    4. Installation klappt nicht auf RPi2 Raspbian Jessie
    UNSOLVED Installation klappt nicht auf RPi2 Raspbian Jessie
    • V
      Velo17 last edited by Velo17
      Hallo zusammen!
      Ich versuche ioBroker zu installieren, leider ohne Erfolg. Das Script sagt zwar am Ende, dass es geklappt hätte, allerdings werden folgende Fehler vorher angezeigt:
          Installing ioBroker (3/4)
      ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmiss
           struct statvfs info = {};
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmis
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmis
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmiss
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmis
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmiss
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmiss
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmis
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissi
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_unused’ [-Wm
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissi
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmi
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmi
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is de
      p/10.17.0/include/node/v8.h:2891): Use Isolate version [-Wdeprecated-declarations]
         v8::String::Utf8Value path(info[0]->ToString());
      ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is depreca
      17.0/include/node/v8.h:10046): Use maybe version [-Wdeprecated-declarations]
         v8::Local<v8::Object> options = info[1]->ToObject();
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::V
      ../nan/nan.h:1740) [-Wdeprecated-declarations]
         data->callback.Call(2, argv);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprec
      .17.0/include/node/v8.h:10046): Use maybe version [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
      ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      /../nan/nan.h:1740) [-Wdeprecated-declarations]
         data->callback.Call(1, argv);
      ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
      ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
      ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprec
      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
      ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
      ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
      ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
      ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::
      ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
      ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value
         obj->callback.Call(2, argv);
      events.js:174
            throw er; // Unhandled 'error' event
      Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
          at Server.setupListenHandle [as _listen2] (net.js:1280:14)
          at listenInCluster (net.js:1328:12)
          at doListen (net.js:1461:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
      Emitted 'error' event at:
          at emitErrorNT (net.js:1307:8)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.5.14 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.5.14 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/pi/.npm/_logs/2019-10-26T08_53_11_238Z-debug.log
      Wenn ich, wie im Fehlersuche Artikel beschrieben, versuche den js-contoller manuell zu starten, passiert folgendes:
      pi@raspberrypi1:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
      internal/modules/cjs/loader.js:638
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      Führe ich die Installation des js-controller nochmal aus, kommt es zu den obigen Fehlern:
      pi@raspberrypi1:/opt/iobroker $ npm install iobroker.js-controller
      > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.12.0
      npm version >= 5: disabling package-lock
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_unused’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissing-field-initializers]
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
      > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
      events.js:174
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2019-10-26T09_21_04_783Z-debug.log
      Vermutlich ist folgendes dann normal, aber ich hab es einfach mal eingegeben:
      pi@raspberrypi1:/opt/iobroker $ iobroker list instances
          throw err;
      Das /opt/iobroker/log/ Verzeichnis ist übrigens leer.
      Falls jemand einen Tipp hat, würde ich mich freuen 🙂
      Grüße aus Düsseldorf,
      Velo17
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi2
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian Debian Jessie
      Node-Version: 10.17.0
      Nodejs-Version: 10.17.0
      NPM-Version: 6.12.0
      Installationsart: Skript
      Image genutzt: Nein
        Jan1 @Velo17 last edited by
        @Velo17
        Mal ne blöde Frage, warum ein Raspian von 2015 und kein aktuelles Buster?
        • V
          Velo17 @Jan1 last edited by Velo17
          @Jan1 So blöd ist die Frage ja nicht 🙂 Ist neben ein paar PiZeros mein einziger schnellerer Pi und darauf laufen einige Dienste. Auch eine andere Heimautomation, die aber für die kommenden Aufgaben nicht mehr geeignet ist. Logitech Mediaserver usw. usf. - ich dachte ich teste ioBroker mal darauf, bevor ich mich entscheide, wie es weitergeht.
          Ob ein Distroupgrade funktioniert, wäre auch eine gute Frage. Könnte ich auch versuchen (ich mache auch Backups, von daher wäre das auch rückgängig zu machen), mit der Frage, was danach alles nicht mehr läuft 😉
            @Velo17
            Na dann mal ran an Buster 😊
            • V
              @Jan1 Ich mach erstmal den Schritt auf Stretch - oder glaubst Du, ein dist upgrade von Jessie auf Buster geht genauso gut / schlecht? Wenn nach Jessie noch alles halbwegs läuft, kann ich ja noch den Versuch zu Buster machen...Ist ja noch früh 😉
                @Velo17
                Du hast doch bestimmt ein Backup der Karte, dann würde ich eh gleich ne neue nehmen und das das Backup drauf und direkt auf Buster hoch, wenn es funktioniert, dann hast Zeit gespart und wenn nicht, was gelernt😁
                installation raspberrypi
