    5. benötige Hilfe bei enigma2 Adapter Erweiterung
    • Matten Matten
      Matten Matten last edited by Matten Matten
      Hallo ich würde gerne den enigma2 Adapter erweitern, in dem ich die Timerabfrage einbauen möchte. Der code sieht wie folgt aus:
      function TimerSearch (command, deviceId, xml) {
      	//var bool;
          switch (command.toUpperCase())
              case "TIMERLIST":
                  // Clear Timerlist
                  adapter.delObject('Timer');
      			if(xml.e2timerlist.e2timer !== undefined)
      				for (var i = 0; i < xml.e2timerlist.e2timer.length; i++)
      					adapter.setObjectNotExists('Timer.' + i + '.Event_Name', {
      						type: 'state',
      						common: {
      							type: 'string',
      							role: 'state',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Station', {
      						type: 'state',
      						common: {
      							type: 'string',
      							role: 'state',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Disabled', {
      						type: 'state',
      						common: {
      							type: 'number',
      							role: 'state',
      							states: {
      								0: 'Timer aktiviert',
      								1: 'Timer deaktiviert'
      							name: 'Timer Aktivität',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Repeated', {
      						type: 'state',
      						common: {
      							type: 'number',
      							role: 'state',
      							name: 'Timer Wiederholung',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Timer_Start', {
      						type: 'state',
      						common: {
      							type: 'number',
      							role: 'state',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Timer_End', {
      						type: 'state',
      						common: {
      							type: 'number',
      							role: 'state',
      							read:  true,
      							write: false
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Timer_servicereference', {
      						type: 'state',
      						common: {
      							type: 'number',
      							role: 'state',
      							read:  true,
      							write: false
      						native: {}
      					//++BUTTON++ 	Timer_Toggle
      					adapter.setObjectNotExists('Timer.' + i + '.Delete', {
      						type: 'state',
      						common: {
      							type: 'boolean',
      							role: 'button',
      							read:  false,
      							write: true
      						native: {}
      					adapter.setObjectNotExists('Timer.' + i + '.Timer_Toggle', {
      						type: 'state',
      						common: {
      							type: 'boolean',
      							role: 'button',
      							read:  false,
      							write: true
      						native: {}
      					adapter.setState('Timer.' + i + '.Event_Name', {val: xml.e2timerlist.e2timer[i].e2name[0], ack: true});
      					adapter.setState('Timer.' + i + '.Station', {val: xml.e2timerlist.e2timer[i].e2servicename[0], ack: true});
      					adapter.setState('Timer.' + i + '.Disabled', {val: xml.e2timerlist.e2timer[i].e2disabled[0], ack: true});
      					adapter.setState('Timer.' + i + '.Repeated', {val: xml.e2timerlist.e2timer[i].e2repeated[0], ack: true});
      					adapter.setState('Timer.' + i + '.Timer_servicereference', {val: xml.e2timerlist.e2timer[i].e2servicereference[0], ack: true});
      					adapter.setState('Timer.' + i + '.Timer_End', {val: DateTime(xml.e2timerlist.e2timer[i].e2timeend[0]), ack: true});
      					adapter.setState('Timer.' + i + '.Timer_Start', {val: DateTime(xml.e2timerlist.e2timer[i].e2timebegin[0]), ack: true});
      			break;
              default:
                  adapter.log.info("received unknown TimerSearch '"+command+"' @ TimerSearch");
      function DateTime(eventtime) {
      	var date = new Date(eventtime * 1000);
      	// Hours part from the timestamp
      	var hours = date.getHours();
      	// Minutes part from the timestamp
      	var minutes = "0" + date.getMinutes();
      	// Will display time in 10:30 format
      	return hours + ':' + minutes.substr(-2);
      Das auslesen der xml und erstellen der Objekte funktioniert soweit, jetzt würde ich gerne auf das auslösen der Objekt-button: 'Timer.' + i + '.Delete' und 'Timer.' + i + '.Timer_Toggle' reagieren
      nun bin ich aber mit meinem Latein am Ende was java Programierung an geht, da die obigen Objekte ja jeh nach dem wie viele Timer Ermittelt wurden unterschiedlich viele sind.
      adapter.on('stateChange', function (id, state) {
      	if (id && state && !state.ack) {
              var parts = id.split('.');
              var name = parts.pop();
              if (id === adapter.namespace + '.Timer.0.Timer_Toggle') {
                  adapter.getState('Timer.' + i + '.Timer_servicereference', function(err, state) {
                      var T_sRef  = state.val;
                      adapter.getState('Timer.' + i + '.Timer_Start', function(err, state) {
                          var T_begin  = state.val;
                          adapter.getState('Timer.' + i + '.Timer_End', function(err, state) {
                              var T_end  = state.val;
                              getResponse('NONE', deviceId, PATH['TIMER_TOGGLE'] + T_sRef + '&begin=' + T_begin + '&end=' + T_end, function (error, command, deviceId, xml) {
                                  if (!error) {
                                      adapter.setState('Timer.' + i + '.Timer_Toggle', state.val, true);
                                  } else {
                                      getResponse('TIMERLIST', deviceId, PATH['TIMERLIST'], TimerSearch);
      		} else if (id === adapter.namespace + '.Timer.0.Delete') {
                              getResponse('NONE', deviceId, PATH['DELETE'] + T_sRef + '&begin=' + T_begin + '&end=' + T_end, function (error, command, deviceId, xml) {
                                  if (!error) {
                                      adapter.setState('Timer.' + i + '.Delete', state.val, true);
                                  } else {
                                      adapter.setState('Timer.' + i + '.Delete', {val: state.val, ack: true});
      Ich hab jetzt das problem das ich nicht weiß wie ich statt :
      //und
      es ändern kann um das genau so dynamisch zu halten
      Ich hoffe ich hab mich verständlich ausgedrückt?
      Matten Matten
      • Matten Matten
        die erstellten Objekte sehen dann z.b. so aus:
        • Matten Matten
          ach ja und das einfache
          löscht leider nicht den Objektordner sammt der Timer 🤷‍♂️
          Scrounger 2 Replies Last reply Reply Quote 0
          • Scrounger
            Scrounger Developer @Matten Matten last edited by
            @Matten-Matten
            Du kannst mit 'getStates("enigma2.0.Timer.*")' bzw. 'getObjects' alle Datenpunkte bekommen. Die musst dann in ner Schleife durchlaufen und die ID zum Löschen der einzelnen Datenpunkte verwenden.
            • Dutchman
              ich müsste die anstehende Struktur bzw Datenpunkte mal sehen.
              theoretisch reagierst du ja immer auf ein event das in iobroker der wert geandert wird, das macht man mit nem subscriptie state (zb * fuer all oder nur die du erstellt hast).
              Ergo der on event gibt dir den state, eventuell musst du nur die "." splitten und dan den letzten nemen fuer deinen wert ?
              • Scrounger
                @Matten-Matten
                Ich hab nochmal über die Struktur der Timer Datenpunkte nachgedacht.
                Ich würde die nicht dynamisch erzeugen und löschen.
                Nehmen wir folgendes Beispiel. Die Box hat aktuell 5 Timer, d.h. es existieren x.Timer.0.x -> x.Timer.5.x. Wenn jetzt eine Aufnahme erfolgt ist würdest du z.B. x.Timer.5.x löschen. Wenn aber jetzt jmd z.B. im Vis oder Skripten den Timer x.Timer.5.x verwendet bekommt der ein Problem.
                Denke es wäre besser du machst z.B. 10 fixe Timer.x Datenpunkte, die dann aufsteigend nach RecordTime befüllt werden. Wenn dann ab Timer.5.x keine mehr existieren, dann lösch nur die Daten in den Datenpunkten. Zusätzlich würde ich noch ein Boolean einführen - timerExist - den du dann in diesem Fall auf 'false' setzen würdest.
                Matten Matten 1 Reply Last reply Reply Quote 0
                • Matten Matten
                  Matten Matten @Scrounger last edited by
                  @Scrounger
                  Die fixe Timerprogrammierung hatte ich schon Mal mit 6 oder sogar 10 timern. Ich denke aber auch das du Recht hast die Timer Datenpunkte fest anzulegen.
