    4. Alexa 2 Adapter gibt Error im log aus?
    UNSOLVED Alexa 2 Adapter gibt Error im log aus?
    • MyzerAT
      MyzerAT last edited by MyzerAT
      hi Ihrs,
      seit kurzem bekomme ich im log folgende Meldung, habe nichts verändert oder getan und es schaut auch so aus als ob alles noch funktioniert!
      alexa2.0	2019-11-12 20:11:20.631	info	Alexa-Push-Connection established. Disable Polling
      alexa2.0	2019-11-12 20:10:27.271	info	Alexa-Push-Connection Error: Error: read ECONNRESET
      alexa2.0	2019-11-12 20:10:21.950	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:10:21.950	info	Alexa-Push-Connection Error: Error: read ECONNRESET
      alexa2.0	2019-11-12 20:08:01.355	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:08:01.354	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
      alexa2.0	2019-11-12 20:07:56.307	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:07:56.305	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
      alexa2.0	2019-11-12 20:07:51.277	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:07:51.275	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
      alexa2.0	2019-11-12 20:07:46.238	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:07:46.237	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
      alexa2.0	2019-11-12 20:07:41.154	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
      alexa2.0	2019-11-12 20:07:41.153	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
      • Dr. Bakterius
        Dr. Bakterius Most Active last edited by
        Diese Meldungen habe ich auch seit heute Abend!
        Wenn man sie etwas sagen lassen will (per 'speak'), sagt sie jetzt vor dem Text "sprich mir nach...". Manchmal kommt auch nur das und der eigentliche Text fehlt. Über 'SSML' funktioniert aber alles normal.
        Handelt sich um einen DOT2 mit FW 647642120 aber auch bei anderen Echo-Geräten. Da dürfte Amazon heute Nachmittag etwas geändert haben!
        @apollon77: was meinst du dazu?
          fuchs1978 last edited by
          Bei mir gleiches Problem
          • liv-in-sky
            liv-in-sky last edited by liv-in-sky
            dito - bei mir auch
            bei mir haben heute nachmittag auch die smarhome geräte nicht geschaltet
            • Dr. Bakterius
              Habe gerade begonnen einige Skripte für 'SSML' umzubauen, da hat es plötzlich wieder normal funktioniert.
              Hoffentlich war das nur ein kurzer Schluckauf...
              • apollon77
                apollon77 last edited by
                Ja klingt nach nem kaputten Amazon Update 😞
                • MyzerAT
                  seit 20:15 sind die Meldungen im log weg!
                  eventuell ist es ja wieder behoben seitens Amazon ?
                  alexa 2 adapter
