    4. Radar2 - bt already scanning Problem
    UNSOLVED Radar2 - bt already scanning Problem
      Pittini Developer last edited by Negalein
      Nach etlichen Fehlschlägen hab ichs geschafft Radar2 auf ein aktuelles System zu installieren, leider hakts noch irgendwo. Wenn ich iobroker starte, läuft erstmal einige Stunden alles prima. Bluetoothgeräte werden erkannt, IPs auch, allerdings viel zu wenige, is mir aber egal, brauch nur Bluetooth mit G-Tags für Anwesenheitserkennung.
      Initialisierung schaut für mich gut aus:
      radar2.0	2019-11-13 15:10:07.069	info	(25050) Adapter initialization finished!
      radar2.0	2019-11-13 15:10:06.668	info	(25050) first scan took 25.207 seconds
      radar2.0	2019-11-13 15:09:41.457	info	(25050) radar2 set use of noble(true), doArp(false), btid(0) and doUwz(null,0,0,,false).
      radar2.0	2019-11-13 15:09:41.456	info	(25050) radar2 found 2 devices in config (Keeper_Carlo,G-Tag_Andrea)
      radar2.0	2019-11-13 15:09:41.454	info	(25050) No UWZ warning because of Delay is 0
      radar2.0	2019-11-13 15:09:40.822	info	bts norm: ()
      radar2.0	2019-11-13 15:09:40.822	info	bts LE: (7c:2f:80:e9:f0:be,58:9e:c6:10:51:0d),
      radar2.0	2019-11-13 15:09:40.822	info	ips: (),
      radar2.0	2019-11-13 15:09:40.822	info	(25050) Adapter identified macs: (),
      radar2.0	2019-11-13 15:09:40.816	info	(25050) Init item G-Tag_Andrea with { name: 'G-Tag_Andrea',bluetooth: [ '!58:9e:c6:10:51:0d' ],id: 'G-Tag_Andrea',type: 'BT',btVendor: 'Gigaset Communications GmbH',lasthere: '2019-11-13T12:53:09.983
      radar2.0	2019-11-13 15:09:40.761	info	(25050) Init item Keeper_Carlo with { name: 'Keeper_Carlo',bluetooth: [ '!7c:2f:80:e9:f0:be' ],id: 'Keeper_Carlo',type: 'BT',btVendor: 'Gigaset Communications GmbH',lasthere: '2019-11-13T13:38:31.320
      radar2.0	2019-11-13 15:09:40.534	info	(25050) Will try to scan BT devices: true
      radar2.0	2019-11-13 15:09:40.512	info	(25050) Connected with '0.0.0.0' for DHCP Scan
      radar2.0	2019-11-13 15:09:40.500	info	(25050) radar2 set to scan every 55 seconds and printers every 720 minutes.
      radar2.0	2019-11-13 15:09:40.499	info	(25050) arp-scan will use the following interfaces: [ 'ens18' ]
      radar2.0	2019-11-13 15:09:40.499	info	(25050) use known IP list: [ '192.168.2.1','192.168.2.5','192.168.2.10','192.168.2.15','192.168.2.20','192.168.2.25','192.168.2.50' ]
      radar2.0	2019-11-13 15:09:40.498	info	(25050) use known BT list: [ 'c4:7c:8d:6a:bd:e6' ]
      radar2.0	2019-11-13 15:09:40.495	info	(25050) radar2 set to flag items away if they are not seen for 3 minutes
      radar2.0	2019-11-13 15:09:40.483	info	(25050) found and will use '@abandonware/noble'
      radar2.0	2019-11-13 15:09:40.393	info	(25050) found and will use 'node-bluetooth scan'
      radar2.0	2019-11-13 15:09:40.385	info	(25050) radar2 starting main...
      radar2.0	2019-11-13 15:09:40.385	info	(25050) radar2 initialization started...
      radar2.0	2019-11-13 15:09:39.330	info	(25050) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.17.0
      radar2.0	2019-11-13 15:09:35.478	warn	(9578) Adapter will exit in latest 1 sec with code false!
      radar2.0	2019-11-13 15:09:35.478	info	(9578) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      radar2.0	2019-11-13 15:09:35.477	info	(9578) terminating
      radar2.0	2019-11-13 15:09:35.477	info	(9578) Adapter disconnected and stopped with dostop(false) and callback(true)
      radar2.0	2019-11-13 15:09:35.476	info	(9578) Got terminate signal TERMINATE_YOURSELF
      radar2.0	2019-11-13 15:08:45.958	warn	(9578) BT already scanning!
      radar2.0	2019-11-13 15:07:50.958	warn	(9578) BT already scanning!
      Nach einigen Stunden (4h war das min. und ca. 16h das max.) erscheint dann im Log:
      radar2.0	2019-11-11 16:41:54.389	warn	(26089) BT already scanning!
      Dann werden auch die Bluetooth Devices als abwesend gewertet - und nie wieder als anwesend. Ein Adapterneustart hilft meist ist aber keine echte Lösung.
      Ich hab sämtliche Tipps hier befolgt, Noble und hci Socket jeweils von abandonware genommen, dann das hier:
      sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
      Da ich den JS Controller 2.x verwende, dann auch gepatcht nach dieser Anleitung:
      cd /opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/
      mv myAdapter.js myAdapter.bakup
      wget -O myAdapter.js https://forum.iobroker.net/assets/uploads/files/1570619515405-myadapter.js
      Wäre für Tipps oder Ideen dankbar, bin einerseits kein Linux Profi und andererseits fällt mir nach gesamt x Stunden Bluetoothfehler suchen nix mehr ein.
      Hier noch die Adapter Einstellungen:
      Systemdata
      Hardwaresystem: NUC
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Proxmox > Debian Buster
      Node-Version: v10.17.0
      Nodejs-Version: v10.17.0
      NPM-Version: 6.11.3
      Admin: 3.6.12
      JS Controller: 2.x
        Alex975 @Pittini last edited by
        @Pittini sagte in Radar2 - bt already scanning Problem:
        Hallo kannst Du mir sagen welche Problem du hattest bei der Installation? Ich versuche auch verzweifelt auf die 1.2.0 Version auf meinem Rasp3 zu kommen, der will aber immer neu kompilieren und bricht dabei immer ab.
        Habe mit der Version 1.0.9 aber auch die BT Already Meldungen.. ein Neustart des Adapters bringt nichts, weil er dann meldet, der Adapter läuft bereits.
        Geht also nur ein Reboot / Restart des Iobrokers. Radar2 läuft bei mir als Multihost.
          Pittini Developer @Alex975 last edited by
          @Alex975 sagte in Radar2 - bt already scanning Problem:
          Ich denk dass das nicht zu vergleichen ist, ich installierte auf Nuc unter Proxmox mit Debian (Buster).
          Nachdem ich nach wie vor nicht eingrenzen kann ob das Problem an Noble oder dem Adpter oder beidem liegt hab ich mich auf nen postmortem Workaround verlegt. Ich hab ein Script gemacht, welches sobald die bt already....blabla im Log auftaucht, den Adapter neustartet mit Verzögerung. Läuft seit Wochen jetzt so stabil, aber ne echte Lösung isses trotzdem nicht. Hier das scriptchen, vieleicht hilfts ja auch bei Dir.
          //Startet den Radar2 Adapter neu wenn Fehler bt already scanning
          var obj = getObject("system.adapter.radar2.0");
          function ResetRadar() {
              obj.common.enabled = false;  // Adapter ausschalten
              setObject("system.adapter.radar2.0", obj);
              setTimeout(function () {
                  obj.common.enabled = true;  // Adapter wieder einschalten
               }, 5000);
          function checkWarnings(data) {
              //Warn1
              if (data.message.includes("BT already scanning!")) {       // hier angleichen warning meldung
                  ResetRadar();
          onLog("warn", checkWarnings);
          Kenn ich. Mach mal nicht neustart vom Adapter, sondern nur stop. 5sek warten, dann wieder starten, bei mir gehts so recht zuverläßig.
          bluetooth bug radar2 radar2 adapter
