    5. [gelöst]mit Mediola Gateway TV über IR einschalten
    SOLVED [gelöst]mit Mediola Gateway TV über IR einschalten
      jwedenig Most Active last edited by jwedenig
      Hi!
      Ich versuche meinen Samsung per Alexa einzuschalten, aber irgendwo ist der Wurm drin:
      Hier mal mein Skript:
      "Fernseher_" ist ein virtueller Knoten (Objekt)
      Hier das Log:
      undefined2019-10-15 08:51:10.811 - warn: javascript.0 Wrong type of denon.0.zoneMain.powerZone: "number". Please fix, while deprecated and will not work in next versions.
      2019-10-15 08:51:10.818 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      2019-10-15 08:51:10.819 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:9:5)
      2019-10-15 08:51:10.819 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      2019-10-15 08:51:10.819 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      2019-10-15 08:51:10.820 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
      2019-10-15 08:51:10.820 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      2019-10-15 08:51:10.820 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      2019-10-15 08:51:10.820 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
      2019-10-15 08:51:10.821 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
      2019-10-15 08:51:10.821 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-10-15 08:51:10.821 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      2019-10-15 08:51:10.821 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      2019-10-15 08:51:10.821 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-10-15 08:51:10.822 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      2019-10-15 08:51:10.822 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      2019-10-15 08:51:10.822 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-10-15 08:51:10.822 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-10-15 08:51:10.822 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-10-15 08:51:10.823 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      2019-10-15 08:51:10.823 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      2019-10-15 08:51:10.823 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-10-15 08:51:10.823 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      2019-10-15 08:51:10.823 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
      2019-10-15 08:51:10.824 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      2019-10-15 08:51:10.824 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
      2019-10-15 08:51:10.824 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
      2019-10-15 08:51:10.824 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
      2019-10-15 08:51:10.824 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
      2019-10-15 08:51:10.825 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
      2019-10-15 08:51:10.825 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
      2019-10-15 08:51:10.825 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
      2019-10-15 08:51:10.825 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
      2019-10-15 08:51:10.825 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
      2019-10-15 08:51:10.825 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
      2019-10-15 08:51:10.826 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
      2019-10-15 08:51:10.826 - warn: javascript.0 at Socket.emit (events.js:198:13)
      2019-10-15 08:51:10.826 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
      2019-10-15 08:51:10.826 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
      2019-10-15 08:51:10.826 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
      2019-10-15 08:51:10.827 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
      2019-10-15 08:51:10.830 - error: javascript.0 script.js.Weldscripts.Alexa_Fernseher_ein: TypeError [ERR_UNESCAPED_CHARACTERS]: Request path contains unescaped characters
      Wenn ich die Url im Browser aufrufe, dann schaltet sich der Fernseher an, also an dem liegt es nicht!
      Der Denon Verstärker funktioniert ein/aus!
      Vielen Dank
      Jürgen
      SRo769 1 Reply Last reply Reply Quote 0
      • SRo769
        SRo769 @jwedenig last edited by
        @jwedenig
        a) - setz den Trigger-Baustein mal auf "geändert" statt auf "aktualisiert"
        b) - wird der Wert des Datenpunktes "Fernseher_" sauber gesetzt?
        LG SRo769
          Hi!
          Trigger Baustein auf geändert hat nix bewirkt
          Datenpunkt schaltet schön von true auf false, alles wunderbar soweit
            jwedenig Most Active @jwedenig last edited by
            2019-10-15 09:09:08.407 - info: info.0 Popup news was read...
            2019-10-15 09:17:16.568 - info: javascript.0 Stop script script.js.Weldscripts.Alexa_Fernseher_ein
            2019-10-15 09:17:16.573 - info: javascript.1 Stop script script.js.Weldscripts.Alexa_Fernseher_ein
            2019-10-15 09:17:16.598 - info: javascript.0 Start javascript script.js.Weldscripts.Alexa_Fernseher_ein
            2019-10-15 09:17:16.615 - info: javascript.0 script.js.Weldscripts.Alexa_Fernseher_ein: registered 1 subscription and 0 schedules
            2019-10-15 09:17:27.797 - warn: javascript.0 Wrong type of denon.0.zoneMain.powerZone: "number". Please fix, while deprecated and will not work in next versions.
            2019-10-15 09:17:27.805 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
            2019-10-15 09:17:27.805 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:13:5)
            2019-10-15 09:17:27.806 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
            2019-10-15 09:17:27.806 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
            2019-10-15 09:17:27.806 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
            2019-10-15 09:17:27.806 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
            2019-10-15 09:17:27.806 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.807 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
            2019-10-15 09:17:27.807 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
            2019-10-15 09:17:27.807 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.807 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.807 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            2019-10-15 09:17:27.808 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.808 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            2019-10-15 09:17:27.808 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
            2019-10-15 09:17:27.808 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
            2019-10-15 09:17:27.808 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.809 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.809 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
            2019-10-15 09:17:27.809 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
            2019-10-15 09:17:27.809 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.809 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
            2019-10-15 09:17:27.810 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
            2019-10-15 09:17:27.810 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
            2019-10-15 09:17:27.810 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
            2019-10-15 09:17:27.810 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
            2019-10-15 09:17:27.810 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
            2019-10-15 09:17:27.810 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
            2019-10-15 09:17:27.811 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
            2019-10-15 09:17:27.811 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
            2019-10-15 09:17:27.811 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
            2019-10-15 09:17:27.811 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
            2019-10-15 09:17:27.811 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
            2019-10-15 09:17:27.812 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
            2019-10-15 09:17:27.812 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
            2019-10-15 09:17:27.812 - warn: javascript.0 at Socket.emit (events.js:198:13)
            2019-10-15 09:17:27.812 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
            2019-10-15 09:17:27.812 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
            2019-10-15 09:17:27.812 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
            2019-10-15 09:17:27.813 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
            2019-10-15 09:17:27.813 - warn: javascript.0 Wrong type of samsung.0.Power.off: "number". Please fix, while deprecated and will not work in next versions.
            2019-10-15 09:17:27.819 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
            2019-10-15 09:17:27.820 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:14:5)
            2019-10-15 09:17:27.820 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
            2019-10-15 09:17:27.820 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
            2019-10-15 09:17:27.820 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
            2019-10-15 09:17:27.820 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
            2019-10-15 09:17:27.821 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.821 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
            2019-10-15 09:17:27.821 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
            2019-10-15 09:17:27.821 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.821 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.822 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            2019-10-15 09:17:27.822 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.822 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            2019-10-15 09:17:27.822 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
            2019-10-15 09:17:27.822 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
            2019-10-15 09:17:27.823 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:27.823 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.823 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
            2019-10-15 09:17:27.823 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
            2019-10-15 09:17:27.823 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:27.823 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
            2019-10-15 09:17:27.824 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
            2019-10-15 09:17:27.824 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
            2019-10-15 09:17:27.824 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
            2019-10-15 09:17:27.824 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
            2019-10-15 09:17:27.824 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
            2019-10-15 09:17:27.825 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
            2019-10-15 09:17:27.825 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
            2019-10-15 09:17:27.825 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
            2019-10-15 09:17:27.825 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
            2019-10-15 09:17:27.825 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
            2019-10-15 09:17:27.825 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
            2019-10-15 09:17:27.826 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
            2019-10-15 09:17:27.826 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
            2019-10-15 09:17:27.826 - warn: javascript.0 at Socket.emit (events.js:198:13)
            2019-10-15 09:17:27.826 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
            2019-10-15 09:17:27.826 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
            2019-10-15 09:17:27.827 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
            2019-10-15 09:17:27.827 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
            2019-10-15 09:17:27.881 - error: samsung.0 Empty commands will not be excecuted.
            2019-10-15 09:17:33.731 - warn: javascript.0 Wrong type of denon.0.zoneMain.powerZone: "number". Please fix, while deprecated and will not work in next versions.
            2019-10-15 09:17:33.738 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
            2019-10-15 09:17:33.738 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:9:5)
            2019-10-15 09:17:33.739 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
            2019-10-15 09:17:33.739 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
            2019-10-15 09:17:33.739 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
            2019-10-15 09:17:33.739 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:33.740 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            2019-10-15 09:17:33.741 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:33.741 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            2019-10-15 09:17:33.741 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
            2019-10-15 09:17:33.741 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
            2019-10-15 09:17:33.741 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            2019-10-15 09:17:33.742 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:33.742 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
            2019-10-15 09:17:33.742 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
            2019-10-15 09:17:33.742 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            2019-10-15 09:17:33.742 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
            2019-10-15 09:17:33.742 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
            2019-10-15 09:17:33.743 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
            2019-10-15 09:17:33.743 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
            2019-10-15 09:17:33.743 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
            2019-10-15 09:17:33.743 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
            2019-10-15 09:17:33.743 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
            2019-10-15 09:17:33.744 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
            2019-10-15 09:17:33.744 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
            2019-10-15 09:17:33.744 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
            2019-10-15 09:17:33.744 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
            2019-10-15 09:17:33.744 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
            2019-10-15 09:17:33.744 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
            2019-10-15 09:17:33.745 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
            2019-10-15 09:17:33.745 - warn: javascript.0 at Socket.emit (events.js:198:13)
            2019-10-15 09:17:33.745 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
            2019-10-15 09:17:33.745 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
            2019-10-15 09:17:33.745 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
            2019-10-15 09:17:33.745 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
            2019-10-15 09:17:33.754 - error: javascript.0 script.js.Weldscripts.Alexa_Fernseher_ein: TypeError [ERR_UNESCAPED_CHARACTERS]: Request path contains unescaped characters
              Der Fernseher schaltet auch aus, nur ein leider nicht.
              Und das LOG füllt sich halt auch mit Warnmeldungen
              • SRo769
                SRo769 last edited by
                worüber wird der Fernseher denn abgeschaltet?
                  Über den IP Befehl des Samsung Adapters, und "ein"mit dem http Befehl, welcher ein IR Signal an mein Mediola Gateway sendet, da man ja leider den Samsung Fernseher nicht anders einschalten kann mangels Netzwerkverfügbarkeit
                  • SRo769
                    letztlich meckert das script nur über den Fehler "TypeError [ERR_UNESCAPED_CHARACTERS]: Request path contains unescaped characters" - d.h., der kann den Netzwerkpfad aufgrund eines Fehlers nicht auflösen bzw. die Aktion auslösen.
                    Hast du auch den aus Blockly herauskopierten Pfad im Browser getestet?
                    Zusätzlich ist der Datenpunkt "MainPowerZone" noch falsch definiert. Er wird mit einer Zahl beschrieben, ist vielleicht aber als Bool o.ä. ausgelegt.
                      jwedenig Most Active @SRo769 last edited by
                      @SRo769
                      ja, im Browser funktioniert der Pfad
                        ja, stimmt, Power zone wird mit true/false definiert, ist aber scheinbar egal, weil der DENON ja funktioniert
                          habs jetzt geändert:
                            aktualisiertes Log:
                            undefined2019-10-15 09:48:21.095 - info: javascript.1 Stop script script.js.Weldscripts.Alexa_Fernseher_ein
                            2019-10-15 09:48:21.100 - info: javascript.0 Stop script script.js.Weldscripts.Alexa_Fernseher_ein
                            2019-10-15 09:48:21.129 - info: javascript.0 Start javascript script.js.Weldscripts.Alexa_Fernseher_ein
                            2019-10-15 09:48:21.146 - info: javascript.0 script.js.Weldscripts.Alexa_Fernseher_ein: registered 1 subscription and 0 schedules
                            2019-10-15 09:48:47.833 - warn: javascript.0 Wrong type of denon.0.zoneMain.powerZone: "string". Please fix, while deprecated and will not work in next versions.
                            2019-10-15 09:48:47.840 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                            2019-10-15 09:48:47.841 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:9:5)
                            2019-10-15 09:48:47.841 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                            2019-10-15 09:48:47.841 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                            2019-10-15 09:48:47.841 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
                            2019-10-15 09:48:47.842 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                            2019-10-15 09:48:47.842 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:48:47.842 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                            2019-10-15 09:48:47.842 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                            2019-10-15 09:48:47.842 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                            2019-10-15 09:48:47.843 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                            2019-10-15 09:48:47.844 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:48:47.844 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:48:47.844 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                            2019-10-15 09:48:47.844 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                            2019-10-15 09:48:47.844 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
                            2019-10-15 09:48:47.845 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                            2019-10-15 09:48:47.846 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                            2019-10-15 09:48:47.846 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                            2019-10-15 09:48:47.846 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                            2019-10-15 09:48:47.846 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                            2019-10-15 09:48:47.846 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at Socket.emit (events.js:198:13)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
                            2019-10-15 09:48:47.847 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
                            2019-10-15 09:48:47.848 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
                            2019-10-15 09:48:47.848 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                            2019-10-15 09:48:47.852 - error: javascript.0 script.js.Weldscripts.Alexa_Fernseher_ein: TypeError [ERR_UNESCAPED_CHARACTERS]: Request path contains unescaped characters
                            2019-10-15 09:49:11.101 - warn: javascript.0 Wrong type of denon.0.zoneMain.powerZone: "string". Please fix, while deprecated and will not work in next versions.
                            2019-10-15 09:49:11.109 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                            2019-10-15 09:49:11.110 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:13:5)
                            2019-10-15 09:49:11.110 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                            2019-10-15 09:49:11.110 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                            2019-10-15 09:49:11.110 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
                            2019-10-15 09:49:11.110 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                            2019-10-15 09:49:11.111 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.111 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                            2019-10-15 09:49:11.111 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                            2019-10-15 09:49:11.111 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.111 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.112 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                            2019-10-15 09:49:11.112 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.112 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                            2019-10-15 09:49:11.112 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                            2019-10-15 09:49:11.112 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.113 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                            2019-10-15 09:49:11.114 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                            2019-10-15 09:49:11.114 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                            2019-10-15 09:49:11.114 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                            2019-10-15 09:49:11.114 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
                            2019-10-15 09:49:11.114 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                            2019-10-15 09:49:11.115 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                            2019-10-15 09:49:11.115 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                            2019-10-15 09:49:11.115 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                            2019-10-15 09:49:11.115 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                            2019-10-15 09:49:11.115 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                            2019-10-15 09:49:11.115 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                            2019-10-15 09:49:11.116 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                            2019-10-15 09:49:11.116 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                            2019-10-15 09:49:11.116 - warn: javascript.0 at Socket.emit (events.js:198:13)
                            2019-10-15 09:49:11.116 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
                            2019-10-15 09:49:11.116 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
                            2019-10-15 09:49:11.117 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
                            2019-10-15 09:49:11.117 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                            2019-10-15 09:49:11.117 - warn: javascript.0 Wrong type of samsung.0.Power.off: "number". Please fix, while deprecated and will not work in next versions.
                            2019-10-15 09:49:11.123 - warn: javascript.0 at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                            2019-10-15 09:49:11.124 - warn: javascript.0 at Object. (script.js.Weldscripts.Alexa_Fernseher_ein:14:5)
                            2019-10-15 09:49:11.124 - warn: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                            2019-10-15 09:49:11.124 - warn: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                            2019-10-15 09:49:11.124 - warn: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
                            2019-10-15 09:49:11.124 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                            2019-10-15 09:49:11.125 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.125 - warn: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                            2019-10-15 09:49:11.125 - warn: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                            2019-10-15 09:49:11.125 - warn: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.125 - warn: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.126 - warn: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                            2019-10-15 09:49:11.126 - warn: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.126 - warn: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                            2019-10-15 09:49:11.126 - warn: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                            2019-10-15 09:49:11.126 - warn: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                            2019-10-15 09:49:11.127 - warn: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            2019-10-15 09:49:11.127 - warn: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.127 - warn: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                            2019-10-15 09:49:11.127 - warn: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                            2019-10-15 09:49:11.127 - warn: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            2019-10-15 09:49:11.128 - warn: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                            2019-10-15 09:49:11.128 - warn: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                            2019-10-15 09:49:11.128 - warn: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                            2019-10-15 09:49:11.128 - warn: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                            2019-10-15 09:49:11.128 - warn: javascript.0 at WebSocket.emit (events.js:198:13)
                            2019-10-15 09:49:11.129 - warn: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                            2019-10-15 09:49:11.129 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                            2019-10-15 09:49:11.129 - warn: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                            2019-10-15 09:49:11.129 - warn: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                            2019-10-15 09:49:11.129 - warn: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                            2019-10-15 09:49:11.129 - warn: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                            2019-10-15 09:49:11.130 - warn: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                            2019-10-15 09:49:11.130 - warn: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                            2019-10-15 09:49:11.130 - warn: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                            2019-10-15 09:49:11.130 - warn: javascript.0 at Socket.emit (events.js:198:13)
                            2019-10-15 09:49:11.130 - warn: javascript.0 at addChunk (_stream_readable.js:288:12)
                            2019-10-15 09:49:11.131 - warn: javascript.0 at readableAddChunk (_stream_readable.js:269:11)
                            2019-10-15 09:49:11.131 - warn: javascript.0 at Socket.Readable.push (_stream_readable.js:224:10)
                            2019-10-15 09:49:11.131 - warn: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                            2019-10-15 09:49:11.166 - error: samsung.0 Empty commands will not be excecuted.
                            • UweRLP
                              UweRLP last edited by
                              Du benutzt Texte als true/false mußt aber unter Logik den Baustein wahr/unwahr nutzen. Vermutlich ist der Text bei select input "TV" auch nicht richtig, was ist select input für ein Objekt?
                              • UweRLP
                                Hier mein Blocky zum Ein-/Auschalten meiner Anlage. Ich mußte es leider in zwei Bilder aufteilen...
                                Vielleicht hilft es dir, habe dazu noch ein paar Kommentare eingefügt.
                                  Mein Denon reagiert auf "0"und "1" als auch auf "true" und False"
                                  das Problem ist dass der "request Url" Befehl nicht funktioniert.
                                  Mhhh, Scheibenkleister
                                  UweRLP 1 Reply Last reply Reply Quote 0
                                  • UweRLP
                                    UweRLP @jwedenig last edited by UweRLP
                                    @jwedenig Vermute mal zum einschalten des Fensehers? Hat der TV immer die selbe also feste IP Adresse? War der TV zuvor vom Strom getrennt, kann sein das die Url zu früh nach dem Stromeinschalten abgesetzt wurde. Als Alternative zur Url, kann das Mediola Gateway IR senden oder hast du eine Harmony Fernbedienung mit Hub? Könntest dann den TV damit einschalten.
                                      jwedenig Most Active @UweRLP last edited by
                                      @UweRLP
                                      Der Fernseher ist immer in Standby
                                      Das abfeuern im Browser funktioniert tadellos .
                                      Das Problem ist das Skript!
                                      Glaube ich halt
                                        Wie soll das Mediola als Trigger IR senden, es gibt doch keinen Mediola Adapter für IObroker, oder?
                                        • UweRLP
                                          Ups, bin davon ausgegangen das es einen Mediola Adapter gibt, weis es aber nicht, sorry.
                                          Aber es gibt doch einen Samsung Adapter besteht da nicht die Mölglichkeit den TV einzuschalten?
                                          BBTown J 2 Replies Last reply Reply Quote 0
                                          • BBTown
                                            BBTown @UweRLP last edited by BBTown
                                            @UweRLP sagte in Samsung Fernseher schalten:
                                            kommen die Datenpunkte nicht genau von diesem Adapter? (samsung.0)
                                            @jwedenig was passiert denn bei "Power.off=1" ?
                                            blockly
                                            805
