    4. Hue Error
    SOLVED Hue Error
      CyberMicha last edited by
      Kennt jemand das Problem?
      Habe heute ein Update vom host gemacht auf die 2.0.34
      host.iobroker	2019-10-17 21:29:22.256	info	Restart adapter system.adapter.hue.0 because enabled
      host.iobroker	2019-10-17 21:29:22.256	error	instance system.adapter.hue.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker	2019-10-17 21:29:22.256	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/node-hue-api/lib/api/discovery/index.js:5:23)
      host.iobroker	2019-10-17 21:29:22.256	error	Caught by controller[0]: at require (internal/module.js:11:18)
      host.iobroker	2019-10-17 21:29:22.256	error	Caught by controller[0]: at Module.require (module.js:517:17)
      host.iobroker	2019-10-17 21:29:22.256	error	Caught by controller[0]: at Function.Module._load (module.js:462:3)
      host.iobroker	2019-10-17 21:29:22.255	error	Caught by controller[0]: at tryModuleLoad (module.js:470:12)
      host.iobroker	2019-10-17 21:29:22.255	error	Caught by controller[0]: at Module.load (module.js:507:32)
      host.iobroker	2019-10-17 21:29:22.255	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:584:10)
      host.iobroker	2019-10-17 21:29:22.255	error	Caught by controller[0]: at Module._compile (module.js:537:28)
      host.iobroker	2019-10-17 21:29:22.255	error	Caught by controller[0]: at Object.runInThisContext (vm.js:116:10)
      host.iobroker	2019-10-17 21:29:22.254	error	Caught by controller[0]: at createScript (vm.js:74:10)
      host.iobroker	2019-10-17 21:29:22.254	error	Caught by controller[0]: SyntaxError: Invalid regular expression flags
      host.iobroker	2019-10-17 21:29:22.254	error	Caught by controller[0]: ^
      host.iobroker	2019-10-17 21:29:22.254	error	Caught by controller[0]: const FRIENDLY_NAME = /<friendlyName>(.*)<\/friendlyName/sm
      host.iobroker	2019-10-17 21:29:22.253	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hue/node_modules/node-hue-api/lib/api/discovery/bridge-validation.js:8
      host.iobroker	2019-10-17 21:29:21.116	info	instance system.adapter.hue.0 started with pid 7076
        Hat sich schon erledigt. Sorry... Neustart des Systems und die Verbindung steht wieder.
        Version ist die 2.2.0
        • BBTown
          BBTown @CyberMicha last edited by
          @CyberMicha welche HUE-Adapter-Version setzt Du denn ein?
            • BBTown
              @CyberMicha nimm mal gleich die ganz neue v2.2.1 von GitHub, da sind noch ein paar Fehler raus die sich in der v2.1.0 und v2.2.0 reingeschlichen haben.
              hue 2.0.34
