[Install] Synology DS412+ # add sql
Da das Grundgerüst bereits auf der DS läuft, habe ich heute versucht den SQL-Adapter hinzu zu fügen
Es kamen einige Fehlermeldungen im LOG:
sql-0 28 11:51:25.664 info Connected to sqlite sql-0 28 11:51:25.343 info starting. Version 1.0.3 in /volume2/ioBroker/Master/node_modules/iobroker.sql iobroker 28 11:51:20.762 info exit 0 iobroker 28 11:51:20.727 info host.DS object system.adapter.sql.0 created host-DS 28 11:51:20.723 info instance system.adapter.sql.0 started with pid 11166 host-DS 28 11:51:20.648 info object change system.adapter.sql.0 iobroker 28 11:51:20.613 info host.DS object system.adapter.sql.0.alive created iobroker 28 11:51:20.580 info host.DS object system.adapter.sql.0.connected created iobroker 28 11:51:20.538 info host.DS object system.adapter.sql.0.memHeapUsed created iobroker 28 11:51:20.498 info host.DS object system.adapter.sql.0.memHeapTotal created TypeError: 28 11:51:20.408 error at TCP.onread (net.js:523:20) TypeError: 28 11:51:20.408 error at Socket.Readable.push (_stream_readable.js:110:10) TypeError: 28 11:51:20.408 error at readableAddChunk (_stream_readable.js:146:16) TypeError: 28 11:51:20.408 error at Socket.emit (events.js:169:7) TypeError: 28 11:51:20.408 error at emitOne (events.js:77:13) TypeError: 28 11:51:20.408 error at Socket.realHandler (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:800:20) TypeError: 28 11:51:20.408 error at Receiver.add (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:95:24) TypeError: 28 11:51:20.408 error at Receiver.expectHandler (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:457:31) TypeError: 28 11:51:20.408 error at Receiver.opcodes.1.finish (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:482:12) TypeError: 28 11:51:20.408 error at Receiver.flush (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:340:3) TypeError: 28 11:51:20.408 error at /volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:466:14 TypeError: 28 11:51:20.408 error at Receiver.applyExtensions (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:364:5) TypeError: 28 11:51:20.408 error at /volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:477:18 TypeError: 28 11:51:20.408 error at Receiver.ontext (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:816:10) TypeError: 28 11:51:20.408 error at WebSocket.emit (events.js:172:7) TypeError: 28 11:51:20.408 error at emitTwo (events.js:87:13) TypeError: 28 11:51:20.408 error at WebSocket.onMessage (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:418:14) TypeError: 28 11:51:20.408 error at WebSocket.ws.onmessage (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:132:10) TypeError: 28 11:51:20.408 error at WS.Transport.onData (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) TypeError: 28 11:51:20.408 error at WS.Transport.onPacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) TypeError: 28 11:51:20.408 error at WS.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) TypeError: 28 11:51:20.408 error at WS. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10) TypeError: 28 11:51:20.408 error at Socket.onPacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14) TypeError: 28 11:51:20.408 error at Socket.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) TypeError: 28 11:51:20.408 error at Socket. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 28 11:51:20.408 error at Manager.ondata (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16) TypeError: 28 11:51:20.408 error at Decoder.add (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) TypeError: 28 11:51:20.408 error at Decoder.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) TypeError: 28 11:51:20.408 error at Decoder. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 28 11:51:20.408 error at Manager.ondecoded (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8) TypeError: 28 11:51:20.408 error at Manager.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 28 11:51:20.408 error at Manager. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 28 11:51:20.408 error at Socket.onpacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12) TypeError: 28 11:51:20.408 error at Socket.onevent (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10) TypeError: 28 11:51:20.408 error at Socket.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 28 11:51:20.408 error at Socket. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/lib/objects/objectsInMemClient.js:74:30) TypeError: 28 11:51:20.408 error at Object.that.objects.Objects.change (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/lib/adapter.js:382:77) TypeError: 28 11:51:20.408 error at Object.utils.adapter.objectChange (/volume2/ioBroker/Master/node_modules/iobroker.javascript/javascript.js:94:44) TypeError: 28 11:51:20.408 error Cannot read property 'name' of undefined message 28 11:51:20.309 error _design/history [object Object] Cannot read property 'name' of undefined iobroker 28 11:51:20.448 info host.DS object system.adapter.sql.0.memRss created iobroker 28 11:51:20.361 info host.DS object system.adapter.sql.0.uptime created iobroker 28 11:51:20.346 info host.DS create instance sql iobroker 28 11:51:20.224 info host.DS object _design/history created iobroker 28 11:51:20.115 info host.DS object system.adapter.sql created iobroker 28 11:51:19.578 info upload [0] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/index.html index.html text/html iobroker 28 11:51:19.360 info upload [1] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/sql.png sql.png image/png iobroker 28 11:51:19.008 info upload [2] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/storage.html storage.html text/html iobroker 28 11:51:18.953 info got /volume2/ioBroker/Master/node_modules/iobroker.sql/admin iobroker 28 11:51:18.657 info host.DS install adapter sql iobroker 28 11:50:04.835 info npm install iobroker.sql --production --prefix "/volume2/ioBroker/Master" (System call) iobroker 28 11:50:03.331 info add sql
Später soll er die History in einer mySQL DB speichenrn.
Gibt es Grund zur Sorge? (Aufgrund der Fehlermeldungen)
Jürgen
