    3. Tester
    4. Test Adapter hue-extended
    • Zefau
      Zefau last edited by Zefau
      Repository https://github.com/Zefau/ioBroker.hue-extended
      A sigi234 Horst Böttcher A 5 Replies Last reply Reply Quote 2
        aleks-83 @Zefau last edited by
        Der Punkt "Synchronisiere auch doppelte Szenen" ist jetzt übrigens auch verfügbar.
          aleks-83 last edited by
          Wasn nu los?
          Aus heiterem Himmel.
          Hat das was mit dem extended Adapter zu tun?
          2019-10-30 11:00:16.237 - info: weatherunderground.0 (1076) Terminated (NO_ERROR): Without reason
          2019-10-30 11:00:16.770 - info: host.NUC(NUCmaster) instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2019-10-30 11:00:23.131 - info: host.NUC(NUCmaster) instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2019-10-30 11:01:00.010 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 started with pid 8868
          2019-10-30 11:01:05.516 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
          2019-10-30 11:31:00.421 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 started with pid 8440
          2019-10-30 11:31:05.270 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
          2019-10-30 11:55:52.103 - error: host.NUC(NUCmaster) Caught by controller[1]: FATAL ERROR: Ineffectiv
          2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[2]: e mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[3]: 1: 00007FF78CCFDD8A v8::int
          2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[4]: ernal::GCIdleTimeHandler::GCIdleTimeHandler+4506
          2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[4]: 2: 00007FF78CCD8886 node::MakeCallback+4534
          2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[4]: 3: 00007FF78CCD9200 node_module
          2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[5]: _register+2032
          2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[5]: 4: 00007FF78CFF30DE v8::internal::FatalProc
          2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[6]: essOutOfMemory+846
          2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[6]: 5: 00007FF78CFF300F v8::inte
          2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[7]: rnal:
          2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[8]: :FatalProcessOutOfMemory+639
          2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[8]: 6: 00007FF78D1D9804 v8::internal::Heap::MaxHeapGrowingFactor+9620
          2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 7: 00007FF78D1D07E6 v8::internal::ScavengeJob::operator=+24550
          2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 8: 00007FF78D1CEE3C v8::internal::ScavengeJob::operator=+17980
          2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 9: 00007FF78D1D7B87 v8::internal:
          2019-10-30 11:55:52.110 - error: host.NUC(NUCmaster) Caught by controller[9]: :Heap::MaxHeapGrowingFactor+2327
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[9]: 10: 00007FF78D1D7C06 v8::internal::Heap::MaxHeapGrowingFactor+2454
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[9]: 11: 00007FF78D301EA7 v8::i
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: nternal::Factory::NewFillerObject+55
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: 12: 00007FF78D37F096 v8::internal::operator<<+73494
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: 13: 000003688D75C5C1
          2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 terminated with code 134 (134)
          2019-10-30 11:55:52.111 - info: host.NUC(NUCmaster) Restart adapter system.adapter.hue-extended.0 because enabled
          2019-10-30 11:56:22.122 - info: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 started with pid 8052
          • BBTown
            BBTown @aleks-83 last edited by
            @aleks-83 sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
            Da ist doch bereits ein Hinweis ...
              ... den ich nicht verstehe 😬
              • BBTown
                BBTown @aleks-83 last edited by BBTown
                @aleks-83
                ok, ich versuche dir auf die Sprünge zu helfen ... out of memory
                Du hast ein Speicher(platz) Problem
                  aleks-83 last edited by aleks-83
                  Wüsste nicht wo
                  • Dr. Bakterius
                    Dr. Bakterius Most Active last edited by
                    Ich hatte heute auch eine Warnung (per Skript) bekommen, dass der RAM voll läuft. Die hue-extended Instanz hat fast 900 MB verbraucht. Nach einem Neustart der Instanz war der Verbrauch wieder normal, steigt aber wieder langsam an. 😕
                      HeliosFan @Dr. Bakterius last edited by
                      @Dr-Bakterius Kann ich nicht bestätigen.
                      Bei mir macht der hue.exetended keinerlei Problemene.
                      Der einzige Adapter der sich völlig grundlos immer wieder über 100 MB aufbläst, ist der BackitUp.
                      Dr. Bakterius 1 Reply Last reply Reply Quote 0
                        Adnim last edited by
                        Hi!
                        nutze auch schon länger den extended, genaue einstiegsversion kann ich nicht sagen. Die Aktuelle Version schaltet meine Lampen aber nicht mehr zuverlässig. Die Trigger der Szenen werden ausgelöst das sehe ich im LOG, allerdings schaltet dann die Lampe nicht an. Manchmal funktioniert es, nachstellen wann und warum konnte ich nicht. Werde LOG nachreichen wenn ich den Fehler wieder sehe!
                        Hat sowas sonst jemand?
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @HeliosFan last edited by
                          @HeliosFan Bisher auch keine Probleme in den letzten Monaten (seit ich diesen Adapter verwende). Doch in den letzten 2,5 Stunden hat er sich von ca. 80 MB nach dem Neustart auf fast 500 MB entwickelt.
                          Zefau 1 Reply Last reply Reply Quote 0
                          • Dr. Bakterius
                            Dr. Bakterius Most Active last edited by Dr. Bakterius
                            Wie kann man eigentlich eine bestimmte / ältere Version des Adapters installieren? Wenn man auf das + klickt wo man die Version wählen kann, kommt bei mir nur folgendes:
                            Edit:
                            Habe es auf der Console gemacht:
                            root@iobroker:/# cd /opt/iobroker
                            root@iobroker:/opt/iobroker# npm install iobroker.hue-extended@1.1.1 --production
                            • Zefau
                              Zefau @Dr. Bakterius last edited by
                              @Dr-Bakterius sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                              Ist der Garbage Collector in den Adapter Einstellungen aktiviert?
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @Zefau last edited by Dr. Bakterius
                                @Zefau sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                                Nein, ist er nicht. Mit v1.1.1 habe ich das RAM-Problem bisher nicht.
                                  Adnim @Adnim last edited by Adnim
                                  @Adnim sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                                  Hi!
                                  Hier mal die Logs @Zefau was ist falsch bei mir?
                                  hue-extended.1	2019-10-31 06:00:03.421	debug	(24027) Attempt 1x - No commands to send to TreppeOG (NachtlichttreppeOG) (groups/2/action).
                                  hue-extended.1	2019-10-31 06:00:03.401	debug	(24027) Add to queue ({"path":"scenes.002-treppeog.nachtlichttreppeog","type":"scenes","name":"TreppeOG (NachtlichttreppeOG)","uid":"sKOKnMzhniQQNzP","trigger":"groups/2/action"}) commands: {"scene":
                                  hue-extended.1	2019-10-31 06:00:03.400	debug	(24027) State of hue-extended.1.scenes.002-treppeog.nachtlichttreppeog.action.trigger has changed {"val":true,"ack":false,"ts":1572498003399,"q":0,"from":"system.adapter.javascript.0","user":"system.
                                  hue-extended.1	2019-10-31 05:57:40.287	debug	(24027) Attempt 1x - No commands to send to Bad (Nachtlicht) (groups/1/action).
                                  hue-extended.1	2019-10-31 05:57:40.172	debug	(24027) Add to queue ({"path":"scenes.001-bad.nachtlicht","type":"scenes","name":"Bad (Nachtlicht)","uid":"dr0jUSsdM1VFCgt","trigger":"groups/1/action"}) commands: {"scene":"dr0jUSsdM1VFCgt"}
                                  hue-extended.1	2019-10-31 05:57:40.172	debug	(24027) State of hue-extended.1.scenes.001-bad.nachtlicht.action.trigger has changed {"val":true,"ack":false,"ts":1572497860171,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","
                                  Weiterhin sehe ich gerade das der RAM verbrauch NIO ist:
                                  • Dr. Bakterius
                                    Mit der v1.1.2 stimmt einiges nicht. Der RAM läuft voll und man kann keine ältere Version über die Weboberfläche installieren. Bei der v1.1.1 existieren diese Probleme nicht. Ob es auch Probleme beim Senden der Befehle gibt, habe ich erst gar nicht getestet.
                                    • Zefau
                                      @Dr-Bakterius @Adnim @aleks-83 danke euch für das intensive Testen und das wertvolle Feedback. Die Version v1.1.3 sollte die Punkte beheben (changelog siehe https://github.com/Zefau/ioBroker.hue-extended/releases).
                                      A 1 Reply Last reply Reply Quote 2
                                        Wie kommst du dann eigentlich immer so schnell auf die Fehlerursachen?
                                        Sie werden doch wohl nicht so offensichtlich sein!?
                                        Sonst hättest du sie ja gar nicht erst "drin gelassen".
                                        EDIT:
                                        Bei mir steigt der RAM Verbrauch vom extended Adapter 1.1.3 immer noch stetig an.
                                        gestartet bei ca. 74 MB. Nach 10 Minuten bei 86 MB
                                        Dr. Bakterius Zefau 2 Replies Last reply Reply Quote 0
                                        • Dr. Bakterius
                                          Dr. Bakterius Most Active @aleks-83 last edited by
                                          Das war bei v1.1.1 auch so. Bei mir hat er nach 24 Stunden etwa 200 MB beansprucht. Aber v1.1.2 war nach wenigen Stunden bei fast 1 GB! Mal sehen wie sich v1.1.3 verhält...
                                          • Zefau
                                            Zefau @aleks-83 last edited by Zefau
                                            @aleks-83 auf wie viel ist der refresh eingestellt? Was steht in der Instanzübersicht unter Ereignisse (neben RAM-Nutzung)? Ist die Warteschlange / Queue aktiviert?
                                            31.7k
                                            79.8k
                                            hue hue-extended
                                            49
                                            167
                                            20819
