    4. Install-Fehler node_red Adapter
    • apollon77
      apollon77 last edited by
      beim Versuch den node_red-Adapter zu installieren gab es scheinbar Probleme zwei (optionale?) Module zu bauen:
      ` > 2016-05-23 23:14:44.737 - ESC[32minfoESC[39m: iobroker In file included from ../src/bcrypt_node.cc:1:0:../node_modules/nan/nan.h:592:20: er
      ror: variable or field ‘AddGCEpilogueCallback’ declared void
      v8::Isolate::GCEpilogueCallback callback
      2016-05-23 23:14:44.753 - ESC[32minfoESC[39m: iobroker ../node_modules/nan/nan.h:592:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8:
      :Isolate’ v8::Isolate::GCEpilogueCallback callback
      ../node_modules/nan/nan.h:593:18: error: expected primary-expression before ‘gc_type_filter’
      , v8::GCType gc_type_filter = v8::kGCTypeAll) {
      ../node_modules/nan/nan.h:598:20: error: variable or field ‘RemoveGCEpilogueCallback’ declared void
      v8::Isolate::GCEpilogueCallback callback) {
      ../node_modules/nan/nan.h:598:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
      ../node_modules/nan/nan.h:603:20: error: variable or field ‘AddGCPrologueCallback’ declared void
      v8::Isolate::GCPrologueCallback callback
      ../node_modules/nan/nan.h:603:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
      ../node_modules/nan/nan.h:604:18: error: expected primary-expression before ‘gc_type_filter’
      ../node_modules/nan/nan.h:609:20: error: variable or field ‘RemoveGCPrologueCallback’ declared void
      v8::Isolate::GCPrologueCallback callback) {
      ../node_modules/nan/nan.h:609:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
      2016-05-23 23:14:46.664 - ESC[32minfoESC[39m: host.cubietruck instance system.adapter.admin.1 started with pid 2531
      2016-05-23 23:14:54.206 - ESC[32minfoESC[39m: iobroker make: *** [Release/obj.target/bcrypt_lib/src/bcrypt_node.o] Error 1
      2016-05-23 23:14:54.231 - ESC[32minfoESC[39m: iobroker gyp
      2016-05-23 23:14:54.245 - ESC[32minfoESC[39m: iobroker
      2016-05-23 23:14:54.258 - ESC[32minfoESC[39m: iobroker ERR!
      2016-05-23 23:14:54.291 - ESC[32minfoESC[39m: iobroker build error
      2016-05-23 23:14:54.353 - ESC[32minfoESC[39m: iobroker gyp ERR!
      2016-05-23 23:14:54.360 - ESC[32minfoESC[39m: iobroker stack Error: make failed with exit code: 2
      2016-05-23 23:14:54.389 - ESC[32minfoESC[39m: iobroker gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      2016-05-23 23:14:54.400 - ESC[32minfoESC[39m: iobroker gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:204:12)
      gyp ERR! System
      2016-05-23 23:14:54.420 - ESC[32minfoESC[39m: iobroker Linux 4.5.2-sunxi
      2016-05-23 23:14:54.431 - ESC[32minfoESC[39m: iobroker gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/bcrypt
      gyp ERR! node -v v6.2.0
      gyp ERR! node-gyp -v v3.3.1
      gyp ERR! not ok
      2016-05-23 23:14:54.460 - ESC[32minfoESC[39m: iobroker
      2016-05-23 23:14:54.571 - ESC[32minfoESC[39m: iobroker npm
      2016-05-23 23:14:54.580 - ESC[32minfoESC[39m: iobroker
      2016-05-23 23:14:54.602 - ESC[32minfoESC[39m: iobroker WARN deprecated i18next-client@1.10.3: you can use npm install i18next from version 2.0.0
      2016-05-23 23:15:19.862 - ESC[32minfoESC[39m: iobroker npm WARN optional dep failed, continuing bcrypt@0.8.5
      2016-05-23 23:15:27.975 - ESC[32minfoESC[39m: host.cubietruck instance system.adapter.admin.1 started with pid 2637
      2016-05-23 23:15:37.490 - ESC[32minfoESC[39m: admin.1 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.admin
      2016-05-23 23:15:37.910 - ESC[32minfoESC[39m: admin.1 requesting all states
      2016-05-23 23:15:37.921 - ESC[32minfoESC[39m: admin.1 requesting all objects
      2016-05-23 23:15:37.927 - ESC[32minfoESC[39m: admin.1 Request actual repository…
      2016-05-23 23:15:38.148 - ESC[31merrorESC[39m: admin.1 port 8081 already in use
      2016-05-23 23:15:38.855 - ESC[31merrorESC[39m: host.cubietruck instance system.adapter.admin.1 terminated with code 1 ()
      2016-05-23 23:15:38.857 - ESC[32minfoESC[39m: host.cubietruck Restart adapter system.adapter.admin.1 because enabled
      2016-05-23 23:16:01.181 - ESC[32minfoESC[39m: iobroker In file included from ../src/serialport.h:5:0, from ../src/serialport.cpp:3:
      ../node_modules/nan/nan.h:590:20: error: variable or field ‘AddGCEpilogueCallback’ declared void
      ../node_modules/nan/nan.h:590:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
      ../node_modules/nan/nan.h:591:18: error: expected primary-expression before ‘gc_type_filter’
      ../node_modules/nan/nan.h:596:20: error: variable or field ‘RemoveGCEpilogueCallback’ declared void
      2016-05-23 23:16:01.195 - ESC[32minfoESC[39m: iobroker ../node_modules/nan/nan.h:596:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’ v8::Isolate::GCEpilogueCallback callback) {
      ../node_modules/nan/nan.h:601:20: error: variable or field ‘AddGCPrologueCallback’ declared void
      ../node_modules/nan/nan.h:601:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
      ../node_modules/nan/nan.h:602:18: error: expected primary-expression before ‘gc_type_filter’
      ../node_modules/nan/nan.h:607:20: error: variable or field ‘RemoveGCPrologueCallback’ declared void
      2016-05-23 23:16:02.123 - ESC[32minfoESC[39m: iobroker make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
      2016-05-23 23:16:02.155 - ESC[32minfoESC[39m: iobroker gyp
      2016-05-23 23:16:02.171 - ESC[32minfoESC[39m: iobroker
      2016-05-23 23:16:02.179 - ESC[32minfoESC[39m: iobroker ERR! build error
      2016-05-23 23:16:02.202 - ESC[32minfoESC[39m: iobroker gyp ERR! stack Error: make failed with exit code: 2
      2016-05-23 23:16:02.210 - ESC[32minfoESC[39m: iobroker gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      2016-05-23 23:16:02.230 - ESC[32minfoESC[39m: iobroker gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      gyp ERR! System Linux 4.5.2-sunxi
      2016-05-23 23:16:02.257 - ESC[32minfoESC[39m: iobroker gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "–fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/node-v48-linux-arm/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/node-v48-linux-arm"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
      gyp
      2016-05-23 23:16:02.282 - ESC[32minfoESC[39m: iobroker ERR! not ok node-pre-gyp
      2016-05-23 23:16:02.285 - ESC[32minfoESC[39m: iobroker ERR! build error
      2016-05-23 23:16:02.325 - ESC[32minfoESC[39m: iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/node-v48-linux-arm/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/node-v48-linux-arm' (1)
      2016-05-23 23:16:02.342 - ESC[32minfoESC[39m: iobroker node-pre-gyp
      2016-05-23 23:16:02.347 - ESC[32minfoESC[39m: iobroker ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      2016-05-23 23:16:02.356 - ESC[32minfoESC[39m: iobroker node-pre-gyp ERR! stack
      2016-05-23 23:16:02.385 - ESC[32minfoESC[39m: iobroker at emitTwo (events.js:106:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:850:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
      node-pre-gyp ERR! System Linux 4.5.2-sunxi
      node-pre-gyp ERR!
      2016-05-23 23:16:02.398 - ESC[32minfoESC[39m: iobroker command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
      node-pre-gyp ERR! node -v v6.2.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.18
      node-pre-gyp ERR! not ok
      2016-05-23 23:16:02.463 - ESC[32minfoESC[39m: iobroker npm WARN
      2016-05-23 23:16:02.481 - ESC[32minfoESC[39m: iobroker optional dep failed, continuing node-red-node-serialport@0.1.2</anonymous> `
      Kann man das ignorieren oder wie kann man es fixen?
        node-red denke ich kann kein nodejs 6.0.
        Nimm 4.x
        • apollon77
          jupp, siehe anderer Thread 🙂
