    4. [fixed] Fehler beim Updaten von sayit
      tesso last edited by
      seit den Wochenende habe ich ein Problem damit den sayit Adapter upzudaten.
      Auch ein deinstallieren und neu installiert schlägt fehl.
      root@pi01:/opt/iobroker# iobroker upgrade sayit
      npm install iobroker.sayit --production --prefix "/opt/iobroker" (System call)
      npm http GET https://registry.npmjs.org/iobroker.sayit
      npm http 304 https://registry.npmjs.org/iobroker.sayit
      npm http GET https://registry.npmjs.org/jsftp
      npm http GET https://registry.npmjs.org/ivona-node
      npm http 304 https://registry.npmjs.org/jsftp
      npm http 304 https://registry.npmjs.org/ivona-node
      npm http GET https://registry.npmjs.org/aws4
      npm http 304 https://registry.npmjs.org/aws4
      npm http GET https://registry.npmjs.org/lru-cache
      npm http 304 https://registry.npmjs.org/lru-cache
      npm http GET https://registry.npmjs.org/debug/2.2.0
      npm http GET https://registry.npmjs.org/ftp-response-parser/1.0.0
      npm http GET https://registry.npmjs.org/parse-listing/1.1.3
      npm http GET https://registry.npmjs.org/once/1.3.0
      npm http GET https://registry.npmjs.org/unorm/1.4.1
      npm http GET https://registry.npmjs.org/event-stream/3.1.7
      npm http 304 https://registry.npmjs.org/debug/2.2.0
      npm http 304 https://registry.npmjs.org/parse-listing/1.1.3
      npm http 304 https://registry.npmjs.org/unorm/1.4.1
      npm http 304 https://registry.npmjs.org/ftp-response-parser/1.0.0
      npm http 304 https://registry.npmjs.org/once/1.3.0
      npm http 304 https://registry.npmjs.org/event-stream/3.1.7
      npm http GET https://registry.npmjs.org/ms/0.7.1
      npm http 304 https://registry.npmjs.org/ms/0.7.1
      npm http GET https://registry.npmjs.org/pause-stream/0.0.11
      npm http GET https://registry.npmjs.org/split
      npm http GET https://registry.npmjs.org/stream-combiner
      npm http GET https://registry.npmjs.org/through
      npm http GET https://registry.npmjs.org/duplexer
      npm http GET https://registry.npmjs.org/from
      npm http GET https://registry.npmjs.org/map-stream
      npm http 304 https://registry.npmjs.org/pause-stream/0.0.11
      npm http 304 https://registry.npmjs.org/stream-combiner
      npm http 304 https://registry.npmjs.org/from
      npm http 200 https://registry.npmjs.org/split
      npm http 304 https://registry.npmjs.org/duplexer
      npm http 304 https://registry.npmjs.org/through
      npm http 304 https://registry.npmjs.org/map-stream
      npm http GET https://registry.npmjs.org/readable-stream
      npm http 304 https://registry.npmjs.org/readable-stream
      npm http GET https://registry.npmjs.org/core-util-is
      npm http GET https://registry.npmjs.org/isarray/0.0.1
      npm http GET https://registry.npmjs.org/string_decoder
      npm http GET https://registry.npmjs.org/inherits
      npm http 304 https://registry.npmjs.org/isarray/0.0.1
      npm http 304 https://registry.npmjs.org/inherits
      npm http 304 https://registry.npmjs.org/string_decoder
      npm http 304 https://registry.npmjs.org/core-util-is
      Killed
      npm ERR! iobroker.sayit@1.0.0 install: `node main.js --install`
      npm ERR! Exit status 137
      npm ERR!
      npm ERR! Failed at the iobroker.sayit@1.0.0 install script.
      npm ERR! This is most likely a problem with the iobroker.sayit package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node main.js --install
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls iobroker.sayit
      npm ERR! There is likely additional logging output above.
      npm ERR! System Linux 3.18.11-v7+
      npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sayit" "--production" "--prefix" "/opt/iobroker"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.22
      npm ERR! npm -v 1.3.14
      npm ERR! code ELIFECYCLE
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /opt/iobroker/npm-debug.log
      npm ERR! not ok code 0
      host.pi01 Cannot install iobroker.sayit: 1
      Hat jemand eine Idee wie ich den Fehler eingrenzen kann?
        /opt/iobroker/npm-debug.log ?
          Thema hat sich erledigt.
          Das System machte nach über einem Jahr updaten immer mehr Probleme. Habe mich entschlossen, alles neu aufzubauen. Mit jessie und ohne Restmüll läuft jetzt alles wieder flott. auch die sayit Updateprobleme sind plötzlich weg.
