    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер погоды Weatherunderground
    • E
      electric last edited by
      07.06 драйвер перестал работать, в логе ошибки:
      ! weatherunderground-0 2016-06-07 11:00:45.816 error Wunderground reported an error: Error: getaddrinfo ENOTFOUND api.wunderground.com api.wunderground.com:80 TypeError: 2016-06-07 11:00:45.802 error at Socket.socketErrorListener (_http_client.js:267:9) TypeError: 2016-06-07 11:00:45.802 error at ClientRequest.emit (events.js:169:7) TypeError: 2016-06-07 11:00:45.802 error at emitOne (events.js:77:13) TypeError: 2016-06-07 11:00:45.802 error at Request.onRequestError (/opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/request/request.js:831:8) TypeError: 2016-06-07 11:00:45.802 error at Request.emit (events.js:169:7) TypeError: 2016-06-07 11:00:45.802 error at emitOne (events.js:77:13) TypeError: 2016-06-07 11:00:45.802 error at self.callback (/opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/request/request.js:200:22) TypeError: 2016-06-07 11:00:45.802 error at Request._callback (/opt/iobroker/node_modules/iobroker.weatherunderground/weatherunderground.js:128:29) TypeError: 2016-06-07 11:00:45.802 error at new Buffer (buffer.js:65:10) TypeError: 2016-06-07 11:00:45.802 error at fromObject (buffer.js:138:11) TypeError: 2016-06-07 11:00:45.802 error must start with number, buffer, array or string uncaught 2016-06-07 11:00:45.791 error exception: must start with number, buffer, array or string !
      Но потом, вроде, опять заработал:
      host-cubietruck	2016-06-07 13:30:09.769	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      weatherunderground-0	2016-06-07 13:30:05.353	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.weatherunderground
      Я так понимаю были проблемы на сервере wunderground.com? Он просто был недоступен?
      • E
        08.06 (были обновления) ошибки в логе:
        host-cubietruck	2016-06-08 20:00:11.684	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
        weatherunderground-0	2016-06-08 20:00:07.615	error	Reported WU-Error Type: keynotfound
        weatherunderground-0	2016-06-08 20:00:07.608	error	Could not parse Conditions-Data: TypeError: Cannot read property 'display_location' of undefined
        weatherunderground-0	2016-06-08 20:00:05.670	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.weatherunderground
