    5. [gelöst] split is not a function
    SOLVED [gelöst] split is not a function
    • CKMartens
      CKMartens last edited by CKMartens
      ich bin gerade dabei ein Script zu erstellen das mir den 3stündigen Trend für die Barometerdaten errechnet. Dazu habe lege ich alle 5 Minuten den Wert für den Unterschied zum vorherigen Wert in einem Datenpunkt als Liste ab
      -0.05,0.02,0.04,0.04,0,0.08,0.06,0,0.03,0.03,-0.02,-0.05,0.05,-0.05,0.06,0.02,-0.12,0.06,0.02,-0.04,0.07,0.04,-0.02,0.02,0.04,0.04,0.01,-0.02,0.06,0.04,-0.07,-0.11,0.11,-0.11,0,0.02,-0.02,0.05,0.02,0,0.03,0.01,0.04,-0.09,0.02,-0.04,0.03,0.06,0.1,-0.08,-0.04,0.05,0.03,0.01,0.02,0.01,0.05,0.03,0.1,0,0.01,-0.02,0.02,-0.01,-0.04,0.04,0.08,0.03,-0.05,-0.12,0.09,0.07
      Diese Liste lese ich mit ein und will sie mit split zum errechnen des Trends zerlegen
      function barotrend() {
        var tmpelements = getState(DP_BAROTREND_DATA).val.split(',');
        for (let i = 2; i <= ELEMENTS - 1; i++) {
          b_tmp = parseFloat(tmpelements[i]);
          A_BAROTRENDTEMPDATA.push(b_tmp);
          b_akt_diff = b_akt_diff + b_tmp;
        A_BAROTRENDTEMPDATA.push(b_diff);
        b_akt_diff = b_akt_diff + b_diff;  b_akt_diff = Math.round((b_akt_diff / ELEMENTS) * 100 ) / 100;
        setState(DP_BAROTREND_DATA, A_BAROTRENDTEMPDATA);
        setState(DP_BAROTREND_ALT, b);
        setState(DP_BAROTREND_TREND, b_akt_diff);
      schedule('*/'+CRON+' * * * *', function () {
        barotrend();
      Allerdings kommt spätestens nach dem zweiten Aufruf der Funktion barotrend() der Fehler
      javascript.1	2019-11-05 19:49:00.018	error	(2070) at Timer.processTimers (timers.js:223:10)
      javascript.1	2019-11-05 19:49:00.017	error	(2070) at listOnTimeout (timers.js:263:5)
      javascript.1	2019-11-05 19:49:00.017	error	(2070) at tryOnTimeout (timers.js:300:5)
      javascript.1	2019-11-05 19:49:00.017	error	(2070) at ontimeout (timers.js:436:11)
      javascript.1	2019-11-05 19:49:00.017	error	(2070) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.1	2019-11-05 19:49:00.016	error	(2070) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.1	2019-11-05 19:49:00.016	error	(2070) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.1	2019-11-05 19:49:00.016	error	(2070) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1279:34)
      javascript.1	2019-11-05 19:49:00.015	error	(2070) at Object.<anonymous> (script.js.Test.Weathercalc:417:3)
      javascript.1	2019-11-05 19:49:00.015	error	(2070) at barotrend (script.js.Test.Weathercalc:390:53)
      javascript.1	2019-11-05 19:49:00.014	error	(2070) Error in callback: TypeError: getState(...).val.split is not a function
      Node.js v10.17.0
      NPM 6.11.3
      js-controller: 2.0.39
      Kann mir einer sagen wo da der Fehler ist?
        paul53 @CKMartens last edited by
        @CKMartens sagte:
        Enthält der Datenpunkt schon ein Array ? Dann funktioniert .split(',') nicht und ist auch nicht erforderlich.
        CKMartens 1 Reply Last reply Reply Quote 1
        • CKMartens
          CKMartens @paul53 last edited by CKMartens
          @paul53 sagte in split is not a function:
          @CKMartens sagte:
          Wie muss ich dann vorgehen @paul53 ?
            @CKMartens sagte:
            Ohne split() einlesen.
              var tmpelements = getState(DP_BAROTREND_DATA).val;
            CKMartens 2 Replies Last reply Reply Quote 1
            • CKMartens
              @paul53 Ah... Ok, versuche ich morgen. Danke schon einmal.
              • CKMartens
                @CKMartens sagte:
                Hallo @paul53
                leider habe ich jetzt das Problem das jetzt die Variable tmpelements als Elemente jedes Zeichen enthält. Also aus dem Wert -0.3 werden die Elemente "-", "0", "." und "3" gemacht. Der Typ des Datenpunktes ist ein Array.
                  paul53 @CKMartens last edited by paul53
                  @CKMartens sagte:
                  Dann wurde das Array an anderer Stelle als String im Datenpunkt gespeichert. Das muss korrigiert werden.
                  • CKMartens
                    @CKMartens sagte:
                    Hmmm, eigentlich greift nur noch ein andres Script lesend auf den DP zu. Danke für den Tip, ich mach mich da mal geziehlt auf die Suche
                      @CKMartens sagte:
                      Wenn in einem Skript ein String in einen Datenpunkt vom Typ "array" geschrieben wird, erfolgt eine Warnung "wrong type ...". Im Reiter "Log" findet man dazu den Skriptnamen und die Zeilennummer.
                      • CKMartens
                        @paul53 Habe es gefunden. Ein Testscript ist noch gelaufen obwohl es im eigentlich deaktiviert gewesen sein sollte.
                        Jetzt läuft es. Danke nochmals!
                        javascript
                        1643
