    4. Info Adapter crash loop
    UNSOLVED Info Adapter crash loop
      MrBubbles last edited by
      Heute ist mir aufgefallen, das der Info Adpater im 30 Sekundentakt immer wieder neu gestartet wird um sofort wieder abzustürzen. Leider hilft mein Googel foo mit bei den Fehlermeldungen nicht weiter:
      host.iobroker	2019-10-13 16:47:10.760	info	Restart adapter system.adapter.info.0 because enabled
      host.iobroker	2019-10-13 16:47:10.760	error	instance system.adapter.info.0 terminated with code 0 (OK)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Array.forEach (<anonymous>)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
      Caught	2019-10-13 16:47:10.760	error	by controller[0]: TypeError: Cannot read property 'split' of undefined
      info.0	2019-10-13 16:47:10.754	info	cleaned everything up...
      info.0	2019-10-13 16:47:10.753	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      info.0	2019-10-13 16:47:10.753	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      info.0	2019-10-13 16:47:10.753	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      info.0	2019-10-13 16:47:10.753	error	at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
      info.0	2019-10-13 16:47:10.753	error	at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
      info.0	2019-10-13 16:47:10.753	error	at Array.forEach (<anonymous>)
      info.0	2019-10-13 16:47:10.753	error	at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
      info.0	2019-10-13 16:47:10.753	error	at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
      info.0	2019-10-13 16:47:10.753	error	at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
      info.0	2019-10-13 16:47:10.753	error	TypeError: Cannot read property 'split' of undefined
      info.0	2019-10-13 16:47:10.753	error	uncaught exception: Cannot read property 'split' of undefined
      info.0	2019-10-13 16:47:10.727	info	Popup news was read...
      info.0	2019-10-13 16:47:09.951	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.info, node: v10.16.3
      host.iobroker	2019-10-13 16:47:09.505	info	instance system.adapter.info.0 started with pid 22590
      Kann es sein das er sich beim Lesen von Daten aus dem Internet verschluckt?
      Systemdata
      Hardwaresystem: Intel Core i5-2500
      Arbeitsspeicher: 4GB
      Festplattenart: SSD 32GB
      Betriebssystem: Debian 10
      Node-Version: 10.16.3
      Nodejs-Version: 10.16.3
      NPM-Version: 6.9.x
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: NN
      adapterneustarts info error
