    4. Node-Red
    5. NodeRed und Schalter
      Blackeye last edited by
      kann mir jemand erkläre was ich hier falsch gemacht habe?
      [{"id":"404cf3d6.414dfc","type":"alexa-smart-home-v3","z":"d4a854fe.904","conf":"413f0174.010c08","device":"3454","acknowledge":true,"name":"Licht","topic":"","x":130,"y":380,"wires":[["58151fa5.102de"]]},{"id":"d3d482b0.9f1ca8","type":"ccu-value","z":"d4a854fe.904","name":"Licht Melissa","iface":"BidCos-RF","channel":"MEQ0361861:1 Licht Melissa","datapoint":"STATE","mode":"","start":true,"change":true,"cache":false,"queue":false,"on":0,"onType":"undefined","ramp":0,"rampType":"undefined","working":true,"ccuConfig":"38263145.35ea0e","topic":"${CCU}/${Interface}/${channel}/${datapoint}","x":850,"y":380,"wires":[[]]},{"id":"b141d369.3293d","type":"function","z":"d4a854fe.904","name":"","func":"if ((msg['command']) == 'TurnOff') \n{\nmsg['payload'] = false;\n}\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":420,"wires":[["d3d482b0.9f1ca8"]]},{"id":"58151fa5.102de","type":"switch","z":"d4a854fe.904","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":380,"wires":[["93d87d17.a1f88"],["b141d369.3293d"]]},{"id":"93d87d17.a1f88","type":"function","z":"d4a854fe.904","name":"","func":"if ((msg['command']) == 'TurnOn') \n{\nmsg['payload'] = true;\n}\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":320,"wires":[["d3d482b0.9f1ca8"]]},{"id":"413f0174.010c08","type":"alexa-smart-home-v3-conf","z":"","username":"Melissa2502","mqttserver":"mq-red.cb-net.co.uk","webapiurl":"red.cb-net.co.uk"},{"id":"38263145.35ea0e","type":"ccu-connection","z":"","name":"localhost","host":"localhost","regaEnabled":true,"bcrfEnabled":true,"iprfEnabled":true,"virtEnabled":true,"bcwiEnabled":false,"cuxdEnabled":true,"regaPoll":true,"regaInterval":"30","rpcPingTimeout":"60","rpcInitAddress":"127.0.0.1","rpcServerHost":"127.0.0.1","rpcBinPort":"2047","rpcXmlPort":"2048","queueTimeout":"5000","queuePause":"250","contextStore":""}]
      Das kommt aus dem Adapter:
      {"topic":"","name":"Licht","_messageId":"ffe9171f-d234-48e7-b5f8-738650d794d5","_endpointId":"3454","_confId":"413f0174.010c08","command":"TurnOn","extraInfo":{},"payload":true,"acknowledge":true,"_msgid":"47c8ffb.302c8"}
      Und das aus de Funktion:
      Für mich sieht das gut aus, aber Alexa sperrt sich und will auch nicht ausschalten..
      81.1k
