    4. LCN Adapter error beim scan Windows 10
    UNSOLVED LCN Adapter error beim scan Windows 10
      pauliv_de last edited by pauliv_de
      Laptop mit Windows 10 Home
      Node V10.16.3
      Nach unüberbrückbaren Problemen mit Version 3 habe ich ein Update auf Version 0.4.2 gemacht. Leider läuft der Scan nicht durch.
      lcn.0	2019-10-20 20:57:26.280	info	starting. Version 0.4.2 in C:/iobroker/node_modules/iobroker.lcn, node: v10.16.3
      2019-10-20 20:57:23.908	info	instance system.adapter.lcn.0 started with pid 600
      2019-10-20 20:56:53.891	info	Restart adapter system.adapter.lcn.0 because enabled
      2019-10-20 20:56:53.891	error	instance system.adapter.lcn.0 terminated with code 0 (OK)
      Caught	2019-10-20 20:56:53.890	error	by controller[0]: at Timeout._onTimeout (C:\iobroker\node_modules\iobroker.lcn\main.js:34:5699)
      Caught	2019-10-20 20:56:53.890	error	by controller[0]: at _0x102ca5._processScanRead (C:\iobroker\node_modules\iobroker.lcn\main.js:34:9409)
      lcn.0	2019-10-20 20:56:53.780	debug	sendTo "scan" to system.adapter.admin.0 from system.adapter.lcn.0
      lcn.0	2019-10-20 20:56:53.768	error	at Timeout._onTimeout (C:\iobroker\node_modules\iobroker.lcn\main.js:34:5699)
      lcn.0	2019-10-20 20:56:53.768	error	at _0x102ca5._processScanRead (C:\iobroker\node_modules\iobroker.lcn\main.js:34:9409)
      lcn.0	2019-10-20 20:56:20.350	info	starting. Version 0.4.2 in C:/iobroker/node_modules/iobroker.lcn, node: v10.16.3
      2019-10-20 20:56:17.581	info	instance system.adapter.lcn.0 started with pid 2088
      2019-10-20 20:56:15.165	info	instance system.adapter.lcn.0 terminated with code null ()
      2019-10-20 20:56:15.165	warn	instance system.adapter.lcn.0 terminated due to SIGTERM
      2019-10-20 20:56:15.059	info	stopInstance system.adapter.lcn.0 killing pid 3580
      2019-10-20 20:56:15.056	info	object change system.adapter.lcn.0
      lcn.0			2019-10-20 20:56:10.346	info	starting. Version 0.4.2 in C:/iobroker/node_modules/iobroker.lcn, node: v10.16.3
      2019-10-20 20:56:08.428	info	instance system.adapter.lcn.0 started with pid 3580
      2019-10-20 20:56:05.969	info	instance system.adapter.lcn.0 terminated with code null ()
      2019-10-20 20:56:05.969	warn	instance system.adapter.lcn.0 terminated due to SIGTERM
      2019-10-20 20:56:05.889	info	stopInstance system.adapter.lcn.0 killing pid 17096
      2019-10-20 20:56:05.888	info	stopInstance system.adapter.lcn.0
      2019-10-20 20:56:05.885	info	object change system.adapter.lcn.0
      2019-10-20 19:58:06.655	info	starting. Version 0.4.2 in C:/iobroker/node_modules/iobroker.lcn, node: v10.16.3
      2019-10-20 19:58:04.373	info	instance system.adapter.lcn.0 started with pid 17096
      2019-10-20 19:57:34.350	info	Restart adapter system.adapter.lcn.0 because enabled
      2019-10-20 19:57:34.350	error	instance system.adapter.lcn.0 terminated with code 0 (OK)
      Caught	2019-10-20 19:57:34.349	error	by controller[0]: at Timeout._onTimeout (C:\iobroker\node_modules\iobroker.lcn\main.js:34:5699)
      Caught	2019-10-20 19:57:34.349	error	by controller[0]: at _0x102ca5._processScanRead (C:\iobroker\node_modules\iobroker.lcn\main.js:34:9409)
      lcn.0	2019-10-20 19:57:34.248	debug	sendTo "scan" to system.adapter.admin.0 from system.adapter.lcn.0
      lcn.0	2019-10-20 19:57:34.241	error	at Timeout._onTimeout (C:\iobroker\node_modules\iobroker.lcn\main.js:34:5699)
      lcn.0	2019-10-20 19:57:34.241	error	at _0x102ca5._processScanRead (C:\iobroker\node_modules\iobroker.lcn\main.js:34:9409)
      lcn.0	2019-10-20 19:56:49.497	debug	sendTo "getAll" to system.adapter.admin.0 from system.adapter.lcn.0
      lcn.0	2019-10-20 19:56:02.996	info	starting. Version 0.4.2 in C:/iobroker/node_modules/iobroker.lcn, node: v10.16.3
      2019-10-20 19:56:00.691	info	object change system.adapter.lcn.0
      iobroker	2019-10-20 19:54:26.049	info	Adapter "lcn" updated
      2019-10-20 19:56:00.722	info	instance system.adapter.lcn.0 started with pid 11104
      Ich nehme an, dass das Modul C:\iobroker\node_modules\iobroker.lcn\main.js ein Problem hat....
      Wer kann mir helfen ?
      Gruß Paul, der heute seine erste Erfahrung mit iobroker macht.
      lcn windows
