    4. [ gelöst ]Nach Host Aktualisierung aus der Oberfläche her raus Iobroker nicht mehr erreichbar.
      Creator last edited by
      Ich habe gesehen das es ein Update gab.
      Leider startet ioBroker nicht mehr seit dem Update.
      Habe mich dann hier durch die Seite gewühlt : http://www.iobroker.net/?page_id=3928&lang=de
      bis jetzt leider ohne erfolg!
      ps -A | grep iobroker
      Liefert kein Ausgabe.
      Dann versucht js-controller neu zu installieren:
      root@nas:/opt/iobroker# npm install iobroker.js-controller
      > iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      npm ERR! Linux 3.2.0-4-amd64
      npm ERR! argv "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v5.10.1
      npm ERR! npm  v2.15.6
      npm ERR! code EPEERINVALID
      npm ERR! peerinvalid The package winston@1.1.2 does not satisfy its siblings' peerDependencies requirements!
      npm ERR! peerinvalid Peer winston-daily-rotate-file@1.1.1 wants winston@2.x
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/node_modules/iobroker/npm-debug.log
      npm install iobroker.admin --production --prefix /opt/iobroker
      npm ERR! argv "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/npm" "install" "iobroker.admin" "--production" "--prefix" "/opt/iobroker"
      Write "./iobroker start" to start the ioBroker
      /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
      Error: TypeError: Cannot set property DailyRotateFile of # <object>which has only a getter
          at Object. <anonymous>(/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:138:36)
          at Module._compile (module.js:413:34)
          at Object.Module._extensions..js (module.js:422:10)
          at Module.load (module.js:357:32)
          at Function.Module._load (module.js:314:12)
          at Module.require (module.js:367:17)
          at require (internal/module.js:16:19)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:7:23)
          at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
          at emitTwo (events.js:100:13)
          at ChildProcess.emit (events.js:185:7)
          at handleMessage (internal/child_process.js:718:10)
          at Pipe.channel.onread (internal/child_process.js:444:11)
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      > iobroker.js-controller@0.9.0 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      async@0.9.2 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/async -> node_modules/iobroker.js-controller/node_modules/async
      colors@1.1.2 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/colors -> node_modules/iobroker.js-controller/node_modules/colors
      deep-equal@0.2.2 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/deep-equal -> node_modules/iobroker.js-controller/node_modules/deep-equal
      fstream@1.0.9 node_modules/iobroker.js-controller/node_modules/tar.gz/node_modules/fstream -> node_modules/iobroker.js-controller/node_modules/fstream
      async@1.0.0 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/winston/node_modules/async -> node_modules/iobroker.js-controller/node_modules/prompt/node_modules/async
      tar@2.2.1 node_modules/iobroker.js-controller/node_modules/tar.gz/node_modules/tar -> node_modules/iobroker.js-controller/node_modules/tar
      ncp@1.0.1 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/ncp -> node_modules/iobroker.js-controller/node_modules/utile/node_modules/ncp
      utile@0.3.0 node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile -> node_modules/iobroker.js-controller/node_modules/utile
      window-size@0.1.4 node_modules/iobroker.js-controller/node_modules/yargs/node_modules/window-size -> node_modules/iobroker.js-controller/node_modules/window-size
      /opt/iobroker
      ├── iobroker@0.7.1
      ├── iobroker.dwd@2.0.3
      ├── iobroker.hm-rega@1.1.0
      ├── iobroker.icons-material-png@0.1.0
      ├── iobroker.icons-material-svg@0.1.0
      ├── iobroker.javascript@2.1.3
      ├─┬ iobroker.js-controller@0.9.0
      │ └── UNMET PEER DEPENDENCY winston@2.2.0
      ├── iobroker.sql@1.0.2
      ├── iobroker.vis-hqwidgets@1.0.0
      ├── iobroker.vis-timeandweather@1.1.0
      ├── iobroker.web@1.4.7
      ├── iobroker.yr@1.0.3
      └── mocha@2.5.3
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN winston-daily-rotate-file@1.1.1 requires a peer of winston@2.x but none was installed.
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      Beim starten von iobroker kommt folgende Meldung:
      root@nas:/opt/iobroker# iobroker start
      Starting iobroker controller daemon...
      at emitTwo (events.js💯13)
      Beim direkten Aufruf des Controllers:
      winston.transports.DailyRotateFile = DailyRotateFile;
      Admin scheint aber zu laufen:
        ` > root@nas:/opt/iobroker# iobroker list instances
      > system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      > system.adapter.fritzbox.0              : fritzbox    -  enabled
      > system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
      > system.adapter.hm-rega.0               : hm-rega     -  enabled
      > system.adapter.yamaha.0                : yamaha      -  enabled
      > system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
      > system.adapter.hmm.0                   : hmm         - disabled
      > system.adapter.vis.0                   : vis         -  enabled
      > system.adapter.ical.0                  : ical        -  enabled
      > system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      > system.adapter.javascript.0            : javascript  -  enabled
      > system.adapter.sayit.0                 : sayit       -  enabled, port: 0
      > system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
      > system.adapter.dwd.0                   : dwd         -  enabled
      > system.adapter.yr.0                    : yr          -  enabled
      > system.adapter.sql.0                   : sql         -  enabled, port: 0
      > system.adapter.icons-material-png.0    : icons-material-png -  enabled
      > system.adapter.vis-fancyswitch.0       : vis-fancyswitch -  enabled
      > system.adapter.vis-metro.0             : vis-metro   -  enabled
      > system.adapter.icons-material-svg.0    : icons-material-svg -  enabled
      > system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled `
      So langsam gehen mir die Ideen aus :(
      Was ist das Problem?</anonymous></anonymous></object>
      ````</anonymous></anonymous></anonymous></object>
        Ich glaube, dass es mit nodejs Probleme gibt.
        Wenn ich es richtig sehe hast du ein 64bit System unter wheezy und nodejs v5.xx
        Ich arbeite mit jessie und nodejs 4.xx
        Das läuft problemlos.
        Ist aber nur eine Vermutung.
        Bluefox kann da bestimmt mehr zu sagen.
          iobroker läuft bei mir auf openmediavault das basiert auf Debian.
          Mit Aktualisierungen habe ich sehr viele Probleme.
          Aus der Oberfläche her raus klappt es zu 90% nicht.
          Ansonsten stresst eigentlich nur hmm siehe http://forum.iobroker.net/viewtopic.php?f=20&t=2804
          Bin schon am überlegen ob ich für iobroker eine eigene VM erstellen sollte.
          Da mein Selbstbau NAS eh läuft wollte ich mir weitere Hardware sparen.
            Es liegt an node.js 5.x. Bitte 4.x verwenden.
              Ich habe die Version geändert.
              root@nas:~# node -v
              v4.4.5
              root@nas:~# npm -v
              3.9.3
              Gemacht habe ich das mit https://github.com/creationix/nvm
              > node lib/setup.js
              npm ERR! argv "/root/.nvm/versions/node/v4.4.5/bin/node" "/opt/iobroker/node_modules/.bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
              npm ERR! node v4.4.5
              npm ERR! argv "/root/.nvm/versions/node/v4.4.5/bin/node" "/opt/iobroker/node_modules/.bin/npm" "install" "iobroker.admin" "--production" "--prefix" "/opt/iobroker"
                  at Module._compile (module.js:409:26)
                  at Object.Module._extensions..js (module.js:416:10)
                  at Module.load (module.js:343:32)
                  at Function.Module._load (module.js:300:12)
                  at Module.require (module.js:353:17)
                  at require (internal/module.js:12:17)
                  at emitTwo (events.js:87:13)
                  at ChildProcess.emit (events.js:172:7)
                  at handleMessage (internal/child_process.js:695:10)
                  at Pipe.channel.onread (internal/child_process.js:440:11)
              /opt/iobroker
              ├── iobroker@0.7.1
              └── mocha@2.5.3
              Beim versuch iobroker zu starten:
              Was mache ich falsch?</anonymous></anonymous></anonymous></object>
                hast du vorher mit````
                apt-get purge nodejs
                rainer
                  Nein aber gerade gemacht. Ändert aber nichts. ( System auch neugestartet )
                  root@nas:~# nvm ls
                           v4.2.6
                  ->       v4.4.5
                           v5.0.0
                           system
                  default -> v4.4.5
                  node -> stable (-> v5.0.0) (default)
                  stable -> 5.0 (-> v5.0.0) (default)
                  iojs -> N/A (default)
                  root@nas:~# npm -v
                  3.9.3
                  root@nas:~# node -v
                  v4.4.5
                  Irgendwie hat der mit dem winston ein Problem was auch immer das jetzt genau ist
                    dann das ganze nochmal mit node statt nodejs
                    und bei versionsabfrage auch nodejs -v
                    rainer
                      Ich habe was anderes ausprobiert:
                      npm install winston
                      Danach lief iobroker sofort wieder. 🙂
                      Ich verstehe nur noch nicht warum!
