    2. English
    3. ioBroker general
    4. Installation on openSuse failed
      chiabgigi last edited by
      Hello to all
      I'm new to the forum and my name is Luigi.
      I have linux openSuse 64bit installed on vmware, and I'm trying to install ioBroken.
      I installed nodejs, but when I install iobroken I get these errors, even if it finally tells me that it has been installed successfully, but in the browser at http: // myIp: 8081 there is nothing.
      And also in the / opt / iobroker folder I have only one file (illegible): iob
      Here is the result of konsole:
          Welcome to the ioBroker installer!
          Installer version: 2019-07-21
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Il flag q è sconosciuto.
      Installed acl
      Installed sudo
      Installed libcap2-bin
      Installed build-essential
      Installed libavahi-compat-libdnssd-dev
      Installed libudev-dev
      Installed libpam0g-dev
      Installed pkg-config
      Installed git
      Installed curl
      Installed unzip
      sudo: setcap: comando non trovato
          Creating ioBroker user and directory (2/4)
      usermod: group 'iobroker' does not exist
      Created /etc/sudoers.d/iobroker
      chown: gruppo non valido: "luigi:luigi"
      Directory /opt/iobroker created
      touch: impossibile fare touch di '/opt/iobroker/INSTALLER_INFO.txt': Permesso negato
      chmod: impossibile accedere a '/opt/iobroker/INSTALLER_INFO.txt': File o directory non esistente
      bash: riga 458: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
      bash: riga 459: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
      bash: riga 460: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
          Installing ioBroker (3/4)
      bash: riga 472: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
      /usr/bin/node10: error while loading shared libraries: libicui18n.so.suse64.2: cannot open shared object file: No such file or directory
          Finalizing installation (4/4)
      bash: riga 498: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
      bash: riga 569: /opt/iobroker/iobroker: Permesso negato
      chmod: impossibile accedere a '/opt/iobroker/iobroker': File o directory non esistente
      Enabling autostart...
      chown: impossibile accedere a '/lib/systemd/system/iobroker.service': File o directory non esistente
      chmod: impossibile accedere a '/lib/systemd/system/iobroker.service': File o directory non esistente
      Failed to enable unit: Unit file iobroker.service does not exist.
      Failed to start iobroker.service: Unit iobroker.service not found.
      Autostart enabled!
      bash: riga 717: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
      chown: gruppo non valido: "iobroker:iobroker"
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
      main: riga 601: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
          ioBroker was installed successfully
          Open http://192.168.116.133:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      luigi@localhost:~> iobroker stop
      If 'iobroker' is not a typo you can use command-not-found to lookup the package that contains it, like this:
          cnf iobroker
      luigi@localhost:~> sudo mkdir /home/iobroker
      [sudo] password di root:
      mkdir: impossibile creare la directory "/home/iobroker": File già esistente
      luigi@localhost:~> sudo chown iobroker /home/iobroker
      luigi@localhost:~> iobroken start
      If 'iobroken' is not a typo you can use command-not-found to lookup the package that contains it, like this:
          cnf iobroken
      luigi@localhost:~>
      tanks
        jrjong11 @chiabgigi last edited by jrjong11
        @chiabgigi said in Installation on openSuse failed:
        Hello to all
        I installed nodejs, but when https aka ms remoteconnect I install iobroken I get these errors, even if it finally tells me that it has been installed successfully, but in the browser at http: // myIp: 8081 there is nothing.
        Installed acl
        Installed sudo
        Installed git
        Installed curl
        Installed unzip
        Autostart enabled!
            cnf iobroker
        mkdir: impossibile [https aka ms remoteconnect](https://one2step.net/aka-ms-remoteconnect-minecraft/) creare la directory "/home/iobroker": File già esistente
            cnf iobroken
        luigi@localhost:~>
        tanks
        Any update on this OP? I'm having the same issue here.
        Thanks in advane
        Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @jrjong11 last edited by
          @jrjong11
          Try installing in a debian based distribution.
          • Asgothian
            Asgothian Developer @jrjong11 last edited by
            @jrjong11
            If I look at the generated errors (and assuming I translate them correctly) the Skript fails at 3 points:
            • setcap: either the command does not exist or it cannot be used with sudo
            Sudo: setcap: comando non trovato
            • creating the user iobroker and group iobroker seems to fail
            • creating the folder /opt/iobroker seems to fail due to lack of permissions.
            @Thomas-Braun mentioned the easy way out - use a Debian based Linux as basis.
            If you want to keep opensuse, you can try the following steps:
            • create a user and group iobroker (without password, the user does not need to log on
            • create a folder /opt/iobroker and „chown“ it to iobroker
            • ensure that the user iobroker is allowed to use sudo
            • Run the script again.
            A.
            opensuse
