    3. Entwicklung
    4. Problem beim Adapter Test
      SchuetzeSchulz last edited by
      ich bekomme folgenden Fehler beim Build Test des LGTV Adapters:
      Travis CI
          There are no broadcasts
          Dashboard
          Changelog
          Documentation
          Help
          Sebastian Schultz avatar
      SebastianSchultz / ioBroker.lgtv
      build:passed
          Current
          Branches
          Build History
          Pull Requests
          Build #35
          Job #35.1
      Pull Request #42 Update lgtv.js
      Commit 871d26f
      #42: Update lgtv.js
      Branch master
      Vladimir Vilisov avatar Vladimir Vilisov
      #35.1 failed
      Ran for 2 min 2 sec
          6 minutes ago
      Node.js: 6
      CXX=g++-6
          Job log
          View config
      Raw log
      0.19s0.08s
      worker_info
      Worker information
      0.18s0.01s0.00s0.01s
      system_info
      Build system information
      0.01s0.49s0.00s0.00s0.00s0.01s0.00s0.15s0.01s1.07s0.00s0.00s0.05s0.00s2.99s0.00s2.33s
      docker_mtu
      resolvconf
      apt
      Adding APT Sources
      0.00s
      git.checkout
      0.75s$ git clone --depth=50 https://github.com/SebastianSchultz/ioBroker.lgtv.git SebastianSchultz/ioBroker.lgtv
      0.01s
      Setting environment variables from .travis.yml
      $ export CXX=g++-6
      nvm.install
      3.52s$ nvm install 6
      cache.1
      Setting up build cache
      cache.npm
      $ node --version
      v6.17.1
      $ npm --version
      3.10.10
      $ nvm --version
      0.34.0
      install.npm
      2.28s$ npm install
      before_script.1
      0.22s$ export NPMVERSION=$(echo "$($(which npm) -v)"|cut -c1)
      before_script.2
      0.00s$ if [[ $NPMVERSION == 5 ]]; then npm install -g npm@5; fi
      before_script.3
      0.22s$ npm -v
      1.10s$ npm run test:package
      > iobroker.lgtv@1.0.8 test:package /home/travis/build/SebastianSchultz/ioBroker.lgtv
      > mocha test/package --exit
        Validate the package files
          Ensure they are readable
            package.json
              ✓ exists
              ✓ contains valid JSON
              ✓ is an object
            io-package.json
              ✓ exists
              ✓ is an object
          Check contents of package.json
            ✓ The property "name" exists
            ✓ The property "version" exists
            ✓ The property "description" exists
            ✓ The property "author" exists
            ✓ The property "license" exists
            ✓ The property "main" exists
            ✓ The property "repository" exists
            ✓ The property "repository.type" exists
            ✓ The package name is correct
            ✓ The repository type is "git"
          Check contents of io-package.json
            ✓ The property "common.name" exists
            ✓ The property "common.title" exists
            ✓ The property "common.version" exists
            1) The property "common.news" exists
            ✓ The property "common.desc" exists
            ✓ The property "common.icon" exists
            ✓ The property "common.extIcon" exists
            ✓ The property "common.license" exists
            ✓ The property "common.type" exists
            ✓ The property "common.authors" exists
            ✓ The property "native" exists
            ✓ The title does not contain "adapter" or "iobroker"
            ✓ The description is an object to support multiple languages
            ✓ common.authors is an array that is not empty
            ✓ Materialize is supported
          Compare contents of package.json and io-package.json
            ✓ The name matches
            ✓ The version matches
            ✓ The license matches
        33 passing (33ms)
        1 failing
        1) Validate the package files
               The property "common.news" exists:
           AssertionError: expected undefined not to be undefined
            at Context.it (node_modules/@iobroker/testing/build/tests/packageFiles/index.js:46:52)
      npm ERR! Linux 4.15.0-1028-gcp
      npm ERR! argv "/home/travis/.nvm/versions/node/v6.17.1/bin/node" "/home/travis/.nvm/versions/node/v6.17.1/bin/npm" "run" "test:package"
      npm ERR! node v6.17.1
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.lgtv@1.0.8 test:package: `mocha test/package --exit`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.lgtv@1.0.8 test:package script 'mocha test/package --exit'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the iobroker.lgtv package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     mocha test/package --exit
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.lgtv
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls iobroker.lgtv
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /home/travis/build/SebastianSchultz/ioBroker.lgtv/npm-debug.log
      The command "npm run test:package" exited with 1.
      1.15s$ npm run test:unit
      > iobroker.lgtv@1.0.8 test:unit /home/travis/build/SebastianSchultz/ioBroker.lgtv
      > mocha test/unit --exit
        Test the adapter (in a mocked environment)
          ✓ The adapter starts in normal mode (77ms)
          ✓ The adapter starts in compact mode (39ms)
        2 passing (127ms)
      The command "npm run test:unit" exited with 0.
      40.71s$ npm run test:integration
      > iobroker.lgtv@1.0.8 test:integration /home/travis/build/SebastianSchultz/ioBroker.lgtv
      > mocha test/integration --exit
      Running tests in /tmp/test-iobroker.lgtv
        Test the adapter (in a live environment)
      > iobroker.js-controller@2.0.24 preinstall /tmp/test-iobroker.lgtv/node_modules/.staging/iobroker.js-controller-03cd5130
      > node lib/preinstallCheck.js
      NPM version: 3.10.10
      > diskusage@1.1.3 install /tmp/test-iobroker.lgtv/node_modules/diskusage
      > node-gyp rebuild
      make: Entering directory '/tmp/test-iobroker.lgtv/node_modules/diskusage/build'
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Leaving directory '/tmp/test-iobroker.lgtv/node_modules/diskusage/build'
      > unix-dgram@2.0.3 install /tmp/test-iobroker.lgtv/node_modules/unix-dgram
      > node-gyp rebuild
      make: Entering directory '/tmp/test-iobroker.lgtv/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Leaving directory '/tmp/test-iobroker.lgtv/node_modules/unix-dgram/build'
      > ursa-optional@0.9.10 install /tmp/test-iobroker.lgtv/node_modules/ursa-optional
      > node rebuild.js
      > websocket@1.0.30 install /tmp/test-iobroker.lgtv/node_modules/websocket
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      make: Entering directory '/tmp/test-iobroker.lgtv/node_modules/websocket/build'
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
        COPY Release/bufferutil.node
        CXX(target) Release/obj.target/validation/src/validation.o
        SOLINK_MODULE(target) Release/obj.target/validation.node
        COPY Release/validation.node
      make: Leaving directory '/tmp/test-iobroker.lgtv/node_modules/websocket/build'
      > iobroker.js-controller@2.0.24 install /tmp/test-iobroker.lgtv/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      /tmp/test-iobroker.lgtv/node_modules/chokidar/index.js:141
        async remove(item) {
      SyntaxError: Unexpected identifier
          at createScript (vm.js:56:10)
          at Object.runInThisContext (vm.js:97:10)
          at Module._compile (module.js:549:28)
          at Object.Module._extensions..js (module.js:586:10)
          at Module.load (module.js:494:32)
          at tryModuleLoad (module.js:453:12)
          at Function.Module._load (module.js:445:3)
          at Module.require (module.js:504:17)
          at require (internal/module.js:20:19)
          at Object.<anonymous> (/tmp/test-iobroker.lgtv/node_modules/iobroker.js-controller/lib/cli/cliLogs.js:5:18)
      test-iobroker.lgtv@1.0.0 /tmp/test-iobroker.lgtv
      └─┬ iobroker.lgtv@1.0.8
        ├─┬ @iobroker/adapter-core@1.0.3
        │ └─┬ @types/iobroker@1.4.11
        │   └── @types/node@12.7.11
        ├─┬ lgtv2@1.4.1
        │ ├─┬ mkdirp@0.5.1
        │ │ └── minimist@0.0.8
        │ └── persist-path@1.0.2
        └─┬ websocket@1.0.30
          ├─┬ debug@2.6.9
          │ └── ms@2.0.0
          ├── nan@2.14.0
          ├─┬ typedarray-to-buffer@3.1.5
          │ └── is-typedarray@1.0.0
          └── yaeti@0.0.6
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN test-iobroker.lgtv@1.0.0 No description
      npm WARN test-iobroker.lgtv@1.0.0 No repository field.
      npm ERR! argv "/home/travis/.nvm/versions/node/v6.17.1/bin/node" "/home/travis/.nvm/versions/node/v6.17.1/bin/npm" "i" "--production"
      npm ERR! iobroker.js-controller@2.0.24 install: `node iobroker.js setup first`
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@2.0.24 install script 'node iobroker.js setup first'.
      npm ERR! If you do, this is most likely a problem with the iobroker.js-controller package,
      npm ERR!     node iobroker.js setup first
      npm ERR!     npm bugs iobroker.js-controller
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR!     /tmp/test-iobroker.lgtv/npm-debug.log
          1) "before all" hook for "The adapter starts"
        0 passing (40s)
        1 failing
        1) Test the adapter (in a live environment)
             "before all" hook for "The adapter starts":
           Error: Cannot find module '/tmp/test-iobroker.lgtv/iobroker-data/iobroker.json'
            at ControllerSetup.<anonymous> (node_modules/@iobroker/testing/build/tests/integration/lib/controllerSetup.js:176:34)
            at next (native)
            at /home/travis/build/SebastianSchultz/ioBroker.lgtv/node_modules/@iobroker/testing/build/tests/integration/lib/controllerSetup.js:7:71
            at __awaiter (node_modules/@iobroker/testing/build/tests/integration/lib/controllerSetup.js:3:12)
            at ControllerSetup.setupSystemConfig (node_modules/@iobroker/testing/build/tests/integration/lib/controllerSetup.js:173:16)
            at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/integration/index.js:62:39)
            at next (native)
            at fulfilled (node_modules/@iobroker/testing/build/tests/integration/index.js:5:58)
            at process._tickCallback (internal/process/next_tick.js:109:7)
      npm ERR! argv "/home/travis/.nvm/versions/node/v6.17.1/bin/node" "/home/travis/.nvm/versions/node/v6.17.1/bin/npm" "run" "test:integration"
      0mnpm ERR! node v6.17.1
      npm ERR! iobroker.lgtv@1.0.8 test:integration: `mocha test/integration --exit`
      npm ERR!
      npm ERR! Failed at the iobroker.lgtv@1.0.8 test:integration script 'mocha test/integration --exit'.
      npm ERR!     mocha test/integration --exit
      The command "npm run test:integration" exited with 1.
      cache.2
      store build cache
      Done. Your build exited with 1.
      Top
          My Repositories
      35
      Duration: 8 min 17 sec
      SebastianSchultz/ioBroker.enet
      26
      Duration: 31 min 34 sec
      Finished: 4 months ago
      SebastianSchultz/ioBroker.lgtv11
      24
      Duration: 59 min 25 sec
      Finished: 5 months ago
      SebastianSchultz/ioBroker.hp-ilo
      33
      Duration: 1 hr 3 min 57 sec
      ©Travis CI, GmbH
      Rigaer Straße 8
      10247 Berlin, Germany
          Work with Travis CI
          Blog
          Email
          Twitter
      Help
          Documentation
          Changelog
      Legal
          Imprint
          Terms of Service
          Privacy Policy
          Security Statement
      Travis CI Status
          Travis CI Status
      kann da mal jemand drüber schauen? Ich finde den Fehler leider nicht 😞
      • Jey Cee
        Jey Cee Developer last edited by Jey Cee
        news ist kein Child von common in deiner io-package.json.
          Hallo Jey Cee,
          danke das war's wirklich 🙂
          Allerdings schlagen alle Node 6 Tests fehl, egal welche Plattform:
          Build started
          git clone -q --branch=master https://github.com/SebastianSchultz/ioBroker.lgtv.git c:\projects\ioBroker.lgtv
          git checkout -qf b1e0854602d3d56140e78c42cb1c22e46ea5e6ae
          Running Install scripts
          Update-NodeJsInstallation (Get-NodeJsLatestBuild $env:nodejs_version) $env:platform
          Updating Node.js v6.17.1 (x86)
          Uninstalling Node.js v8.16.0 (x86)...
          Installing Node.js v6.17.1 (x86)...
          $NpmVersion = (npm -v).Substring(0,1)
          if($NpmVersion -eq 5) { npm install -g npm@5 }
          npm --version
          3.10.10
          npm install
          npm WARN deprecated hawk@7.0.10: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
          npm WARN deprecated cryptiles@4.1.3: This module has moved and is now available at @hapi/cryptiles. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated boom@7.3.0: This module has moved and is now available at @hapi/boom. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated sntp@3.0.2: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
          npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated b64@4.1.2: This module has moved and is now available at @hapi/b64. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated bounce@1.2.3: This module has moved and is now available at @hapi/bounce. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated teamwork@3.2.0: This module has moved and is now available at @hapi/teamwork. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
          npm WARN deprecated jscs-preset-wikimedia@1.0.1: Deprecated in favour of eslint-config-wikimedia. -- https://phabricator.wikimedia.org/T118941
          npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
          npm WARN prefer global coffeescript@1.10.0 should be installed with -g
          npm WARN prefer global jsonlint@1.6.3 should be installed with -g
          npm WARN prefer global jshint@2.9.7 should be installed with -g
          npm WARN prefer global node-gyp@3.8.0 should be installed with -g
          > iltorb@1.3.10 install C:\projects\ioBroker.lgtv\node_modules\iltorb
          > detect-libc prebuild-install || node-gyp rebuild
          > websocket@1.0.30 install C:\projects\ioBroker.lgtv\node_modules\websocket
          C:\projects\ioBroker.lgtv\node_modules\websocket>if not defined npm_config_node_gyp (node "C:\Program Files (x86)\nodejs\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "" rebuild )
          Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
            bufferutil.cc
            win_delay_load_hook.cc
               Creating library C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\bufferutil.lib and object C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\bufferutil.exp
            Generating code
            Finished generating code
            bufferutil.vcxproj -> C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\\bufferutil.node
            bufferutil.vcxproj -> C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\bufferutil.pdb (Full PDB)
            validation.cc
               Creating library C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\validation.lib and object C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\validation.exp
            Generating code
            validation.vcxproj -> C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\\validation.node
            validation.vcxproj -> C:\projects\ioBroker.lgtv\node_modules\websocket\build\Release\validation.pdb (Full PDB)
          > core-js@2.6.9 postinstall C:\projects\ioBroker.lgtv\node_modules\core-js
          > node scripts/postinstall || echo "ignore"
          iobroker.lgtv@1.0.8 C:\projects\ioBroker.lgtv
          +-- @iobroker/adapter-core@1.0.3
          | `-- @types/iobroker@1.4.11
          |   `-- @types/node@12.7.11
          +-- @iobroker/testing@1.2.5
          | +-- alcalzone-shared@2.0.0
          | | `-- debug@4.1.1
          | |   `-- ms@2.1.2
          | +-- chai-as-promised@7.1.1
          | +-- debug@4.1.1
          | | `-- ms@2.1.2
          | +-- fs-extra@8.1.0
          | | +-- graceful-fs@4.2.2
          | | +-- jsonfile@4.0.0
          | | `-- universalify@0.1.2
          | +-- sinon@7.5.0
          | | +-- @sinonjs/commons@1.6.0
          | | +-- @sinonjs/formatio@3.2.2
          | | +-- @sinonjs/samsam@3.3.3
          | | | `-- array-from@2.1.1
          | | +-- lolex@4.2.0
          | | +-- nise@1.5.2
          | | | +-- @sinonjs/text-encoding@0.7.1
          | | | +-- just-extend@4.0.2
          | | | `-- path-to-regexp@1.7.0
          | | |   `-- isarray@0.0.1
          | | `-- supports-color@5.5.0
          | `-- sinon-chai@3.3.0
          +-- chai@4.2.0
          | +-- assertion-error@1.1.0
          | +-- check-error@1.0.2
          | +-- deep-eql@3.0.1
          | +-- get-func-name@2.0.0
          | +-- pathval@1.1.0
          | `-- type-detect@4.0.8
          +-- grunt@1.0.4
          | +-- coffeescript@1.10.0
          | +-- dateformat@1.0.12
          | | +-- get-stdin@4.0.1
          | | `-- meow@3.7.0
          | |   +-- camelcase-keys@2.1.0
          | |   | `-- camelcase@2.1.1
          | |   +-- loud-rejection@1.6.0
          | |   | +-- currently-unhandled@0.4.1
          | |   | | `-- array-find-index@1.0.2
          | |   | `-- signal-exit@3.0.2
          | |   +-- map-obj@1.0.1
          | |   +-- minimist@1.2.0
          | |   +-- normalize-package-data@2.5.0
          | |   | +-- hosted-git-info@2.8.5
          | |   | `-- validate-npm-package-license@3.0.4
          | |   |   +-- spdx-correct@3.1.0
          | |   |   | `-- spdx-license-ids@3.0.5
          | |   |   `-- spdx-expression-parse@3.0.0
          | |   |     `-- spdx-exceptions@2.2.0
          | |   +-- object-assign@4.1.1
          | |   +-- read-pkg-up@1.0.1
          | |   | +-- find-up@1.1.2
          | |   | | +-- path-exists@2.1.0
          | |   | | `-- pinkie-promise@2.0.1
          | |   | |   `-- pinkie@2.0.4
          | |   | `-- read-pkg@1.1.0
          | |   |   +-- load-json-file@1.1.0
          | |   |   | +-- parse-json@2.2.0
          | |   |   | | `-- error-ex@1.3.2
          | |   |   | |   `-- is-arrayish@0.2.1
          | |   |   | `-- pify@2.3.0
          | |   |   `-- path-type@1.1.0
          | |   +-- redent@1.0.0
          | |   | +-- indent-string@2.1.0
          | |   | | `-- repeating@2.0.1
          | |   | |   `-- is-finite@1.0.2
          | |   | |     `-- number-is-nan@1.0.1
          | |   | `-- strip-indent@1.0.1
          | |   `-- trim-newlines@1.0.0
          | +-- eventemitter2@0.4.14
          | +-- exit@0.1.2
          | +-- findup-sync@0.3.0
          | | `-- glob@5.0.15
          | +-- glob@7.0.6
          | | +-- fs.realpath@1.0.0
          | | +-- inflight@1.0.6
          | | | `-- wrappy@1.0.2
          | | +-- inherits@2.0.4
          | | `-- once@1.4.0
          | +-- grunt-cli@1.2.0
          | | `-- resolve@1.1.7
          | +-- grunt-known-options@1.1.1
          | +-- grunt-legacy-log@2.0.0
          | | +-- colors@1.1.2
          | | `-- grunt-legacy-log-utils@2.0.1
          | +-- grunt-legacy-util@1.1.1
          | | +-- getobject@0.1.0
          | | `-- underscore.string@3.3.5
          | |   +-- sprintf-js@1.0.3
          | |   `-- util-deprecate@1.0.2
          | +-- iconv-lite@0.4.24
          | | `-- safer-buffer@2.1.2
          | +-- js-yaml@3.13.1
          | | +-- argparse@1.0.10
          | | `-- esprima@4.0.1
          | +-- minimatch@3.0.4
          | | `-- brace-expansion@1.1.11
          | |   +-- balanced-match@1.0.0
          | |   `-- concat-map@0.0.1
          | +-- mkdirp@0.5.1
          | | `-- minimist@0.0.8
          | +-- nopt@3.0.6
          | | `-- abbrev@1.1.1
          | +-- path-is-absolute@1.0.1
          | `-- rimraf@2.6.3
          +-- grunt-contrib-clean@1.1.0
          | `-- async@1.5.2
          +-- grunt-contrib-compress@1.5.0
          | +-- archiver@1.3.0
          | | +-- archiver-utils@1.3.0
          | | | +-- lazystream@1.0.0
          | | | `-- normalize-path@2.1.1
          | | |   `-- remove-trailing-separator@1.1.0
          | | +-- async@2.6.3
          | | +-- buffer-crc32@0.2.13
          | | +-- readable-stream@2.3.6
          | | | +-- core-util-is@1.0.2
          | | | +-- isarray@1.0.0
          | | | +-- process-nextick-args@2.0.1
          | | | `-- string_decoder@1.1.1
          | | +-- tar-stream@1.6.2
          | | | +-- bl@1.2.2
          | | | +-- buffer-alloc@1.2.0
          | | | | +-- buffer-alloc-unsafe@1.1.0
          | | | | `-- buffer-fill@1.0.0
          | | | +-- end-of-stream@1.4.4
          | | | +-- fs-constants@1.0.0
          | | | +-- to-buffer@1.1.1
          | | | `-- xtend@4.0.2
          | | +-- walkdir@0.0.11
          | | `-- zip-stream@1.2.0
          | |   `-- compress-commons@1.2.2
          | |     `-- crc32-stream@2.0.0
          | |       `-- crc@3.8.0
          | |         `-- buffer@5.4.3
          | |           +-- base64-js@1.3.1
          | |           `-- ieee754@1.1.13
          | +-- chalk@1.1.3
          | | +-- ansi-styles@2.2.1
          | | +-- has-ansi@2.0.0
          | | | `-- ansi-regex@2.1.1
          | | +-- strip-ansi@3.0.1
          | | `-- supports-color@2.0.0
          | +-- iltorb@1.3.10
          | | +-- detect-libc@0.2.0
          | | +-- node-gyp@3.8.0
          | | | +-- fstream@1.0.12
          | | | +-- npmlog@4.1.2
          | | | | +-- are-we-there-yet@1.1.5
          | | | | | `-- delegates@1.0.0
          | | | | +-- console-control-strings@1.1.0
          | | | | `-- gauge@2.7.4
          | | | |   +-- aproba@1.2.0
          | | | |   +-- has-unicode@2.0.1
          | | | |   +-- string-width@1.0.2
          | | | |   | +-- code-point-at@1.1.0
          | | | |   | `-- is-fullwidth-code-point@1.0.0
          | | | |   `-- strip-ansi@3.0.1
          | | | +-- osenv@0.1.5
          | | | | `-- os-tmpdir@1.0.2
          | | | +-- semver@5.3.0
          | | | `-- tar@2.2.2
          | | |   `-- block-stream@0.0.9
          | | `-- prebuild-install@2.5.3
          | |   +-- detect-libc@1.0.3
          | |   +-- expand-template@1.1.1
          | |   +-- github-from-package@0.0.0
          | |   +-- minimist@1.2.0
          | |   +-- node-abi@2.11.0
          | |   +-- noop-logger@0.1.1
          | |   +-- os-homedir@1.0.2
          | |   +-- pump@2.0.1
          | |   +-- rc@1.2.8
          | |   | +-- deep-extend@0.6.0
          | |   | +-- ini@1.3.5
          | |   | `-- minimist@1.2.0
          | |   +-- simple-get@2.8.1
          | |   | +-- decompress-response@3.3.0
          | |   | | `-- mimic-response@1.0.1
          | |   | `-- simple-concat@1.0.0
          | |   +-- tar-fs@1.16.3
          | |   | +-- chownr@1.1.3
          | |   | `-- pump@1.0.3
          | |   `-- which-pm-runs@1.0.0
          | +-- lodash@4.17.15
          | +-- pretty-bytes@4.0.2
          | `-- stream-buffers@2.2.0
          +-- grunt-contrib-copy@1.0.0
          | +-- chalk@1.1.3
          | `-- file-sync-cmp@0.1.1
          +-- grunt-contrib-jshint@1.1.0
          | +-- chalk@1.1.3
          | +-- hooker@0.2.3
          | `-- jshint@2.9.7
          |   +-- cli@1.0.1
          |   +-- console-browserify@1.1.0
          |   | `-- date-now@0.1.4
          |   +-- htmlparser2@3.8.3
          |   | +-- domelementtype@1.3.1
          |   | +-- domhandler@2.3.0
          |   | +-- domutils@1.5.1
          |   | | `-- dom-serializer@0.2.1
          |   | |   +-- domelementtype@2.0.1
          |   | |   `-- entities@2.0.0
          |   | +-- entities@1.0.0
          |   | `-- readable-stream@1.1.14
          |   |   `-- string_decoder@0.10.31
          |   +-- shelljs@0.3.0
          |   `-- strip-json-comments@1.0.4
          +-- grunt-exec@3.0.0
          +-- grunt-http@2.3.2
          | +-- async@3.1.0
          | +-- aws-sign2@0.7.0
          | +-- form-data@2.3.3
          | | +-- asynckit@0.4.0
          | | +-- combined-stream@1.0.8
          | | | `-- delayed-stream@1.0.0
          | | `-- mime-types@2.1.24
          | |   `-- mime-db@1.40.0
          | +-- hawk@7.0.10
          | | +-- b64@4.1.2
          | | +-- boom@7.3.0
          | | +-- cryptiles@4.1.3
          | | +-- hoek@6.1.3
          | | `-- sntp@3.0.2
          | |   +-- bounce@1.2.3
          | |   `-- teamwork@3.2.0
          | +-- http-signature@1.2.0
          | | +-- assert-plus@1.0.0
          | | +-- jsprim@1.4.1
          | | | +-- extsprintf@1.3.0
          | | | +-- json-schema@0.2.3
          | | | `-- verror@1.10.0
          | | `-- sshpk@1.16.1
          | |   +-- asn1@0.2.4
          | |   +-- bcrypt-pbkdf@1.0.2
          | |   +-- dashdash@1.14.1
          | |   +-- ecc-jsbn@0.1.2
          | |   +-- getpass@0.1.7
          | |   +-- jsbn@0.1.1
          | |   `-- tweetnacl@0.14.5
          | +-- oauth-sign@0.9.0
          | +-- request@2.88.0
          | | +-- aws4@1.8.0
          | | +-- caseless@0.12.0
          | | +-- extend@3.0.2
          | | +-- forever-agent@0.6.1
          | | +-- har-validator@5.1.3
          | | | +-- ajv@6.10.2
          | | | | +-- fast-deep-equal@2.0.1
          | | | | +-- fast-json-stable-stringify@2.0.0
          | | | | +-- json-schema-traverse@0.4.1
          | | | | `-- uri-js@4.2.2
          | | | `-- har-schema@2.0.0
          | | +-- is-typedarray@1.0.0
          | | +-- isstream@0.1.2
          | | +-- json-stringify-safe@5.0.1
          | | +-- performance-now@2.1.0
          | | +-- qs@6.5.2
          | | +-- safe-buffer@5.1.2
          | | +-- tough-cookie@2.4.3
          | | | `-- punycode@1.4.1
          | | `-- uuid@3.3.3
          | +-- tough-cookie@3.0.1
          | | +-- ip-regex@2.1.0
          | | +-- psl@1.4.0
          | | `-- punycode@2.1.1
          | `-- tunnel-agent@0.6.0
          +-- grunt-jscs@3.0.1
          | +-- jscs@3.0.7
          | | +-- chalk@1.1.3
          | | +-- cli-table@0.3.1
          | | | `-- colors@1.0.3
          | | +-- commander@2.9.0
          | | | `-- graceful-readlink@1.0.1
          | | +-- cst@0.4.10
          | | | +-- babel-runtime@6.26.0
          | | | | +-- core-js@2.6.9
          | | | | `-- regenerator-runtime@0.11.1
          | | | +-- babylon@6.18.0
          | | | `-- source-map-support@0.4.18
          | | |   `-- source-map@0.5.7
          | | +-- estraverse@4.3.0
          | | +-- glob@5.0.15
          | | +-- js-yaml@3.4.6
          | | | +-- esprima@2.7.3
          | | | `-- inherit@2.2.7
          | | +-- jscs-jsdoc@2.0.0
          | | | +-- comment-parser@0.3.2
          | | | `-- jsdoctypeparser@1.2.0
          | | |   `-- lodash@3.10.1
          | | +-- jscs-preset-wikimedia@1.0.1
          | | +-- jsonlint@1.6.3
          | | | +-- JSV@4.0.2
          | | | `-- nomnom@1.8.1
          | | |   +-- chalk@0.4.0
          | | |   | +-- ansi-styles@1.0.0
          | | |   | +-- has-color@0.1.7
          | | |   | `-- strip-ansi@0.1.1
          | | |   `-- underscore@1.6.0
          | | +-- lodash@3.10.1
          | | +-- natural-compare@1.2.2
          | | +-- pathval@0.1.1
          | | +-- prompt@0.2.14
          | | | +-- pkginfo@0.4.1
          | | | +-- read@1.0.7
          | | | | `-- mute-stream@0.0.8
          | | | +-- revalidator@0.1.8
          | | | +-- utile@0.2.1
          | | | | +-- async@0.2.10
          | | | | +-- deep-equal@1.1.0
          | | | | | +-- is-arguments@1.0.4
          | | | | | +-- is-date-object@1.0.1
          | | | | | +-- object-is@1.0.1
          | | | | | `-- regexp.prototype.flags@1.2.0
          | | | | +-- i@0.3.6
          | | | | `-- ncp@0.4.2
          | | | `-- winston@0.8.3
          | | |   +-- async@0.2.10
          | | |   +-- colors@0.6.2
          | | |   +-- cycle@1.0.3
          | | |   +-- eyes@0.1.8
          | | |   +-- pkginfo@0.3.1
          | | |   `-- stack-trace@0.0.10
          | | +-- reserved-words@0.1.2
          | | +-- resolve@1.12.0
          | | | `-- path-parse@1.0.6
          | | +-- strip-bom@2.0.0
          | | | `-- is-utf8@0.2.1
          | | +-- strip-json-comments@1.0.4
          | | +-- to-double-quotes@2.0.0
          | | +-- to-single-quotes@2.0.1
          | | +-- vow-fs@0.3.6
          | | | +-- uuid@2.0.3
          | | | `-- vow-queue@0.4.3
          | | `-- xmlbuilder@3.1.0
          | |   `-- lodash@3.10.1
          | +-- lodash@4.6.1
          | `-- vow@0.4.20
          +-- grunt-replace@1.0.1
          | +-- applause@1.2.2
          | | +-- cson-parser@1.3.5
          | | | `-- coffee-script@1.12.7
          | | `-- lodash@3.10.1
          | `-- chalk@1.1.3
          +-- lgtv2@1.4.1
          | `-- persist-path@1.0.2
          +-- mocha@6.2.1
          | +-- ansi-colors@3.2.3
          | +-- browser-stdout@1.3.1
          | +-- debug@3.2.6
          | +-- diff@3.5.0
          | +-- escape-string-regexp@1.0.5
          | +-- find-up@3.0.0
          | | `-- locate-path@3.0.0
          | |   +-- p-locate@3.0.0
          | |   | `-- p-limit@2.2.1
          | |   |   `-- p-try@2.2.0
          | |   `-- path-exists@3.0.0
          | +-- glob@7.1.3
          | +-- growl@1.10.5
          | +-- he@1.2.0
          | +-- log-symbols@2.2.0
          | | `-- chalk@2.4.2
          | |   +-- ansi-styles@3.2.1
          | |   | `-- color-convert@1.9.3
          | |   |   `-- color-name@1.1.3
          | +-- ms@2.1.1
          | +-- node-environment-flags@1.0.5
          | | +-- object.getownpropertydescriptors@2.0.3
          | | | `-- es-abstract@1.15.0
          | | |   +-- es-to-primitive@1.2.0
          | | |   | `-- is-symbol@1.0.2
          | | |   +-- has@1.0.3
          | | |   +-- is-callable@1.1.4
          | | |   +-- is-regex@1.0.4
          | | |   +-- object-inspect@1.6.0
          | | |   +-- string.prototype.trimleft@2.1.0
          | | |   `-- string.prototype.trimright@2.1.0
          | | `-- semver@5.7.1
          | +-- object.assign@4.1.0
          | | +-- define-properties@1.1.3
          | | +-- function-bind@1.1.1
          | | +-- has-symbols@1.0.0
          | | `-- object-keys@1.1.1
          | +-- strip-json-comments@2.0.1
          | +-- supports-color@6.0.0
          | | `-- has-flag@3.0.0
          | +-- which@1.3.1
          | | `-- isexe@2.0.0
          | +-- wide-align@1.1.3
          | | `-- string-width@2.1.1
          | |   +-- is-fullwidth-code-point@2.0.0
          | |   `-- strip-ansi@4.0.0
          | |     `-- ansi-regex@3.0.0
          | +-- yargs@13.3.0
          | | +-- cliui@5.0.0
          | | | +-- string-width@3.1.0
          | | | +-- strip-ansi@5.2.0
          | | | | `-- ansi-regex@4.1.0
          | | | `-- wrap-ansi@5.1.0
          | | |   `-- strip-ansi@5.2.0
          | | +-- get-caller-file@2.0.5
          | | +-- require-directory@2.1.1
          | | +-- require-main-filename@2.0.0
          | | +-- set-blocking@2.0.0
          | | | +-- emoji-regex@7.0.3
          | | +-- which-module@2.0.0
          | | `-- y18n@4.0.0
          | +-- yargs-parser@13.1.1
          | | +-- camelcase@5.3.1
          | | `-- decamelize@1.2.0
          | `-- yargs-unparser@1.6.0
          |   `-- flat@4.1.0
          |     `-- is-buffer@2.0.4
          `-- websocket@1.0.30
            +-- debug@2.6.9
            | `-- ms@2.0.0
            +-- nan@2.14.0
            +-- typedarray-to-buffer@3.1.5
            `-- yaeti@0.0.6
          echo %cd%
          node --version
          v6.17.1
          npm --version
          3.10.10
          > iobroker.lgtv@1.0.8 test:package C:\projects\ioBroker.lgtv
                package.json
                  √ exists
                  √ contains valid JSON
                  √ is an object
                io-package.json
                  √ exists
                  √ is an object
                √ The property "name" exists
                √ The property "version" exists
                √ The property "description" exists
                √ The property "author" exists
                √ The property "license" exists
                √ The property "main" exists
                √ The property "repository" exists
                √ The property "repository.type" exists
                √ The package name is correct
                √ The repository type is "git"
                √ The property "common.name" exists
                √ The property "common.title" exists
                √ The property "common.version" exists
                √ The property "common.news" exists
                √ The property "common.desc" exists
                √ The property "common.icon" exists
                √ The property "common.extIcon" exists
                √ The property "common.license" exists
                √ The property "common.type" exists
                √ The property "common.authors" exists
                √ The property "native" exists
                √ The title does not contain "adapter" or "iobroker"
                √ The description is an object to support multiple languages
                √ common.authors is an array that is not empty
                √ Materialize is supported
                √ The name matches
                √ The version matches
                √ The license matches
            34 passing (32ms)
          npm run test:unit
          > iobroker.lgtv@1.0.8 test:unit C:\projects\ioBroker.lgtv
              √ The adapter starts in normal mode (93ms)
              √ The adapter starts in compact mode
            2 passing (125ms)
          > iobroker.lgtv@1.0.8 test:integration C:\projects\ioBroker.lgtv
          Running tests in C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv
          > iobroker.js-controller@2.0.24 preinstall C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\.staging\iobroker.js-controller-4a5c006f
          > diskusage@1.1.3 install C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage
          > node-gyp rebuild
          C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage>if not defined npm_config_node_gyp (node "C:\Program Files (x86)\nodejs\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "" rebuild )
          C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets(400,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage\build\diskusage.vcxproj]
            main.cpp
            diskusage_win.cpp
               Creating library C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage\build\Release\diskusage.lib and object C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage\build\Release\diskusage.exp
            Generating code
            diskusage.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage\build\Release\\diskusage.node
            diskusage.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\diskusage\build\Release\diskusage.pdb (Full PDB)
          > unix-dgram@2.0.3 install C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\unix-dgram
          > node-gyp rebuild
          C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files (x86)\nodejs\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "" rebuild )
          C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets(400,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\unix-dgram\build\unix_dgram.vcxproj]
            unix_dgram.cc
          ..\src\unix_dgram.cc(9): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directory [C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\unix-dgram\build\unix_dgram.vcxproj]
          gyp ERR! build error
          gyp ERR! stack Error: `msbuild` failed with exit code: 1
          gyp ERR! stack     at ChildProcess.onExit (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:276:23)
          gyp ERR! stack     at emitTwo (events.js:106:13)
          gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
          gyp ERR! System Windows_NT 6.3.9600
          gyp ERR! command "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
          gyp ERR! cwd C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\unix-dgram
          gyp ERR! node -v v6.17.1
          gyp ERR! node-gyp -v v3.4.0
          gyp ERR! not ok
          > ursa-optional@0.9.10 install C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\ursa-optional
          > node rebuild.js
          > websocket@1.0.30 install C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket
          C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket>if not defined npm_config_node_gyp (node "C:\Program Files (x86)\nodejs\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "" rebuild )
          C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets(400,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\bufferutil.vcxproj]
            bufferutil.cc
               Creating library C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\bufferutil.lib and object C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\bufferutil.exp
            Generating code
            bufferutil.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\\bufferutil.node
            bufferutil.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\bufferutil.pdb (Full PDB)
          C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets(400,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\validation.vcxproj]
            validation.cc
               Creating library C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\validation.lib and object C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\validation.exp
            Generating code
            validation.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\\validation.node
            validation.vcxproj -> C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\websocket\build\Release\validation.pdb (Full PDB)
          > iobroker.js-controller@2.0.24 install C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\iobroker.js-controller
          C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\chokidar\index.js:141
              at Object.<anonymous> (C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\node_modules\iobroker.js-controller\lib\cli\cliLogs.js:5:18)
          test-iobroker.lgtv@1.0.0 C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv
          `-- iobroker.lgtv@1.0.8
            +-- lgtv2@1.4.1
            | +-- mkdirp@0.5.1
            | | `-- minimist@0.0.8
              +-- debug@2.6.9
              | `-- ms@2.0.0
              +-- nan@2.14.0
              | `-- is-typedarray@1.0.0
              `-- yaeti@0.0.6
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.0 (node_modules\chokidar\node_modules\fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\unix-dgram):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          npm ERR! Windows_NT 6.3.9600
          npm ERR! argv "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "i" "--production"
          npm ERR!
          npm ERR!     C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\npm-debug.log
            0 passing (1m)
            1 failing
               Error: Cannot find module 'C:\Users\appveyor\AppData\Local\Temp\1\test-iobroker.lgtv\iobroker-data\iobroker.json'
                at ControllerSetup.<anonymous> (node_modules\@iobroker\testing\build\tests\integration\lib\controllerSetup.js:176:34)
                at next (native)
                at C:\projects\ioBroker.lgtv\node_modules\@iobroker\testing\build\tests\integration\lib\controllerSetup.js:7:71
                at __awaiter (node_modules\@iobroker\testing\build\tests\integration\lib\controllerSetup.js:3:12)
                at ControllerSetup.setupSystemConfig (node_modules\@iobroker\testing\build\tests\integration\lib\controllerSetup.js:173:16)
                at Context.<anonymous> (node_modules\@iobroker\testing\build\tests\integration\index.js:62:39)
                at next (native)
                at fulfilled (node_modules\@iobroker\testing\build\tests\integration\index.js:5:58)
          npm ERR! argv "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "run" "test:integration"
          npm ERR!
          npm ERR!     C:\projects\ioBroker.lgtv\npm-debug.log
          Command exited with code 1
          Hab ich d irgendwo noch einen Fehler drin?
            Hat sich erledigt.
            Vielen Dank für die Hilfe!
            • AlCalzone
              AlCalzone Developer @SchuetzeSchulz last edited by
              @SchuetzeSchulz FYI, Node 6 wird nicht mehr unterstützt. Einige Dependencies sorgen bereits länger für Fehler bei der Ausführung aufgrund neuer Syntax. Und JS-Controller benötigt seit kurzem auch zwingend Node 8. Die Integration Tests laufen immer gegen die aktuelle JS-Controller-Version, damit fällt das sofort auf.
              appveyor travis
