    3. Entwicklung
    4. Update BackitUp 1.2.1 Fehlermeldungen
    UNSOLVED Update BackitUp 1.2.1 Fehlermeldungen
    • JB_Sullivan
      JB_Sullivan last edited by
      Kurze Frage am Rande - ich wollte heute auf BackitUp 1.2.1 updaten und habe die folgenden Fehlermeldung während des Updatevorgang bekommen.
      Ist das ggf. ein Problem welches mit dem neuen js-controller 2.0.33 zusammenhängen kann?
      $ ./iobroker upgrade backitup
      Update backitup from @1.2.0 to @1.2.1
      NPM version: 6.9.0
      npm install iobroker.backitup@1.2.1 --loglevel error --production --save --prefix "C:/ioBroker" (System call)
      npm
      ERR! path C:\ioBroker\node_modules\iobroker.backitupnpm ERR! code EPERMnpm ERR!
      errno
      -4048
      npm
      ERR!
      syscall
      rename
      npm
      ERR! Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE'npm
      ERR!
      { [Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE']
      npm
      ERR!
      cause:
      npm
      ERR!
      { Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE'
      npm
      ERR!
      errno: -4048,
      npm
      ERR!
      code: 'EPERM',
      npm
      ERR!
      syscall: 'rename',
      npm
      ERR!
      path: 'C:\ioBroker\node_modules\iobroker.backitup',
      npm
      ERR!
      dest: 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE' },
      npm
      ERR!
      stack:
      npm
      ERR!
      'Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE'',
      npm
      ERR!
      errno: -4048,
      npm
      ERR!
      code: 'EPERM',
      npm
      ERR!
      syscall: 'rename',
      npm
      ERR!
      npm
      ERR!
      dest: 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE',
      npm
      ERR!
      parent: 'ioBroker' }
      npm
      ERR!
      npm
      ERR!
      The operation was rejected by your operating system.
      npm
      ERR!
      It's possible that the file was already in use (by a text editor or antivirus),
      npm
      ERR!
      or that you lack permissions to access it.
      npm
      ERR!
      npm
      ERR!
      If you believe this might be a permissions issue, please double-check the
      npm
      ERR!
      permissions of the file and its containing directories, or try running
      npm
      ERR!
      the command again as root/Administrator (though this is not recommended).
      npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-10-20T07_01_21_138Z-debug.log
      ERROR: host.iobroker Cannot install iobroker.backitup@1.2.1: 4294963248
      ERROR: process exited with code 25
      Stabilostick simatec 2 Replies Last reply Reply Quote 0
      • Stabilostick
        Stabilostick @JB_Sullivan last edited by
        @JB_Sullivan
        Stoppe vor dem Update alle diesbezüglichen Adapterinstanzen. Geht jetzt das Update?
        • simatec
          simatec Developer Most Active @JB_Sullivan last edited by
          @JB_Sullivan Sollte mit Version 1.2.2 behoben sein ...
          smartboart 1 Reply Last reply Reply Quote 0
          • smartboart
            smartboart @simatec last edited by smartboart
            @simatec Hat sich bezüglich des js.controller 2.0.xx und redis file und state aktiv etwas im backup Widerherstellungsprozess geändert? Irgendwie hat es bei mir mit dem komplett Backup nicht hingehauen...
              Jan1 @smartboart last edited by
              @smartboart
              Das komplett Backup ist auch nicht die erste Wahl und je nach dem wo Du das wieder herstellen möchtest auch falsch.
              • smartboart
                smartboart last edited by smartboart
                Hatte mein system neu aufgesetzt wegen der ganzen node-gyp erros. node.js und npm sowie js controller alles aktuell bzw. genau wie im neu aufgesetzten System.
                iobroker stop.
                dann redis mit der Backup Datei ersetzt und
                sudo tar -xzvf Backupname.tar.gz -C /opt/iobroker
                dann iobroker start...
                hatte danach trotzdem nur den admin laufen wie im neu aufgesetzten system...
                Hatte vorher eigentlich immer funktioniert, also vor redis file Umstellung...
                1.2.1 backitup js-controller
