    3. Tester
    4. Test Adapter z-wave v1.6.x
      cburghardt last edited by Jey Cee
      Der z-wave Adapter der 1.6 Reihe hat schon einige Zyklen hinter sich und ich denke, die gerade im latest verfügbare Version 1.6.3 ist ein guter Kandidat für stable.
      Dazu benötigen wir aber noch mehr Tester, also ran an die z-wave Controller.
        Stormbringer @cburghardt last edited by Jey Cee
        @cburghardt Wollts grad für dich testen... Installation über die Katze kommt:
        iobroker	2019-10-07 17:42:19.283	info	exit 0
        iobroker	2019-10-07 17:42:19.280	error	Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
        iobroker	2019-10-07 17:42:19.249	info	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-10-07T15_42_19_237Z-debug.log
        iobroker	2019-10-07 17:42:19.228	info	Failed at the iobroker.zwave@1.6.3 preinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        iobroker	2019-10-07 17:42:19.228	info	npm ERR!
        iobroker	2019-10-07 17:42:19.228	info	npm ERR! Exit status 1
        iobroker	2019-10-07 17:42:19.228	info	npm ERR! iobroker.zwave@1.6.3 preinstall: `node lib/preinstall.js`
        iobroker	2019-10-07 17:42:19.228	info	ERR! code ELIFECYCLEnpm ERR! errno 1
        iobroker	2019-10-07 17:42:19.227	info	npm
        iobroker	2019-10-07 17:42:19.219	info
        iobroker	2019-10-07 17:42:19.218	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2019-10-07 17:42:19.218	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
        iobroker	2019-10-07 17:42:19.218	info	npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
        iobroker	2019-10-07 17:42:19.218	info	npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
        iobroker	2019-10-07 17:42:19.218	info	babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is
        iobroker	2019-10-07 17:42:16.581	info	at tryModuleLoad (module.js:506:12)
        iobroker	2019-10-07 17:42:16.581	info	at Module.load (module.js:566:32)
        iobroker	2019-10-07 17:42:16.581	info	at Object.Module._extensions..js (module.js:664:10)
        iobroker	2019-10-07 17:42:16.581	info	at Module._compile (module.js:653:30)
        iobroker	2019-10-07 17:42:16.581	info	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:27:7)
        iobroker	2019-10-07 17:42:16.581	info	at installOpenZwave (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:139:3)
        iobroker	2019-10-07 17:42:16.581	info	at installOpenZwaveFromSource (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:144:3)
        iobroker	2019-10-07 17:42:16.581	info	at doScript (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:13:15)
        iobroker	2019-10-07 17:42:16.581	info	at Object.execSync (child_process.js:647:13)
        iobroker	2019-10-07 17:42:16.581	info	at checkExecSyncError (child_process.js:607:13)
        iobroker	2019-10-07 17:42:16.581	info	0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0
        iobroker	2019-10-07 17:42:16.581	info	Dload Upload Total Spent Left Speed
        iobroker	2019-10-07 17:42:16.581	info	% Total % Received % Xferd Average Speed Time Time Time Current
        iobroker	2019-10-07 17:42:16.581	info	Error: Command failed: curl -L -O http://old.openzwave.com/downloads/openzwave-1.6.918.zip
        iobroker	2019-10-07 17:42:16.581	info	^
        iobroker	2019-10-07 17:42:16.581	info	/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:16 if (!suppressException) throw e;
        iobroker	2019-10-07 17:42:16.578	info	0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0
        iobroker	2019-10-07 17:42:16.578	info	% Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/ssl/private": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/polkit-1/localauthority": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/ppp/peers": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/cups/ssl": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/chatscripts": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ipfw": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/mon": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/squid": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/iscsi-target": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/sendmail": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/qmailadmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/postfix": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/smf": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/dhcpd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ajaxterm": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/change-user": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/htaccess-htpasswd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/acl": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cpan": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/apache": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/pap": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ipsec": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/raid": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/syslog-ng": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/filter": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/openslp": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/lvm": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/phpini": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/file": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/nis": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/webalizer": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/smart-status": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/telnet": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/quota": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/at": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/sshd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/custom": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/usermin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/proftpd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-cron": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/tunnel": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-passwd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/logrotate": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/servers": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ldap-useradmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/inittab": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/fsdump": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-copy": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/heartbeat": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/useradmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/xinetd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/man": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/samba": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/shorewall": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/pam": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/webmincron": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/system-status": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/package-updates": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/tcpwrappers": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/software": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/filemin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-software": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/shell": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/bind8": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/net": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/krb5": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/fdisk": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/iscsi-tgtd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/pptp-server": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ldap-server": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/inetd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/exim": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/postgresql": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/lpadmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/vgetty": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/sarg": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/exports": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/dovecot": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/burner": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/pptp-client": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/spam": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/time": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/jabber": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/stunnel": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/dfsadmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ldap-client": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/wuftpd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/firewall": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/status": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/fetchmail": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/init": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/idmapd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/mysql": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/syslog": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-usermin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/fail2ban": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-shell": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/mount": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/passwd": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/iscsi-server": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ipfilter": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/procmail": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/backup-config": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/bandwidth": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/grub": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/webmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/updown": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/mailboxes": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/shorewall6": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/bacula-backup": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cron": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/firewall6": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/iscsi-client": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/firewalld": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/proc": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/cluster-webmin": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/adsl-client": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/webminlog": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/mailcap": Keine Berechtigung
        iobroker	2019-10-07 17:42:11.406	info	find: "/etc/webmin/ppp-client": Keine Berechtigungfind: "/etc/webmin/cluster-useradmin": Keine Berechtigung
        NPM Version 6.4.1
        Node Version 8.16.0
        Fixer das letzte mal ausgeführt vor ca. 3 Wochen
        Ist das wieder der Lifecycle Spaß oder brauch ich eine neuere Node Version? Muss ich dafür dann den alten Adapter deinstallieren?
          cburghardt last edited by cburghardt
          @Stormbringer said in [Aufruf] z-wave 1.6.3 testen:
          Diese ganzen "Keine Berechtigung" sind harmlos, aber es scheitert an dem obigen Aufruf.
          Was passiert wenn du das Kommando manuell ausführst?
          Und nein, die node Version passt und der vorherige Adapter muss nicht deinstalliert werden.
            @cburghardt sagte in [Aufruf] z-wave 1.6.3 testen:
            Scheint zu gehen
            curl -L -O http://old.openzwave.com/downloads/openzwave-1.6.918.zip % Total % Received % Xferd Average Speed Time Time Time Current
            100 13.0M 100 13.0M 0 0 2631k 0 0:00:05 0:00:05 --:--:-- 3145k
              Stormbringer @cburghardt last edited by Stormbringer
              @cburghardt
              Jetzt rennt es auch bei der Katze durch
              $ ./iobroker url "https://github.com/ioBroker/ioBroker.zwave/tarball/master" zwave
              install https://github.com/ioBroker/ioBroker.zwave/tarball/master
              npm install https://github.com/ioBroker/ioBroker.zwave/tarball/master --production --save --prefix "/opt/iobroker" (System call)
              0 13.0M 0 2896 0 0 11018 0 0:20:38 --:--:-- 0:20:38 11011
              0 13.0M 0 103k 0 0 85651 0 0:02:39 0:00:01 0:02:38 85612
              2 13.0M 2 360k 0 0 159k 0 0:01:23 0:00:02 0:01:21 159k
              6 13.0M 6 918k 0 0 282k 0 0:00:47 0:00:03 0:00:44 282k
              15 13.0M 15 2060k 0 0 486k 0 0:00:27 0:00:04 0:00:23 486k
              29 13.0M 29 3908k 0 0 743k 0 0:00:17 0:00:05 0:00:12 781k
              50 13.0M 50 6708k 0 0 1075k 0 0:00:12 0:00:06 0:00:06 1321k
              80 13.0M 80 10.5M 0 0 1490k 0 0:00:08 0:00:07 0:00:01 2097k
              100 13.0M 100 13.0M 0 0 1725k 0 0:00:07 0:00:07 --:--:-- 2776k
              Makefile:249: Documentation not being built
              npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.npm WARN
              react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
              got /opt/iobroker/node_modules/iobroker.zwave/admin
              upload [20] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleepOn.png img/sleepOn.png image/png
              upload [19] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleep.png img/sleep.png image/png
              upload [18] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/readyOn.png img/readyOn.png image/png
              upload [17] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/ready.png img/ready.png image/png
              upload [16] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/neighbors.png img/neighbors.png image/png
              upload [15] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/heal.png img/heal.png image/png
              upload [14] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/hard-reset.png img/hard-reset.png image/png
              upload [13] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/delete.png img/delete.png image/png
              upload [12] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/aliveOn.png img/aliveOn.png image/png
              upload [11] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/alive.png img/alive.png image/png
              upload [10] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/add.png img/add.png image/png
              upload [9] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [8] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [7] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [6] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [5] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [4] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [3] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [2] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [1] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [0] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/i18n/de/translations.json i18n/de/translations.json application/json
              process exited with code 0
              Aber in der Adapterübersicht ist er jetzt komplett weg. Erst bei wechseln wieder auf Default kommt er wieder. Bei Instanzen bleibt er da... Danke, ich teste dann mal.
              Ist "Makefile:249: Documentation not being built" schlimm?
                Nein, es gibt wohl keine Doku 😉
                @AlCalzone bei der Installation scheint es manchmal Probleme mit der Auflösung von old.openzwave.com zu geben, das sieht man auch bei travis. Irgendeine Idee was man da machen kann?
                  @cburghardt Also Scan ist fertig.... So wie es aussieht verhält sich jetzt die 1.6.3 wieder so wie die schlimmen alten Z Wave Adapter Versionen. Sprich er kennt wieder die meisten Geräte nicht...
                  Bisher war die 1.6.0 die einzige die echt Top war. Die verhält sich so wie andere Adapter ala Deconz oder Hue. Die erkennt ihre Geräte nach Neustart wieder. Sowohl Strom als auch Batterie. Bei der Version 1.6.3 müsste man wohl wieder viel Vodoo aufbringen um die einzelnen Nodes zu überreden wieder zu gehen? Gehen tun grad ca. 80 % der strombetriebenen Aeon Multi 6 Sensoren, Fibaro Augen melden alle nix mehr... Fibaro Tür und Rauchmelder auch nicht... Sensative Strip und Comfort nada... Und Danalock auch nicht wie es scheint. Also quasi alle batteriebetriebenen bocken und 20 % der Strombetriebenen.
                    1.6.0 und 1.6.3 unterscheiden sich nur marginal von der openzwave Version.
                    @Stormbringer Wenn du sagst, er erkennt die Geräte nicht, was genau meinst du? Werden sie nicht als bereit markiert?
                    Batterie betriebene Geräte müssen aufwachen um abgefragt zu werden, das ist bei z-wave immer so. Entweder du wartest so lange, oder weckst sie auf.
                    Wenn Strombetriebene nicht gehen, sind sie schlecht erreichbar, ich habe das hier bei einem Fibaro Switch, der alle paar Wochen mal die Verbindung verliert und dann nach einem Neustart als tot markiert wird. Den wecke ich per Schalter auf und gut ist es.
                    In der Version wurden beispielsweise auch Fibaro Definitionen von openzwave gefixt, das sieht mittlerweile viel besser aus.
                      @cburghardt Habe jetzt 2 angeschaut. Der Strombetriebene wird als Ready und Alive true angezeigt und das Fibaro Auge mit Sleep true.
                      Der Unterschied zwischen Zigbee und Z Wave ist mir schon bekannt. Aber unter aufwecken verstehe ich auch, dass das Gerät einen Zustand erkennt. Sprich wenn ich an einem Bewegungssensor vorbeigehe und er aufblinkt muss er auch wach sein und senden... Empfangsprobleme kann ich, wie immer zu 1000 % ausschließen. Könnte die Sensoren maimal noch übereinander stapeln ;D Du hast ja meine Karte auf Github gesehen. 100 Nodes auf einer 80 qm Wohnung dürften langen denke ich g
                      Ich kenne die Z-Wave Antworten schon... Aber die 1.60. hatte die nicht. Die war TOP. Auch wenn es mir nie einer glaubt g
                      Wie kann ich wieder zurück auf die ohne grosse Verluste?
                      C 2 Replies Last reply Reply Quote 0
                        LaplaceII last edited by
                        Hallo, ich habe die neue Version schon ein paar Tage laufen. Bis auf kleine Änderung bei den ObjektIDs von wenigen Geräten, funktioniert alles soweit. Die batteriebetrieben Geräte funktionieren auch...es dauert halt bis diese korrekt eingebunden sind. Wem das zu langsam geht: Manuelles WakeUp und die Einbindung funktioniert ad-hoc. Danke für die Mühen!!
                        S C 2 Replies Last reply Reply Quote 0
                          Stormbringer @LaplaceII last edited by Stormbringer
                          @LaplaceII Denke ich kommt auf die Größe vom Netzwerk an. Wenn ich nur ein paar battierebetriebene habe würde mir das auch nichts ausmachen 😉 Aber denke wird keiner freiwillig bei 50 Geräten drei mal den Kopf drückt damit das SmartHome wieder funktioniert, wenns bei der 1.6.0 einwandfrei funktioniert. Und die Zeit hast so lang wie du gern im dunkeln hockst oder fürs Fenster raus heizt.... ;o)
                            cburghardt @Stormbringer last edited by
                            @Stormbringer das ist leider z-wave Standard, bei einem Neustart ist der Scan Pflicht und da müssen sich die Geräte zurückmelden. Das war bei der 1.6.0 genauso.
                              cburghardt @Stormbringer last edited by cburghardt
                              Du kannst die Version über npm manuell installieren schätze ich. Aber das Start-Verhalten wird identisch sein. Aber dann hast du einige Bugs wieder zurück und keine Karte 😉
                              Allerdings werde ich aus der Erklärung des Status nicht ganz schlau. Du hast Geräte die bereits auf alive stehen und trotzdem keine Daten liefern? Welche Geräte sind das und welche Daten kommen nicht rein?
                                Im normalen Betrieb stimmt das. Aber beim Scan nach einem Neustart muss das Gerät erst aufwachen und das passiert bei einer Bewegungsmeldung nicht. Sonst wären die Batterien nach kurzer Zeit leer.
                                  cburghardt @LaplaceII last edited by
                                  @LaplaceII Danke für die Rückmeldung!
                                    @cburghardt wär nett, wenn du mir eine genaue anleitung geben könntest? 🙈🙈
                                      @cburghardt Scan ist klar, der ist ja schon lange abgeschlossen 😉Adapter ist grün
                                        @cburghardt Primär sind es Schlüsseldaten wie beim Bewegungsmelder > Bewegung erkannt. Wassersensor > Feucht, Fenstersensor > offen/zu. Auch wenns mir keiner glaubt bei 1.6.0 hat er das erkannt. wenn er die Sensoren beim Neustart nicht erkannt hat dann spätestens bei Betätigung. Oder meinst das ist nur beim ersten mal nach dem Update so? Ne oder so wie ich es verstehe?
                                          @Stormbringer ich formuliere es mal anders: solange das Gerät sich nicht aktiv nach dem Scan gemeldet hat, werden Statusmeldungen ignoriert. Also auch wenn der Adapter grün ist, werden Daten von einem Gerät nicht berücksichtigt, solange es nicht einmal aufgewacht ist. Das war in jeder Version des Adapters identisch.
                                          Installation einer bestimmten Version: in der Liste der Adapter den Expertenmodus aktivieren. Dann gibt es beim Adapter die Option "Bestimmte Version installieren".
                                          S AlCalzone 2 Replies Last reply Reply Quote 0
                                            Hm, dass eine unmittelbare Einbindung batteriebetriebener Geräte bei der 1.60 Version funktioniert hat, konnte ich nicht beobachten bzw habe ich nicht explizit drauf geachtet. Wäre natürlich klasse wenn dem so wäre...ich habe auch einige dieser devices.
                                            31.7k
                                            79.8k
                                            tester z-wave
                                            10
                                            101
                                            8087
