    4. Hm-rega update
    Hm-rega update
      Habe eben das hm-rega update gefahren.
      Die großen Fehlermeldungen im log bei influxDB sind weg, bleibt nur noch:
      Test-Pi3	27 23:06:49.202	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
      Test-Pi3	27 23:06:49.197	info	host.Test-Pi3 Restart adapter system.adapter.influxdb.0 because enabled
      Test-Pi3	27 23:06:49.196	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
      influxdb.0	27 23:06:48.673	warn	influxdb.0 Exception: TypeError: this._createKeyValueString is not a function
      influxdb.0	27 23:06:48.673	error	TypeError: this._createKeyValueString is not a function at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28 at arrayEach (/opt/iobroker/node_modules/iobroker.influx
      influxdb.0	27 23:06:48.671	error	uncaught exception: this._createKeyValueString is not a function
      influxdb.0	27 23:06:38.617	debug	inMem message hm-rega.1.12885 hm-rega.1.12885
      influxdb.0	27 23:06:21.603	error	influxdb.0 Error: retention policy already exists
      Und das war genau das was ich hoffte, dass es weg ist.
