    4. Fehler bei Update Javascript Adapter auf 4.3.3
    SOLVED Fehler bei Update Javascript Adapter auf 4.3.3
      spaceduck last edited by
      muss mich mal an euch wenden weil ich nicht weiterkomme... Ich wollte gerade den Javascript Adapter von 4.3.2 auf 4.3.3 updaten. Folgende Fehlermeldung:
      899 warn enoent ENOENT: no such file or directory, open '/volume1/opt/iobroker/node_modules/mailparser-mit/package.json'
      900 verbose enoent This is related to npm not being able to find a file.
      901 warn enoent ENOENT: no such file or directory, open '/volume1/opt/iobroker/node_modules/iobroker.node-red/node_modules/utf7/package.json'
      902 verbose enoent This is related to npm not being able to find a file.
      903 verbose stack Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
      904 verbose cwd /volume1/opt/iobroker
      905 verbose Linux 4.15.0-66-generic
      906 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install" "iobroker.javascript@4.3.3" "--loglevel" "error" "--production" "--save" "--prefix" "/volume1/opt/iobroker"
      907 verbose node v10.17.0
      908 verbose npm  v6.10.0
      909 error path /volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc
      910 error code EACCES
      911 error errno -13
      912 error syscall unlink
      913 error Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
      913 error  { [Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc']
      913 error   cause:
      913 error    { Error: EACCES: permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc'
      913 error      errno: -13,
      913 error      code: 'EACCES',
      913 error      syscall: 'unlink',
      913 error      path:
      913 error       '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc' },
      913 error   stack:
      913 error    'Error: EACCES: permission denied, unlink \'/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc\'',
      913 error   path:
      913 error    '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
      913 error   parent: 'iobroker.javascript' }
      914 error The operation was rejected by your operating system.
      914 error It is likely you do not have the permissions to access this file as the current user
      914 error
      914 error If you believe this might be a permissions issue, please double-check the
      914 error permissions of the file and its containing directories, or try running
      914 error the command again as root/Administrator (though this is not recommended).
      915 verbose exit [ -13, true ]
      Folgendes ist zum log zu sagen:
      1. '/volume1/opt/iobroker/node_modules/mailparser-mit/package.json' & '/volume1/opt/iobroker/node_modules/iobroker.node-red/node_modules/utf7/package.json' sind nicht vorhanden, ja richtig, aber auch in meinen alten Backups nicht...
      2. permission denied, unlink '/volume1/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc' ist bei mir ein link auf ../typescript/bin/tsc - permissions sind 777
      Ich komm nicht weiter, kann mir jemand erklären was da schiefläuft?
      Hier noch meine Config falls es hilft:
      Betriebssystem: linux
      Architektur: x64
      CPUs: 2
      Geschwindigkeit: 2065 MHz
      Modell: Intel(R) Celeron(R) CPU G1610T @ 2.30GHz
      RAM: 3.81 GB
      Node.js: v10.17.0
      NPM: 6.10.0
        spaceduck @sigi234 last edited by
        Habe es gerade selbst hinbekommen, ein
        "chmod -R 777 /volume1/opt/iobroker/node_modules/iobroker.javascript/"
        hats gelöst, da war doch noch ein permission problem...
        Danke trotzdem!
        • sigi234
          sigi234 Forum Testing Most Active @spaceduck last edited by
          @spaceduck
          Schon mal den Fixer angewandt?
          https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
            Jepp lief drüber, hat aber keine Änderung gebracht
            • sigi234
              @spaceduck sagte in Fehler bei Update Javascript Adapter auf 4.3.3:
              Neustart?
              Was kommt bei:
              cd..iobroker
              iobroker list instances
              node -v
              nodejs -v
              npm -v
                Danke trotzdem!
                javascript adapter
