    5. Hilfe bei Javaskript Device Counter
      Adnim last edited by Adnim
      Hi!
      der Cache Selektor zeile 11 "Error" funktioniert nicht mehr mit folgender Fehlermeldung. Das klappte aber immer so, jemand ne Idee was ich tun kann ?
      //Add device rules
      addDeviceCounter("lowbat",         $('channel[state.id=*LOWBAT]'),                     true);
      addDeviceCounter("lowbat",         $('channel[state.id=*lowbat]'),                      true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
      addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
      addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
      addDeviceCounter("Motion",  $('channel[state.id=*.MOTION]'),               true);
      addDeviceCounter("DutyCycle",  $('channel[state.id=*.DUTYCYCLE]'),               true);
      addDeviceCounter("Spannungsüberwachung",  $('channel[state.id=*.VOLTAGE]'),           function(state){return state<200;});
      addDeviceCounter("Auskühlschutz",  $('channel[state.id=*.ACTUAL_TEMPERATURE]'),           function(state){return state<14;});
      addDeviceCounter("ERROR",  $('channel[state.id=*.ERROR*]'),               function(state){return state>0;});
      addDeviceCounter("Heizbedarf",  $('channel[state.id=*.VALVE_STATE]'),           function(state){return state>15;});
      addDeviceCounter("Alive",         $('channel[state.id=*alive]'),                     false);
      addDeviceCounter("CONNECTED",         $('channel[state.id=*.connected]'),                     false);
      addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
      addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
       * Code - do not change anything bellow this line *
      function addDeviceCounter(name, selector, val_to_count) {
          //Total amount of devices found by selector
          var state_total = 'deviceCounter.' + name + '.total';
          createState(state_total, 0);
          //List of devices that match condition
          var state_list = 'deviceCounter.' + name + '.list';
          createState(state_list, "");
          //Number of devices that match condition
          var state_counter = 'deviceCounter.' + name + '.counter';
          createState(state_counter, 0);
          function countDevs(obj) {
              var d_count = 0;
              var d_list  = [];
              selector.each(function (id, i) {
                  var status = getState(id).val;
                  var obj    = getObject(id);
                  if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                      (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                      //Get parent object
                      var parentChannelId = id.slice(id.lastIndexOf("."));
                      var parentDevicelId = id.split(".").slice(0,-2).join(".");
                      var deviceObject = getObject(parentDevicelId);
                      //remember device name
                      d_list.push(deviceObject.common.name);
                  ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
      //if ("state_counter" > 0) {event(name + "(" + d_count + "): " + d_list);
              setState(state_list,     d_list.join('<br>'));
              setState(state_counter,  d_list.length);
              setState(state_total,    d_count);
          //Re-evaluate when a device status changes
          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
              countDevs(obj);
          //Re-evaluate each hour
          schedule("*/60 * * * *", countDevs);
          //Evaluate for the first time
          countDevs();
      javascript.0	2019-10-12 16:02:30.844	info	(13143) Stop script script.js.common.DeviceCounter
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at Script.runInContext (vm.js:133:20)
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:11:1
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at addDeviceCounter (script.js.common.DeviceCounter:72:5)
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at countDevs (script.js.common.DeviceCounter:40:18)
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:808:29)
      javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:50:42
      javascript.0	2019-10-12 16:02:19.889	error	(13143) TypeError: Cannot read property 'common' of null
      javascript.0	2019-10-12 16:02:19.889	error	(13143) ^
      javascript.0	2019-10-12 16:02:19.889	error	(13143) d_list.push(deviceObject.common.name);
      javascript.0	2019-10-12 16:02:19.889	error	(13143) script.js.common.DeviceCounter: script.js.common.DeviceCounter:50
      javascript.0	2019-10-12 16:02:19.888	warn	(13143) Object "javascript.0.deviceCounter" does not exist
      Glasfaser paul53 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Adnim last edited by
        @Adnim
        Datenpunkt nicht vorhanden !
          Adnim @Glasfaser last edited by
          @Glasfaser sagte in Hilfe bei Javaskript Device Counter:
          @Adnim
          den legt das skript aber doch eigentlich an!?
          • Glasfaser
            @Adnim
            und … ist er vorhanden !?
              @Adnim
              sind alle da, der errors teil wird aber seit ein paar tagen nicht aktualisiert und wirft halt die Fehlermeldung
              • Glasfaser
                @Adnim
                Dein Bild ist zu klein , kann nichts erkennen .
                So sieht es bei mir aus
                  japp exakt so sieht es bei mir aus, nimm mal die // vor der Zeile 11 weg und starte das skript neu, das geht nicht mehr und habe ich auskommentiert das ich die andren funktionen erstmal nutzen kann
                  • Glasfaser
                    @Adnim
                    Alles in Ordnung ,keine ERROR Meldung ,
                      hmm ich starte mal neu
                        Adnim @Adnim last edited by
                        @Adnim sagte in Hilfe bei Javaskript Device Counter:
                        hilft nicht kommt immer die obige fehlermeldung
                        • Glasfaser
                          Glasfaser @Adnim last edited by Glasfaser
                          @Adnim
                          Verstehe ich nicht !?
                          Hast du mal alle Datenpunkte gelöscht und das Skript dann mal neugestartet , damit die Datenpunkte " neu "erzeugt werden !!
                          Zeig mal einen aktuellen Log vom Fehler !
                          und einen Screenshot von den Datenpunkten , der besser zu erkennen ist.
                            paul53 @Adnim last edited by
                            @Adnim sagte:
                            $('channel[state.id=.ERROR]')
                            Was liefert ?
                            $('channel[state.id=*.ERROR*]').each(function(id, i) {
                               log(id);
                              @paul53 sagte in Hilfe bei Javaskript Device Counter:
                              @Adnim sagte:
                              Was liefert ?
                              Da bekomm ich nen error, irgendwo fehlt eine klammer?
                              @Glasfaser
                              habe die objekte gelöscht sie werden angelegt ,dann stürzt das skript aber mit der Fehlermeldung ab, neustart hilft dann auch nicht
                              Danke euch!
                              • Glasfaser
                                @Adnim
                                … das Skript von paul53 in ein neues Skript starten !!!
                                  @Glasfaser
                                  oh ok, habe ich versucht. Da kommt nix nur Start Skript im Log
                                  • Glasfaser
                                    @Adnim
                                    so muss es aussehen :
                                      sieht bei mir aber so aus
                                      • Glasfaser
                                        @Adnim
                                        Datenpunkte mit ERROR ,die bei mir z.B aufgelistet werden :
                                          ja habe ich auch ne ganze menge von den Errors States ,148 laut dem Skript er zählt sie ja beim ersten start
                                          aber irgendwie findet er sie nicht mit Pauls Skript, habe Neustart und den Fixer aber gleiches Ergebnis
                                          • Glasfaser
                                            @Adnim
                                            Gib mal anstatt " ERROR" im Skript von paul53 ,"UNREACH" ein
                                            Zeig mal bitte die ausgabe von
                                            iobroker list adapters
                                            javascript
                                            2482
