    4. [GELÖST] Cannot read property 'split' of null
    SOLVED [GELÖST] Cannot read property 'split' of null
    • LausiD
      LausiD last edited by LausiD
      "uncaught exception: Cannot read property 'split' of null"
      Bin mir nicht sicher ob das Problem m Zusammenhang mit den Updates von gestern steht......
      host.raspberrypi	2019-10-12 14:03:48.342	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.raspberrypi	2019-10-12 14:03:48.341	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.raspberrypi	2019-10-12 14:03:48.341	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberrypi	2019-10-12 14:03:48.340	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:75163)
      host.raspberrypi	2019-10-12 14:03:48.340	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2127:49)
      host.raspberrypi	2019-10-12 14:03:48.339	error	Caught by controller[0]: TypeError: Cannot read property 'split' of null
      iot.0	2019-10-12 14:03:48.277	info	(16814) Terminated (NO_ERROR): Without reason
      iot.0	2019-10-12 14:03:48.275	info	(16814) terminating
      iot.0	2019-10-12 14:03:47.999	error	(16814) TypeError: Cannot read property 'split' of null at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2127:49) at (anonymous function).(anon
      iot.0	2019-10-12 14:03:47.998	error	(16814) uncaught exception: Cannot read property 'split' of null
      iot.0	2019-10-12 14:03:43.338	info	(16814) Connecting with xxxcxxxxxxxxxxxxxxx.iot.eu-west-1.amazonaws.com
      iot.0	2019-10-12 14:03:43.258	info	(16814) starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.0
      sql.0	2019-10-12 14:03:38.702	info	(1040) enabled logging of system.adapter.iot.0.memRss, Alias=false
      Was mache ich falsch?
      Danke und Gruß
      LausiD
      • LausiD
        @dslraser @FredF
        Vielen Dank für Eure Unterstützung
        Habe mir mal alexaSmartHomeV2.js angeschaut und das Problem gefunden.
        Bow was es alles gibt....die function sensor hatte als Inhalt ein null
          "fhem.0.HUEDevice12.state",
          "fhem.0.HUEDevice3.state",
          "fhem.0.HUEDevice4.state",
          null,
          null
        und das habe ich mir mit dem FHEM Adapter eingefangen 😞
        Also alles gut mit dem iot Adapter
        Danke und Gruß
        LausiD
        • Negalein
          Negalein Global Moderator @LausiD last edited by
          @LausiD sagte in [IOT] Cannot read property 'split' of null:
          Ich habe den Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
          • LausiD
            Niemand eine Idee??
            • LausiD
              Bin mit meinem Latein am Ende 😞
              Instanz und Adapter entfernt. Neuinstallation und gleiches Problem.
              Wer kann helfen?
              Danke und Gruß
              LausiD
              • FredF
                FredF Most Active Forum Testing @LausiD last edited by
                @LausiD
                Schreib doch mal was du hast:
                node -v
                nodejs -v
                npm -v
                und
                welcher js controller
                welcher iot Adpaterversion
                • LausiD
                  @FredF
                  Stimmt, könnte hilfreich sein. Sorry, hätte ich auch drauf kommen können 😞
                  node -v 10.16.0
                  nodejs -v 10.16.0
                  npm - v 6.9.0
                  js-controller 2.0.35
                  iot Adapter 1.1.8
                  • dslraser
                    dslraser Forum Testing Most Active @LausiD last edited by
                    @LausiD
                    Hast Du mal den Fixer drüber laufen lassen ?
                    • LausiD
                      @dslraser @FredF
                        null,
                        null
                      Danke und Gruß
                      LausiD
                      iot
