzTarPerm extractEntry www/img/garage-door-closed.png
      ! 113 silly gunzTarPerm modified mode [ 'www/img/garage-door-closed.png', 438, 420 ]
      ! 114 silly gunzTarPerm extractEntry www/img/garage-door-opened.png
      ! 115 silly gunzTarPerm modified mode [ 'www/img/garage-door-opened.png', 438, 420 ]
      ! 116 silly gunzTarPerm extractEntry www/img/gear-icon-md.png
      ! 117 silly gunzTarPerm modified mode [ 'www/img/gear-icon-md.png', 438, 420 ]
      ! 118 silly gunzTarPerm extractEntry www/img/hexabump.png
      ! 119 silly gunzTarPerm modified mode [ 'www/img/hexabump.png', 438, 420 ]
      ! 120 silly gunzTarPerm extractEntry www/img/kde_folder.png
      ! 121 silly gunzTarPerm modified mode [ 'www/img/kde_folder.png', 438, 420 ]
      ! 122 silly gunzTarPerm extractEntry www/img/no_filter.png
      ! 123 silly gunzTarPerm modified mode [ 'www/img/no_filter.png', 438, 420 ]
      ! 124 silly gunzTarPerm extractEntry www/img/sound.png
      ! 125 silly gunzTarPerm modified mode [ 'www/img/sound.png', 438, 420 ]
      ! 126 silly gunzTarPerm extractEntry www/img/tank.png
      ! 127 silly gunzTarPerm modified mode [ 'www/img/tank.png', 438, 420 ]
      ! 128 silly gunzTarPerm extractEntry www/css/add_kian.css
      ! 129 silly gunzTarPerm modified mode [ 'www/css/add_kian.css', 438, 420 ]
      ! 130 silly gunzTarPerm extractEntry www/css/backgrounds.css
      ! 131 silly gunzTarPerm modified mode [ 'www/css/backgrounds.css', 438, 420 ]
      ! 132 silly gunzTarPerm extractEntry www/css/doc.css
      ! 133 silly gunzTarPerm modified mode [ 'www/css/doc.css', 438, 420 ]
      ! 134 silly gunzTarPerm extractEntry www/css/vis.css
      ! 135 silly gunzTarPerm modified mode [ 'www/css/vis.css', 438, 420 ]
      ! 136 silly gunzTarPerm extractEntry www/css/vis_editor.css
      ! 137 silly gunzTarPerm modified mode [ 'www/css/vis_editor.css', 438, 420 ]
      ! 138 silly gunzTarPerm extractEntry www/edit.html
      ! 139 silly gunzTarPerm modified mode [ 'www/edit.html', 438, 420 ]
      ! 140 silly gunzTarPerm extractEntry www/icon/cancel.png
      ! 141 silly gunzTarPerm modified mode [ 'www/icon/cancel.png', 438, 420 ]
      ! 142 silly gunzTarPerm extractEntry www/icon/add.png
      ! 143 silly gunzTarPerm modified mode [ 'www/icon/add.png', 438, 420 ]
      ! 144 silly gunzTarPerm extractEntry www/icon/align-horizontal-center-2.png
      ! 145 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-center-2.png', 438, 420 ]
      ! 146 silly gunzTarPerm extractEntry www/icon/align-horizontal-left.png
      ! 147 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-left.png', 438, 420 ]
      ! 148 silly gunzTarPerm extractEntry www/icon/align-horizontal-right-2.png
      ! 149 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-right-2.png', 438, 420 ]
      ! 150 silly gunzTarPerm extractEntry www/icon/align-vertical-bottom-2.png
      ! 151 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-bottom-2.png', 438, 420 ]
      ! 152 silly gunzTarPerm extractEntry www/icon/align-vertical-center-2.png
      ! 153 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-center-2.png', 438, 420 ]
      ! 154 silly gunzTarPerm extractEntry www/icon/align-vertical-top-2.png
      ! 155 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-top-2.png', 438, 420 ]
      ! 156 silly gunzTarPerm extractEntry www/icon/align-width.png
      ! 157 silly gunzTarPerm modified mode [ 'www/icon/align-width.png', 438, 420 ]
      ! 158 silly gunzTarPerm extractEntry www/icon/align-height.png
      ! 159 silly gunzTarPerm modified mode [ 'www/icon/align-height.png', 438, 420 ]
      ! 160 silly gunzTarPerm extractEntry www/icon/copy.png
      ! 161 silly gunzTarPerm modified mode [ 'www/icon/copy.png', 438, 420 ]
      ! 162 silly gunzTarPerm extractEntry www/icon/delete.png
      ! 163 silly gunzTarPerm modified mode [ 'www/icon/delete.png', 438, 420 ]
      ! 164 silly gunzTarPerm extractEntry www/icon/distribute-horizontal-equal.png
      ! 165 silly gunzTarPerm modified mode [ 'www/icon/distribute-horizontal-equal.png', 438, 420 ]
      ! 166 silly gunzTarPerm extractEntry www/icon/distribute-vertical-equal.png
      ! 167 silly gunzTarPerm modified mode [ 'www/icon/distribute-vertical-equal.png', 438, 420 ]
      ! 168 silly gunzTarPerm extractEntry www/icon/info.png
      ! 169 silly gunzTarPerm modified mode [ 'www/icon/info.png', 438, 420 ]
      ! 170 silly gunzTarPerm extractEntry www/icon/lock.png
      ! 171 silly gunzTarPerm modified mode [ 'www/icon/lock.png', 438, 420 ]
      ! 172 silly gunzTarPerm extractEntry www/icon/ok.png
      ! 173 silly gunzTarPerm modified mode [ 'www/icon/ok.png', 438, 420 ]
      ! 174 silly gunzTarPerm extractEntry www/icon/refresh-4.png
      ! 175 silly gunzTarPerm modified mode [ 'www/icon/refresh-4.png', 438, 420 ]
      ! 176 silly gunzTarPerm extractEntry www/icon/rename.png
      ! 177 silly gunzTarPerm modified mode [ 'www/icon/rename.png', 438, 420 ]
      ! 178 silly gunzTarPerm extractEntry www/cache.manifest
      ! 179 silly gunzTarPerm modified mode [ 'www/cache.manifest', 438, 420 ]
      ! 180 silly gunzTarPerm extractEntry www/index.html
      ! 181 silly gunzTarPerm modified mode [ 'www/index.html', 438, 420 ]
      ! 182 silly gunzTarPerm extractEntry www/js/app.js
      ! 183 silly gunzTarPerm modified mode [ 'www/js/app.js', 438, 420 ]
      ! 184 silly gunzTarPerm extractEntry www/js/conn.js
      ! 185 silly gunzTarPerm modified mode [ 'www/js/conn.js', 438, 420 ]
      ! 186 silly gunzTarPerm extractEntry www/js/connSignalR.js
      ! 187 silly gunzTarPerm modified mode [ 'www/js/connSignalR.js', 438, 420 ]
      ! 188 silly gunzTarPerm extractEntry www/js/visLang.js
      ! 189 silly gunzTarPerm modified mode [ 'www/js/visLang.js', 438, 420 ]
      ! 190 silly gunzTarPerm extractEntry www/js/vis.js
      ! 191 silly gunzTarPerm modified mode [ 'www/js/vis.js', 438, 420 ]
      ! 192 silly gunzTarPerm extractEntry www/js/config.js
      ! 193 silly gunzTarPerm modified mode [ 'www/js/config.js', 438, 420 ]
      ! 194 silly gunzTarPerm extractEntry www/js/visEdit.js
      ! 195 silly gunzTarPerm modified mode [ 'www/js/visEdit.js', 438, 420 ]
      ! 196 silly gunzTarPerm extractEntry www/js/visEditExt.js
      ! 197 silly gunzTarPerm modified mode [ 'www/js/visEditExt.js', 438, 420 ]
      ! 198 silly gunzTarPerm extractEntry www/js/visEditInspect.js
      ! 199 silly gunzTarPerm modified mode [ 'www/js/visEditInspect.js', 438, 420 ]
      ! 200 silly gunzTarPerm extractEntry www/js/visEditWelcome.js
      ! 201 silly gunzTarPerm modified mode [ 'www/js/visEditWelcome.js', 438, 420 ]
      ! 202 silly gunzTarPerm extractEntry www/js/visWizard.js
      ! 203 silly gunzTarPerm modified mode [ 'www/js/visWizard.js', 438, 420 ]
      ! 204 silly gunzTarPerm extractEntry www/js/visAbout.js
      ! 205 silly gunzTarPerm modified mode [ 'www/js/visAbout.js', 438, 420 ]
      ! 206 silly gunzTarPerm extractEntry www/js/fm/fileManager.js
      ! 207 silly gunzTarPerm modified mode [ 'www/js/fm/fileManager.js', 438, 420 ]
      ! 208 silly gunzTarPerm extractEntry www/js/fm/fileManager.css
      ! 209 silly gunzTarPerm modified mode [ 'www/js/fm/fileManager.css', 438, 420 ]
      ! 210 silly gunzTarPerm extractEntry www/js/fm/icon/actions/folder-new.png
      ! 211 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/folder-new.png', 438, 420 ]
      ! 212 silly gunzTarPerm extractEntry www/js/fm/icon/actions/add.png
      ! 213 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/add.png', 438, 420 ]
      ! 214 silly gunzTarPerm extractEntry www/js/fm/icon/actions/delete.png
      ! 215 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/delete.png', 438, 420 ]
      ! 216 silly gunzTarPerm extractEntry www/js/fm/icon/actions/down.png
      ! 217 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/down.png', 438, 420 ]
      ! 218 silly gunzTarPerm extractEntry www/js/fm/icon/actions/edit-rename.png
      ! 219 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/edit-rename.png', 438, 420 ]
      ! 220 silly gunzTarPerm extractEntry www/js/fm/icon/actions/folder-new-7.png
      ! 221 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/folder-new-7.png', 438, 420 ]
      ! 222 silly gunzTarPerm extractEntry www/js/fm/icon/actions/back.png
      ! 223 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/back.png', 438, 420 ]
      ! 224 silly gunzTarPerm extractEntry www/js/fm/icon/actions/icons.png
      ! 225 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/icons.png', 438, 420 ]
      ! 226 silly gunzTarPerm extractEntry www/js/fm/icon/actions/list.png
      ! 227 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/list.png', 438, 420 ]
      ! 228 silly gunzTarPerm extractEntry www/js/fm/icon/actions/play.png
      ! 229 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/play.png', 438, 420 ]
      ! 230 silly gunzTarPerm extractEntry www/js/fm/icon/actions/refresh.png
      ! 231 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/refresh.png', 438, 420 ]
      ! 232 silly gunzTarPerm extractEntry www/js/fm/icon/actions/stop.png
      ! 233 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/stop.png', 438, 420 ]
      ! 234 silly gunzTarPerm extractEntry www/js/fm/icon/actions/up.png
      ! 235 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/up.png', 438, 420 ]
      ! 236 silly gunzTarPerm extractEntry www/js/fm/icon/circleLeftIcon.png
      ! 237 silly gunzTarPerm modified mode [ 'www/js/fm/icon/circleLeftIcon.png', 438, 420 ]
      ! 238 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/jpg.png
      ! 239 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/jpg.png', 438, 420 ]
      ! 240 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/JS.png
      ! 241 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/JS.png', 438, 420 ]
      ! 242 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/css.png
      ! 243 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/css.png', 438, 420 ]
      ! 244 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-blue.png
      ! 245 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-blue.png', 438, 420 ]
      ! 246 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-brown.png
      ! 247 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-brown.png', 438, 420 ]
      ! 248 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-green.png
      ! 249 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-green.png', 438, 420 ]
      ! 250 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/gif.png
      ! 251 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/gif.png', 438, 420 ]
      ! 252 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/img2.png
      ! 253 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/img2.png', 438, 420 ]
      ! 254 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/bmp.png
      ! 255 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/bmp.png', 438, 420 ]
      ! 256 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/misc.png
      ! 257 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/misc.png', 438, 420 ]
      ! 258 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/mp3.png
      ! 259 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/mp3.png', 438, 420 ]
      ! 260 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/png.png
      ! 261 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/png.png', 438, 420 ]
      ! 262 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/prg.png
      ! 263 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/prg.png', 438, 420 ]
      ! 264 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/svg.png
      ! 265 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/svg.png', 438, 420 ]
      ! 266 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/undef.png
      ! 267 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/undef.png', 438, 420 ]
      ! 268 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/wav.png
      ! 269 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/wav.png', 438, 420 ]
      ! 270 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/zip.png
      ! 271 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/zip.png', 438, 420 ]
      ! 272 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/js.png
      ! 273 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/js.png', 438, 420 ]
      ! 274 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/bmp.png
      ! 275 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/bmp.png', 438, 420 ]
      ! 276 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-blue.png
      ! 277 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-blue.png', 438, 420 ]
      ! 278 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-brown.png
      ! 279 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-brown.png', 438, 420 ]
      ! 280 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-green.png
      ! 281 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-green.png', 438, 420 ]
      ! 282 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/gif.png
      ! 283 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/gif.png', 438, 420 ]
      ! 284 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/img2.png
      ! 285 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/img2.png', 438, 420 ]
      ! 286 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/jpg.png
      ! 287 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/jpg.png', 438, 420 ]
      ! 288 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/css.png
      ! 289 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/css.png', 438, 420 ]
      ! 290 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/misc.png
      ! 291 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/misc.png', 438, 420 ]
      ! 292 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/mp3.png
      ! 293 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/mp3.png', 438, 420 ]
      ! 294 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/png.png
      ! 295 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/png.png', 438, 420 ]
      ! 296 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/prg.png
      ! 297 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/prg.png', 438, 420 ]
      ! 298 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/svg.png
      ! 299 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/svg.png', 438, 420 ]
      ! 300 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/undef.png
      ! 301 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/undef.png', 438, 420 ]
      ! 302 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/wav.png
      ! 303 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/wav.png', 438, 420 ]
      ! 304 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/zip.png
      ! 305 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/zip.png', 438, 420 ]
      ! 306 silly gunzTarPerm extractEntry www/lib/ace/ace.js
      ! 307 silly gunzTarPerm modified mode [ 'www/lib/ace/ace.js', 438, 420 ]
      ! 308 silly gunzTarPerm extractEntry www/lib/ace/ext-language_tools.js
      ! 309 silly gunzTarPerm modified mode [ 'www/lib/ace/ext-language_tools.js', 438, 420 ]
      ! 310 silly gunzTarPerm extractEntry www/lib/ace/ext-searchbox.js
      ! 311 silly gunzTarPerm modified mode [ 'www/lib/ace/ext-searchbox.js', 438, 420 ]
      ! 312 silly gunzTarPerm extractEntry www/lib/ace/mode-css.js
      ! 313 silly gunzTarPerm modified mode [ 'www/lib/ace/mode-css.js', 438, 420 ]
      ! 314 silly gunzTarPerm extractEntry www/lib/ace/mode-html.js
      ! 315 silly gunzTarPerm modified mode [ 'www/lib/ace/mode-html.js', 438, 420 ]
      ! 316 silly gunzTarPerm extractEntry www/lib/ace/worker-css.js
      ! 317 silly gunzTarPerm modified mode [ 'www/lib/ace/worker-css.js', 438, 420 ]
      ! 318 silly gunzTarPerm extractEntry www/lib/ace/worker-html.js
      ! 319 silly gunzTarPerm modified mode [ 'www/lib/ace/worker-html.js', 438, 420 ]
      ! 320 silly gunzTarPerm extractEntry www/lib/css/add2home-2.0.8.css
      ! 321 silly gunzTarPerm modified mode [ 'www/lib/css/add2home-2.0.8.css', 438, 420 ]
      ! 322 silly gunzTarPerm extractEntry www/lib/css/fancytree/channel.png
      ! 323 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/channel.png', 438, 420 ]
      ! 324 silly gunzTarPerm extractEntry www/lib/css/fancytree/device.png
      ! 325 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/device.png', 438, 420 ]
      ! 326 silly gunzTarPerm extractEntry www/lib/css/fancytree/icons.gif
      ! 327 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/icons.gif', 438, 420 ]
      ! 328 silly gunzTarPerm extractEntry www/lib/css/fancytree/loading.gif
      ! 329 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/loading.gif', 438, 420 ]
      ! 330 silly gunzTarPerm extractEntry www/lib/css/fancytree/state.png
      ! 331 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/state.png', 438, 420 ]
      ! 332 silly gunzTarPerm extractEntry www/lib/css/fancytree/ui.fancytree.jquery.min.css
      ! 333 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/ui.fancytree.jquery.min.css', 438, 420 ]
      ! 334 silly gunzTarPerm extractEntry www/lib/css/fancytree/ui.fancytree.min.css
      ! 335 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/ui.fancytree.min.css', 438, 420 ]
      ! 336 silly gunzTarPerm extractEntry www/lib/css/farbtastic.css
      ! 337 silly gunzTarPerm modified mode [ 'www/lib/css/farbtastic.css', 438, 420 ]
      ! 338 silly gunzTarPerm extractEntry www/lib/css/jquery-ui-timepicker-addon-1.2.2.css
      ! 339 silly gunzTarPerm modified mode [ 'www/lib/css/jquery-ui-timepicker-addon-1.2.2.css', 438, 420 ]
      ! 340 silly gunzTarPerm extractEntry www/lib/css/jquery.jgrowl.min.css
      ! 341 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.jgrowl.min.css', 438, 420 ]
      ! 342 silly gunzTarPerm extractEntry www/lib/css/jquery.multiselect-1.13.css
      ! 343 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.multiselect-1.13.css', 438, 420 ]
      ! 344 silly gunzTarPerm extractEntry www/lib/css/jquery.multiselect.filter.css
      ! 345 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.multiselect.filter.css', 438, 420 ]
      ! 346 silly gunzTarPerm extractEntry www/lib/css/superfish/megafish.css
      ! 347 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/megafish.css', 438, 420 ]
      ! 348 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish-navbar.css
      ! 349 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish-navbar.css', 438, 420 ]
      ! 350 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish-vertical.css
      ! 351 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish-vertical.css', 438, 420 ]
      ! 352 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish.css
      ! 353 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish.css', 438, 420 ]
      ! 354 silly gunzTarPerm extractEntry www/lib/img/delete.png
      ! 355 silly gunzTarPerm modified mode [ 'www/lib/img/delete.png', 438, 420 ]
      ! 356 silly gunzTarPerm extractEntry www/lib/img/edit-undo-8.png
      ! 357 silly gunzTarPerm modified mode [ 'www/lib/img/edit-undo-8.png', 438, 420 ]
      ! 358 silly gunzTarPerm extractEntry www/lib/img/logout.png
      ! 359 silly gunzTarPerm modified mode [ 'www/lib/img/logout.png', 438, 420 ]
      ! 360 silly gunzTarPerm extractEntry www/lib/img/marker.png
      ! 361 silly gunzTarPerm modified mode [ 'www/lib/img/marker.png', 438, 420 ]
      ! 362 silly gunzTarPerm extractEntry www/lib/img/mask.png
      ! 363 silly gunzTarPerm modified mode [ 'www/lib/img/mask.png', 438, 420 ]
      ! 364 silly gunzTarPerm extractEntry www/lib/img/shape_align_bottom.png
      ! 365 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_bottom.png', 438, 420 ]
      ! 366 silly gunzTarPerm extractEntry www/lib/img/shape_align_left.png
      ! 367 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_left.png', 438, 420 ]
      ! 368 silly gunzTarPerm extractEntry www/lib/img/shape_align_right.png
      ! 369 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_right.png', 438, 420 ]
      ! 370 silly gunzTarPerm extractEntry www/lib/img/shape_align_top.png
      ! 371 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_top.png', 438, 420 ]
      ! 372 silly gunzTarPerm extractEntry www/lib/img/wheel.png
      ! 373 silly gunzTarPerm modified mode [ 'www/lib/img/wheel.png', 438, 420 ]
      ! 374 silly gunzTarPerm extractEntry www/lib/js/add2home-2.0.8.js
      ! 375 silly gunzTarPerm modified mode [ 'www/lib/js/add2home-2.0.8.js', 438, 420 ]
      ! 376 silly gunzTarPerm extractEntry www/lib/js/jquery.ba-resize.min.js
      ! 377 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ba-resize.min.js', 438, 420 ]
      ! 378 silly gunzTarPerm extractEntry www/lib/js/jquery.base64.min.js
      ! 379 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.base64.min.js', 438, 420 ]
      ! 380 silly gunzTarPerm extractEntry www/lib/js/jquery.fancytree-all.min.js
      ! 381 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.fancytree-all.min.js', 438, 420 ]
      ! 382 silly gunzTarPerm extractEntry www/lib/js/jquery.inputmask.bundle.min.js
      ! 383 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.inputmask.bundle.min.js', 438, 420 ]
      ! 384 silly gunzTarPerm extractEntry www/lib/js/jquery-ui-timepicker-addon-1.2.2.js
      ! 385 silly gunzTarPerm modified mode [ 'www/lib/js/jquery-ui-timepicker-addon-1.2.2.js', 438, 420 ]
      ! 386 silly gunzTarPerm extractEntry www/lib/js/jquery.jgrowl.min.js
      ! 387 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.jgrowl.min.js', 438, 420 ]
      ! 388 silly gunzTarPerm extractEntry www/lib/js/jquery.multiselect-1.13.min.js
      ! 389 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.multiselect-1.13.min.js', 438, 420 ]
      ! 390 silly gunzTarPerm extractEntry www/lib/js/jquery.multiselect.filter-1.5pre.js
      ! 391 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.multiselect.filter-1.5pre.js', 438, 420 ]
      ! 392 silly gunzTarPerm extractEntry www/lib/js/jquery.ui.datepicker.min.js
      ! 393 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ui.datepicker.min.js', 438, 420 ]
      ! 394 silly gunzTarPerm extractEntry www/lib/js/jquery.ui.touch-punch.min.js
      ! 395 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ui.touch-punch.min.js', 438, 420 ]
      ! 396 silly gunzTarPerm extractEntry www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
      ! 397 silly gunzTarPerm modified mode [ 'www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js', 438, 420 ]
      ! 398 silly gunzTarPerm extractEntry www/lib/js/jquery.wakeup.js
      ! 399 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.wakeup.js', 438, 420 ]
      ! 400 silly gunzTarPerm extractEntry www/lib/js/html2canvas.min.js
      ! 401 silly gunzTarPerm modified mode [ 'www/lib/js/html2canvas.min.js', 438, 420 ]
      ! 402 silly gunzTarPerm extractEntry www/lib/js/jqueryui.selectmenu.js
      ! 403 silly gunzTarPerm modified mode [ 'www/lib/js/jqueryui.selectmenu.js', 438, 420 ]
      ! 404 silly gunzTarPerm extractEntry www/lib/js/farbtastic.js
      ! 405 silly gunzTarPerm modified mode [ 'www/lib/js/farbtastic.js', 438, 420 ]
      ! 406 silly gunzTarPerm extractEntry www/lib/js/loStorage.js
      ! 407 silly gunzTarPerm modified mode [ 'www/lib/js/loStorage.js', 438, 420 ]
      ! 408 silly gunzTarPerm extractEntry www/lib/js/dropzone.js
      ! 409 silly gunzTarPerm modified mode [ 'www/lib/js/dropzone.js', 438, 420 ]
      ! 410 silly gunzTarPerm extractEntry www/lib/js/quo.standalone.js
      ! 411 silly gunzTarPerm modified mode [ 'www/lib/js/quo.standalone.js', 438, 420 ]
      ! 412 silly gunzTarPerm extractEntry www/lib/js/colResizable-1.5.min.js
      ! 413 silly gunzTarPerm modified mode [ 'www/lib/js/colResizable-1.5.min.js', 438, 420 ]
      ! 414 silly gunzTarPerm extractEntry www/lib/js/superclick.js
      ! 415 silly gunzTarPerm modified mode [ 'www/lib/js/superclick.js', 438, 420 ]
      ! 416 silly gunzTarPerm extractEntry www/lib/js/can.2.2.4.custom.min.js
      ! 417 silly gunzTarPerm modified mode [ 'www/lib/js/can.2.2.4.custom.min.js', 438, 420 ]
      ! 418 silly gunzTarPerm extractEntry www/lib/js/translate.js
      ! 419 silly gunzTarPerm modified mode [ 'www/lib/js/translate.js', 438, 420 ]
      ! 420 silly gunzTarPerm extractEntry www/lib/js/jquery.jgrowl.map
      ! 421 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.jgrowl.map', 438, 420 ]
      ! 422 silly gunzTarPerm extractEntry www/offline.html
      ! 423 silly gunzTarPerm modified mode [ 'www/offline.html', 438, 420 ]
      ! 424 silly gunzTarPerm extractEntry www/widgets/jqui.html
      ! 425 silly gunzTarPerm modified mode [ 'www/widgets/jqui.html', 438, 420 ]
      ! 426 silly gunzTarPerm extractEntry www/widgets/basic/css/table.css
      ! 427 silly gunzTarPerm modified mode [ 'www/widgets/basic/css/table.css', 438, 420 ]
      ! 428 silly gunzTarPerm extractEntry www/widgets/basic/doc.html
      ! 429 silly gunzTarPerm modified mode [ 'www/widgets/basic/doc.html', 438, 420 ]
      ! 430 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueBool.png
      ! 431 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueBool.png', 438, 420 ]
      ! 432 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_AckBool.png
      ! 433 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_AckBool.png', 438, 420 ]
      ! 434 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ContainerView.png
      ! 435 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ContainerView.png', 438, 420 ]
      ! 436 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_HTML.png
      ! 437 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_HTML.png', 438, 420 ]
      ! 438 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_HTMLnavigation.png
      ! 439 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_HTMLnavigation.png', 438, 420 ]
      ! 440 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_Image.png
      ! 441 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_Image.png', 438, 420 ]
      ! 442 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulContainerView8.png
      ! 443 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulContainerView8.png',
      ! 443 silly gunzTarPerm 438,
      ! 443 silly gunzTarPerm 420 ]
      ! 444 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulIFrame8.png
      ! 445 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulIFrame8.png', 438, 420 ]
      ! 446 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulImage.png
      ! 447 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulImage.png', 438, 420 ]
      ! 448 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_BasicState.png
      ! 449 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_BasicState.png', 438, 420 ]
      ! 450 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueBoolCtrl.png
      ! 451 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueBoolCtrl.png', 438, 420 ]
      ! 452 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueList.png
      ! 453 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueList.png', 438, 420 ]
      ! 454 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueListHtml.png
      ! 455 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueListHtml.png', 438, 420 ]
      ! 456 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueListHtml8.png
      ! 457 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueListHtml8.png', 438, 420 ]
      ! 458 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueStringImg.png
      ! 459 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueStringImg.png', 438, 420 ]
      ! 460 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_iFrame.png
      ! 461 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_iFrame.png', 438, 420 ]
      ! 462 silly gunzTarPerm extractEntry www/widgets/basic/img/doc_example_hm_val_number.png
      ! 463 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/doc_example_hm_val_number.png',
      ! 463 silly gunzTarPerm 438,
      ! 463 silly gunzTarPerm 420 ]
      ! 464 silly gunzTarPerm extractEntry www/widgets/basic/img/pin_red5.svg
      ! 465 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/pin_red5.svg', 438, 420 ]
      ! 466 silly gunzTarPerm extractEntry www/widgets/basic/js/table.js
      ! 467 silly gunzTarPerm modified mode [ 'www/widgets/basic/js/table.js', 438, 420 ]
      ! 468 silly gunzTarPerm extractEntry www/widgets/jqplot/css/jquery.jqplot.min.css
      ! 469 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/css/jquery.jqplot.min.css', 438, 420 ]
      ! 470 silly gunzTarPerm extractEntry www/widgets/jqplot/doc.html
      ! 471 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/doc.html', 438, 420 ]
      ! 472 silly gunzTarPerm extractEntry www/widgets/jqplot/img/Prev_MeterGauge.png
      ! 473 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/img/Prev_MeterGauge.png', 438, 420 ]
      ! 474 silly gunzTarPerm extractEntry www/widgets/jqplot/js/jquery.jqplot.min.js
      ! 475 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/js/jquery.jqplot.min.js', 438, 420 ]
      ! 476 silly gunzTarPerm extractEntry www/widgets/jqplot.html
      ! 477 silly gunzTarPerm modified mode [ 'www/widgets/jqplot.html', 438, 420 ]
      ! 478 silly gunzTarPerm extractEntry www/widgets/jqui/doc.html
      ! 479 silly gunzTarPerm modified mode [ 'www/widgets/jqui/doc.html', 438, 420 ]
      ! 480 silly gunzTarPerm extractEntry www/widgets/jqui/img/ct.png
      ! 481 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/ct.png', 438, 420 ]
      ! 482 silly gunzTarPerm extractEntry www/widgets/jqui/img/hue.png
      ! 483 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/hue.png', 438, 420 ]
      ! 484 silly gunzTarPerm extractEntry www/widgets/jqui/img/internet-web-browser-2.png
      ! 485 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/internet-web-browser-2.png', 438, 420 ]
      ! 486 silly gunzTarPerm extractEntry www/widgets/basic.html
      ! 487 silly gunzTarPerm modified mode [ 'www/widgets/basic.html', 438, 420 ]
      ! 488 silly gunzTarPerm extractEntry www/widgets/swipe/css/swipe.css
      ! 489 silly gunzTarPerm modified mode [ 'www/widgets/swipe/css/swipe.css', 438, 420 ]
      ! 490 silly gunzTarPerm extractEntry www/widgets/swipe/doc.html
      ! 491 silly gunzTarPerm modified mode [ 'www/widgets/swipe/doc.html', 438, 420 ]
      ! 492 silly gunzTarPerm extractEntry www/widgets/swipe/img/noSwipe.jpg
      ! 493 silly gunzTarPerm modified mode [ 'www/widgets/swipe/img/noSwipe.jpg', 438, 420 ]
      ! 494 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.roundabout-shapes.js
      ! 495 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.roundabout-shapes.js', 438, 420 ]
      ! 496 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.roundabout.min.js
      ! 497 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.roundabout.min.js', 438, 420 ]
      ! 498 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.touchSwipe.min.js
      ! 499 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.touchSwipe.min.js', 438, 420 ]
      ! 500 silly gunzTarPerm extractEntry www/widgets/tabs/jquery.sliderTabs.js
      ! 501 silly gunzTarPerm modified mode [ 'www/widgets/tabs/jquery.sliderTabs.js', 438, 420 ]
      ! 502 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/indicator.png
      ! 503 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/indicator.png', 438, 420 ]
      ! 504 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/indicatorActive.png
      ! 505 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/indicatorActive.png',
      ! 505 silly gunzTarPerm 438,
      ! 505 silly gunzTarPerm 420 ]
      ! 506 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/leftArrow.png
      ! 507 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/leftArrow.png', 438, 420 ]
      ! 508 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/leftPanelArrow.png
      ! 509 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/leftPanelArrow.png', 438, 420 ]
      ! 510 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/rightArrow.png
      ! 511 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/rightArrow.png', 438, 420 ]
      ! 512 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/rightPanelArrow.png
      ! 513 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/rightPanelArrow.png',
      ! 513 silly gunzTarPerm 438,
      ! 513 silly gunzTarPerm 420 ]
      ! 514 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.css
      ! 515 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.css', 438, 420 ]
      ! 516 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.css.orig
      ! 517 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.css.orig',
      ! 517 silly gunzTarPerm 438,
      ! 517 silly gunzTarPerm 420 ]
      ! 518 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.min.css
      ! 519 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.min.css', 438, 420 ]
      ! 520 silly gunzTarPerm extractEntry www/widgets/tabs.html
      ! 521 silly gunzTarPerm modified mode [ 'www/widgets/tabs.html', 438, 420 ]
      ! 522 silly gunzTarPerm extractEntry www/widgets/todo/dev.html
      ! 523 silly gunzTarPerm modified mode [ 'www/widgets/todo/dev.html', 438, 420 ]
      ! 524 silly gunzTarPerm extractEntry www/widgets/todo/homematic.html
      ! 525 silly gunzTarPerm modified mode [ 'www/widgets/todo/homematic.html', 438, 420 ]
      ! 526 silly gunzTarPerm extractEntry www/widgets/todo/special.html
      ! 527 silly gunzTarPerm modified mode [ 'www/widgets/todo/special.html', 438, 420 ]
      ! 528 silly gunzTarPerm extractEntry www/widgets/todo/swipe.html
      ! 529 silly gunzTarPerm modified mode [ 'www/widgets/todo/swipe.html', 438, 420 ]
      ! 530 silly gunzTarPerm extractEntry www/widgets/todo/weather.html
      ! 531 silly gunzTarPerm modified mode [ 'www/widgets/todo/weather.html', 438, 420 ]
      ! 532 silly gunzTarPerm extractEntry www/widgets/weather-adapter.html
      ! 533 silly gunzTarPerm modified mode [ 'www/widgets/weather-adapter.html', 438, 420 ]
      ! 534 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0/node_modules is being purged
      ! 535 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0/node_modules
      ! 536 silly doParallel preinstall 1
      ! 537 silly preinstall iobroker.vis@0.9.4 /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      ! 538 info lifecycle iobroker.vis@0.9.4~preinstall: iobroker.vis@0.9.4
      ! 539 silly lifecycle iobroker.vis@0.9.4~preinstall: no script for preinstall, continuing
      ! 540 silly doReverseSerial remove 0
      ! 541 silly doSerial move 0
      ! 542 silly doSerial finalize 1
      ! 543 silly finalize /opt/iobroker/node_modules/iobroker.vis
      ! 544 verbose unlock done using /root/.npm/_locks/staging-40fe0fc83e86560c.lock for /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging
      ! 545 silly rollbackFailedOptional Starting
      ! 546 silly rollbackFailedOptional Finishing
      ! 547 silly runTopLevelLifecycles Starting
      ! 548 silly runTopLevelLifecycles Finishing
      ! 549 silly install printInstalled
      ! 550 verbose stack Error: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
      ! 550 verbose stack at whenOldMovedAway (/usr/local/lib/node_modules/npm/lib/install/action/finalize.js:43:5)
      ! 550 verbose stack at /usr/local/lib/node_modules/npm/lib/utils/rename.js:13:14
      ! 550 verbose stack at FSReqWrap.oncomplete (fs.js:117:15)
      ! 550 verbose stack
      ! 550 verbose stack at Error (native)
      ! 551 verbose cwd /opt/iobroker
      ! 552 error FreeBSD 10.2-RELEASE
      ! 553 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "–production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
      ! 554 error node v6.1.0
      ! 555 error npm v3.8.8
      ! 556 error path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
      ! 557 error code ENOENT
      ! 558 error errno -2
      ! 559 error syscall rename
      ! 560 error enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
      ! 561 error enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
      ! 561 error enoent This is most likely not a problem with npm itself
      ! 561 error enoent and is related to npm not being able to find a file.
      ! 562 verbose exit [ -2, true ]
        Можешь поставить node 4.x ?
          boba last edited by
          все тоже самое
          ! root /opt/iobroker # iobroker add vis 0:23
          ! npm install iobroker.vis –production --prefix "/opt/iobroker" (System call)
          ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
          ! npm WARN iobroker No description
          ! npm WARN iobroker No repository field.
          ! npm WARN iobroker No README data
          ! npm WARN iobroker No license field.
          ! host.home.su install adapter vis
          ! npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
          ! npm ERR! FreeBSD 10.2-RELEASE
          ! npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
          ! npm ERR! node v4.4.4
          ! npm ERR! npm v3.8.8
          ! npm ERR! path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
          ! npm ERR! code ENOENT
          ! npm ERR! errno -2
          ! npm ERR! syscall rename
          ! npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
          ! npm ERR! enoent This is most likely not a problem with npm itself
          ! npm ERR! enoent and is related to npm not being able to find a file.
          ! npm ERR! enoent
          ! npm ERR! Please include the following file with any support request:
          ! npm ERR! /opt/iobroker/npm-debug.log
          ! Cannot install iobroker.vis: 254
            А можешь поставить Npm попроще?
            npm install -g npm@2.15.5
              boba last edited by
              заработало.
              спасибо!
                @boba:
                (там неточность небольшая "sudo chmod 777 /opt/iobroker/. -R" ключ после команды должен быть) `
                3 раза прочитал. Так и не понял, что за ключ :?
                  boba last edited by
                  boba ~ % sudo chmod 777 /opt/iobroker/*.* -R
                  chmod: -R: No such file or directory
                  boba ~ % man chmod
                  CHMOD(1)                FreeBSD General Commands Manual               CHMOD(1)
                  NAME
                       chmod — change file modes
                  SYNOPSIS
                       chmod [-fhv] [-R [-H | -L | -P]] mode file ...
                  правильно "sudo chmod -R 777 /opt/iobroker"
                  на счет "." я тоже не уверен, ибо это сменит права только двум скриптам в корне iobroker
