    4. Feiertage-Adapter installationsfehler
    UNSOLVED Feiertage-Adapter installationsfehler
      mrMuppet last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz (4 cores), FreeNAS. FreeBSD.
      Arbeitsspeicher: 32GB
      Festplattenart: HDD
      Betriebssystem: FreeBSD 11.2
      Node-Version: v10.16.3
      Nodejs-Version: v10.16.3
      NPM-Version: 6.9.0
      Installationsart: Manuell
      Image genutzt: Nein
      Leider kann ich den Feiertags-adapter installieren. Ich erhalte folgende Meldung:
      $ ./iobroker add feiertage  --host iobroker_v1
      ERROR: internal/modules/cjs/loader.js:800    throw err;
      SyntaxError: /usr/local/www/iobroker/node_modules/iobroker.feiertage/io-package.json: Unexpected token < in JSON at position 1841
          at JSON.parse (<anonymous>)
          at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Upload.uploadAdapter (/usr/local/www/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:266:19)
          at Socket.objects.getObject (/usr/local/www/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:707:20)
          at Socket.onack (/usr/local/www/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      ERROR: process exited with code 1
      • sigi234
        sigi234 Forum Testing Most Active @mrMuppet last edited by
        @mrMuppet
        Was kommt bei:
        cd /opt/iobroker
        iobroker list instances
        node -v
        nodejs -v
        npm -v
          mrMuppet @sigi234 last edited by mrMuppet
          @sigi234
          root@iobroker_v1:/usr/local/www/iobroker # iobroker list instances                   system.adapter.admin-beta.0            : admin-beta  - disabled, port: 9081, bind: 0.0.0.0, run as: admin
          + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                : alexa2      -  enabled
          + system.adapter.cloud.0                 : cloud       -  enabled
            system.adapter.daswetter.0             : daswetter   -  enabled
            system.adapter.flot.0                  : flot        -  enabled
            system.adapter.fritzbox.0              : fritzbox    - disabled
            system.adapter.habpanel.0              : habpanel    -  enabled
          + system.adapter.harmony.0               : harmony     -  enabled
            system.adapter.heatingcontrol.0        : heatingcontrol - disabled
          + system.adapter.hm-rega.0               : hm-rega     -  enabled
          + system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
          + system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
            system.adapter.hm-rpc.2                : hm-rpc      - disabled, port: 0
            system.adapter.hmm.0                   : hmm         - disabled
          + system.adapter.hue-extended.0          : hue-extended -  enabled
          + system.adapter.hue.0                   : hue         -  enabled, port: 80
            system.adapter.hyperion.0              : hyperion    - disabled
            system.adapter.ical.0                  : ical        -  enabled
            system.adapter.ical.1                  : ical        - disabled
            system.adapter.icons-material-svg.0    : icons-material-svg -  enabled
          + system.adapter.influxdb.0              : influxdb    -  enabled, port: 8086
            system.adapter.info.0                  : info        - disabled
          + system.adapter.iot.0                   : iot         -  enabled
          + system.adapter.javascript.0            : javascript  -  enabled
            system.adapter.material.0              : material    -  enabled
          + system.adapter.mihome-vacuum.0         : mihome-vacuum -  enabled, port: 54321
            system.adapter.mobile.0                : mobile      -  enabled
            system.adapter.nest.0                  : nest        - disabled
            system.adapter.nut.0                   : nut         - disabled
            system.adapter.octoprint.0             : octoprint   - disabled
            system.adapter.paw.0                   : paw         - disabled, port: 8898
          + system.adapter.phantomjs.0             : phantomjs   -  enabled
            system.adapter.plexconnect.0           : plexconnect - disabled, port: 10000
          + system.adapter.pushover.0              : pushover    -  enabled
          + system.adapter.sayit.0                 : sayit       -  enabled, port: 0
          + system.adapter.scenes.0                : scenes      -  enabled
            system.adapter.schoolfree.0            : schoolfree  -  enabled
            system.adapter.shuttercontrol.0        : shuttercontrol - disabled
          + system.adapter.simple-api.0            : simple-api  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0              : socketio    -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.squeezebox.0            : squeezebox  -  enabled, port: 9090
            system.adapter.statistics.0            : statistics  - disabled
            system.adapter.systeminfo.0            : systeminfo  - disabled
          + system.adapter.unifi.0                 : unifi       -  enabled
            system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
            system.adapter.vis-google-fonts.0      : vis-google-fonts -  enabled
            system.adapter.vis-justgage.0          : vis-justgage -  enabled
            system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
            system.adapter.vis.0                   : vis         -  enabled
            system.adapter.weatherunderground.0    : weatherunderground -  enabled
          + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.web.1                   : web         - disabled, port: 80, bind: 0.0.0.0, run as: admin
          + system.adapter.yamaha.0                : yamaha      -  enabled
            system.adapter.yr.0                    : yr          - disabled
          + instance is alive
          Die Versionsnummern hab ich oben schon eingetragen.
            Tja, ohne diesen Adapter läuft leider auch mein Heizungsscript nicht mehr... Ich würde ja gerne noch mal alles neu Aufsetzten, aber leider wird der FreeBSD-Install Script ja nicht repariert. So langsam "zerbricht" mein ganzes IoBroker-System.
            feiertag install plugin
